OBD II Linking Error !!??
woscarr
06-25-2012, 08:43 PM
Ok I just received one of these chepo scanners from china and it don't work on my 2002 Silhouette !? Bummer :(
The kicker, my work truck a 2012 Dodge Ram it works perfectly ! Scans in seconds and shows no codes message.
I checked the plug itself on the van wires and plug seem intact. It powers the scanner and the scanner scans but eventually gives a linking error.
The scanner... U480 OBD2 CAN-BUS Scanner Code For GM Ford Toyota Honda
Where to go from here. Wanted to find out what's causing my engine light to come on.
Just did some searching.. Tomorrow I will check pins 4,5 chassi/signal ground, pin 16 12v and where I think my problem might be pin 7 'Kwire" as I did install a after market stereo system.
Any ideas on how to get this 'kwire' working with a Dennon head !? Dose it go through a factory stereo ? If so possible to bypass from loop ??
Thanks
Wayne.
Thanks
Wayne.
danielsatur
06-26-2012, 10:47 AM
What year is the van?
Check the fuse to the DLC connector.
Tech II
06-26-2012, 12:02 PM
What are the numbered blocks in the ALDL that have contacts?
#4 chassis ground
#5 signal ground
#16 bat
What other contacts do you have...
#4 chassis ground
#5 signal ground
#16 bat
woscarr
06-26-2012, 08:31 PM
#4 chassis ground
#5 signal ground
#16 bat
Ok I checked the obd2 connector in my 2002 Oldsmobile Silhouette..
#2 + 0.50v
#4 ground 0.0v
#5 ground 0.0v
#16 + 11.9v
All other pins are empty
#4 chassis ground
#5 signal ground
#16 bat
#2 + 0.50v
#4 ground 0.0v
#5 ground 0.0v
#16 + 11.9v
Tech II
06-26-2012, 09:33 PM
If you only have 4 contacts, and #2 is the fourth, that circuit is Class II serial data.....should not be 0.5 volts.....should be constantly varying between 12 and zero, when communicating, so this can vary between 3-6 volts.....have the vehicle scanned for "U" codes....
DOUGLASNC
11-11-2012, 08:26 PM
My scanner wouldn't connect to a GM and read any code's.. Turned out that cigarette lighter fuse was blown.
