misfire on 3.0 v6 code is confussing
ITSWRONGWAY
03-27-2011, 08:14 AM
my 01 escape with 3.0 v6 has code that comes up as po351. the code list says it is the primary coil ?? my engine has a coil pack on each plug so what am I not understanding here ?? it does not give any one cyl. as a misfire. this only happens when the temp outside gets to around 20 degrees.
65comet
03-29-2011, 12:19 PM
I usually don't post links for other forums, but just about every option was discussed in this thread.
http://www.ford-trucks.com/forums/576951-touble-code-p0351.html
Either bad wire or bad pcm seems to be most common if you already swapped coil and plugs.
