recommended scanners.
snakecan2
11-21-2010, 11:40 PM
looking to possibly buy a scanner that will reset codes, read full codes from sensors, not just give me error codes. need fuel pressure rail pressure, transmission info, reset odometer for tire change, etc.
info much appreciated, found some info on cummins forum via google search and other than couple that do not support cummins much seem like not much better than info that autozone gives out.
theFREAKnasty82
11-30-2010, 09:30 AM
well, be prepared to open up your wallet because little cheap scanners like actron will not do everything that you want it to. You'll either have to buy one from a tool truck like Snap-On or Matco or check www.bullydog.com and see what they have. I know their diesel tuner can also do some limited functions with the PCM.
jmike575
12-28-2010, 02:36 PM
we have a snap on modis one of the lower cost ones and it does a good job but be ready to dish out for that one
