03 altima crank but wont start HELP !!!!
bgaltima
05-23-2010, 07:12 PM
I have an 03 Altima. It cranks well... but sometimes it won't start. I had to have it towed to the dealer this last time. The code came up "misfire" is what the dealer told me. And said it was a very generalized code and could be anything. They replaced the spark plugs and it worked great a couple of days. Now, it's back to not starting well. Any ideas?
nissan cat
05-29-2010, 02:22 AM
Dude again it the ecm/cat/head gasket. My guess is Oil comsumotion or coolant consumtion(sorry abou spelling this ain't english class) if it starts it will run well, until it burns what's in the chambers;but trust me take it to get reflashed if you have not done so. From what i have heard and seen they reprogram the ecm to ra=ead the crank/cam sensor as one, worked for me. Either that or they will replace the engine, cat, and reflash the ecm for free if you are lucky, BUT DONT WAIT!!!
G4M
07-06-2010, 09:48 AM
I bought my 03 new and it's done this about two times a year since probably 2005. The dealership told me it was a common problem in the 03 but they didn't have a fix. They told me to step on the gas and let it crank until it starts. This always work but sometimes it takes a few minutes. When it does finally start huge clouds of white smoke come out the exhause for a few seconds and then all is fine. I know this isn't a technical answer but it's all I have. Good luck.
