95 olds cutlass supreme gauges
bigdaddy121005
04-26-2010, 06:53 PM
I had to replace a few bulbs on the back of my gauge pod and now that i have it put back together none of my gauges work. I checked all the connections on wires and they are nice and tight I checked the fuses i have no bad fuses but still no luck. Tach reads nothing gas gauge reads nothing temp gauge reads off the charts. Any one have an idea? or am i gonna have to buy a new one?
serge_saati
04-26-2010, 07:28 PM
Check voltage at pink wire. You should have 12V.
Check if it's well connected.
bigdaddy121005
04-27-2010, 01:32 PM
thanx man u saved me a major head ache. only thing is now my abs light all of a sudden came on. fuses are good i am assuming the relay is fine, but i dont have a scanner to check codes. brakes work fine still so not quite sure whats going on. any suggestions?
serge_saati
04-27-2010, 03:09 PM
Check the ABS control module connection (under-hood on passenger side). It has a red wire that need to be tight.
Check also the indicator control circuit connection in the instrument cluster. This circuit controls the ABS lamps. It has 3 connections. It's also connected to the ABS module.
