View Full Version : Outback
- 2009 outback coolant issue
- 2020 Outback Transmission Failure
- Really Upset about 2020 Outback
- Engine seize?
- Cap or Cover for hole on Roof?
- Crossbar Question
- Fuse prong broke inside panel!
- Replacing Tires
- Subaru 1998 Legacy Outback
- 2006 Subaru Outback 2.5 wagon P0171
- Eyesight Switching Off
- 2011 Outback passenger air bag light...
- no fuel delivery to engine
- how to open a seized up car door
- I'm trying to figure out if i blew my Engine or if it could be something else
- 2004 Subaru Outback Engine Mounts
- Bought a used '04 Subaru Outback w/ 184,000 miles
- 2001 Subaru Outback Engine sounds AWFUL suddenly
- 2015 Subaru Outback - Official
- Charging issue?!?!?
- NJ Subaru Tuner Event
- 2012 Fog Lamp replace for Driving Lights
- '05 Outback - only dash and defroster vents work
- 02 starting issues
- my 97 outback overheats
- '08 When barely given gas, car stalls
- Cold Weather 'diesel' smell
- Subaru 2001 Outback H6 3.0L Engine - Test Drive... what to look for?
- 2001 Outback AWD 2.5L Fault Code P0328
- Snow Tires & Rims
- 1996 Outback rattle noise before and after shifting
- A/C belt squeal - 2002 Outback
- Car noob needs bumper help
- 1997 Outback Liftgate ajar light always on
- 2006 Outback Brake trouble
- vibration on acceleration
- Consumer Likeness
- Subaru Dome Light Issue
- 01 subaru dome light
- '02 Outback Hesitation on acceleration
- Steam under engine on a rainy day
- Windshield Wiper Wing
- Better buy?
- Air conditioner/Heater intermittent
- Electric Problems
- Change ATF & filter on 06 Outback at 52k ?
- 2001 vdc
- Wheels & Tires for rough roads
- Cruise Control
- passengar seatbelt alarm
- '04 outback no audio from speakers
- The notorious P0420 code ... again
- Strange noise in 5th gear
- Changing rotors on 02 Outback`
- 1996 Outback Subura Vibrations
- want to buy 98 outback
- New Battery, No Speedo
- Can i tow an enclosed two place snowmobile trailer with a 1997 outback?
- 2002 Outback code PO420 back again
- "Check Engine" light intermittently on/off?
- Brakes Whine at Hi Way Speed
- 06 Outback Wagon Sparkplugs
- 1996 transmission, need I new one
- My subaru keeps stalling
- '98 Bearing Replaced, Car Shaking
- '97 outback brakes "hard" to press
- '99 Outback tranny clicking
- Outback transmission shifting hard
- Outback power steering and brakes died
- 1998 outback
- 2001 Outback Spark Plug boots
- 06 outback traction question
- 2002 2.5 - mysterious coolant issues
- Stereo Electrical Help
- Whirring sound on acceleration
- Help!!
- Knocking noise when warm
- Need Subaru 2.5 engine, Have Questions
- 97 Outback Wagon worth $1900 ?
- Thinking of Buying 07 or 08 Outback
- 2006 Outback weak suspension
- Transmission problem?
- 25K maintenance
- 2.5 wants to die
- subaru legacy outback STI
- Brakes / Steering Wheel Feedback
- 3.0 Boxer Octane Requirements
- Amber parking lights always on
- Outback AC
- Finally got pics of my 2002 Rocky Mountain Edition wagon
- Couple of questions about H6 equipped models
- awd fuse for outback
- '99 Outback brake job...anything special?
- Looking to buy a 2001 outback
- help with 97 CV joint
- 2001 H6 LL Bean belt/pulley squeak
- Synthetic Oil
- Low gas mileage and pulsating after front brake change
- Removal of Mirror Assembly...
- 1996 Legacy Outback AWD Not working
- Spark Plug Blow Out
- Need help!
- 06 Outback 2.5i wagon brakes
- A whiner
- Alarm Security Problem
- Growling Noise in rear end
- Strange 'whining' noise
- outback drive shaft
- Brakes on 2000
- Rear hub removal . . . won't budge
- Windshield Wiper fluid/pump
- tire recommendation 06 Outback wagon
- Looking to buy, what to look for
- 96 outback 2.5 stuuters under load
- gas filter location 2005 Outback 2.5i
- 1998 outback
- 04 Outback Drive Side Window Mechanism - Busted
- new 02 outback tranny
- 96 Outback Dash Lights and Parking Lts Blinking
- wants to die
- TIming Belt hange on '95 Outback
- Outback wagon with multiple codes...
- 2000 Outback overheats, loses coolant
- Poll: What to do About
- Thinking about buying
- Outback Tires
- 96 subaru outback 2.5, 152K over heating
- Adjusting the parking brake
- 2000 Outback - Transmission
- CEL code P0420
- water sound
- power mirror switch
- Cold start problems on 02 Outback
- AfterMarket timing belt kits
- Maintance manual
- Vents
- Blown head gasket in 99 Outback?
- 04 Cabin Air Filter
- 1996 subaru help
- subaru help please
- Catalytic Converter Replacement
- Windshield visor
- AC problem
- Cai
- Subaru steering wheel lock problem
- Name that part
- aftermarket audio in an outback?
- Automatic Transmission for 2000 Outback Legacy
- Strange Noise
- Subaru Advice Please
- 04 outback half shaft seal?
- looking at getting my lil a bro an outback wagon
- would you recommend a wagon?
- Tool req'd for aiming brights??
- Ringing Sound When Accelerating
- 00' Outback, check engine light
- Steering Chatter
- General Outback Interest
- Squeaky brakes
- Serpentine Belt Squeek
- 05 Subaru OUTBACK XT LIMITED FOR SALE
- new '05 outback sedan
- 97 outback sport radio no sound
- 1996 Outback Heater core, DIY?
- tires
- Subaru XM Radio Reception Problems??
- Oil Consumption
- Transmission stick in firts gear
- No Heater After draining cooling sytem
- squeeky wheel
- 2006 Outback 3.0 R - FWD Only & Regular Fuel?
- Cheapest Model with Leather?
- Are 4-Cylinder Automatics Underpowered?
- Towing questions
- Service Manual
- Outback's Low JD Powers Ratings
- Outback Automatic Trans. Clunky
- Sunroof Question
- 01 outback
- sulphur exhaust inside cabin
- Is my AWD Working - 98 Outback
- Fuel smell in cab
- Manual trans pops out of gear....
- Luggage rack torx screws
- Changing Automatic Transmission Fluids on Outbacks
- 97 outback overheating
- '97 Outback rear accessory socket not working
- 99 Outback Hubcap Problem
- '96 Outback (Japanese import) Stereo antenna change.
- 2000 Outback Limited Sedan AWD for sale - Chicago
- Brake Job
- Brakes don't work when cold
- 2005 Subaru Outback H6 VDC 3.0R -- Fails To Start Intermittently
- 2000 Outback Fuel Line Problem
- WRX Motor Swap?
- head gaskets vs. rebuilt engine
- Automatic Door Lock/Unlock
- What is this Filter?
- weak alternater?
- 1999 Outback Rear "Subaru"/back-up light assembly
- Burnt Valves
- steering wheel vibration
- Numbers on 04 Outback H-6 3.0
- stereo on 02 outback
- Lighting Diode(headlights)
- 2005 4cyl info please
- 2003 Outback H6-3.0 Performance
- Rain guards?
- 96 Outback bogging when sharp turning
- What Year for Turbo Motor Outback?
- Returning a Leased Outback
- Air Intake for a '98 Outback?
- Need to service the auto trans
- CEL...code P0325
- Future Mud-Bogging Outback
- 2002 back firing
- 2000 Outback check engine code P1443
- engine trouble
- 2004 Outback
- 2000 Outback transmission won't go right into drive.
- 97 transmission
- 2000 outback - strange noise
- Outback Testdrive
- oil leak
- The Best of Both Worlds
