View Full Version : 3 Series
- Recommended Restoration Shop NY,CT,NJ
- Lowering a 2000 323i
- Stereo Muffled/ no vocals
- Bmw E46 problems. (n42b20a)
- BMW 2002 325CI Code P0491 and P0492
- What’s Bi-directional test? How does it benefit me?
- Unfamiliar concept: longitudinal acceleration calibration
- Introduce the PINs of OBDII interface and cheap way to check them
- Two Exhaust Pipe + Multiple O2 sensors, code P2277, how to know which sensor goes wrong?
- What’s after replacing ABS----Initialization
- BMW X3 E83 Steering Angle?
- Wrong fuel
- 2009 335i exhaust
- No battery and trunk is shut. How do I open the trunk?
- 320i Seat belt warning light goes off erratically when belt is on
- 99 323i E46, faulty MPG display from OBC
- What is your favorite serie 3 bmw ?
- Need advice!!!
- aircon problems bmw e46 318i 2005
- BMW 325i won't turn over
- Dope M3 Pics
- Looking at 325i with sunroof issues
- 318i unlock code
- e36 and s85b50
- Faulty Steering Problem
- 2001 BWM Blower Motor Control
- 1997 328i parts for sale
- fuel pump
- Low gas interruption
- BMW 325xi Starting problem
- College student looking to get an E30 or E46...
- E30 325e vs. 318i
- BMW E30 Modernization Kit
- 2003 325i Oil light on after 4k
- Need help removing rock chips off my bmw asap!!!
- Life expectancy - 99 328i
- What do you think i can get for it
- BMW 318i SE
- Kitchen Sale Edinburgh
- my new car
- 1991 BMW 318is with 1991 BMW M5 Engine
- Vossen Envisions Wheels on BMW 4-Series Coupe
- 04' 330CI Headlight Unit Quote
- 2001 bmw 325ci engine problems
- too much engine braking and excessive fuel consumption
- E36 with Mercedes Shoes
- 2014 BMW 4 Series Convertible spy pictures
- 2006 325i BMW E90 Oil Change Question
- air bag and B tool not working
- 95 bmw 325is overheating on highway
- 1993 BMW 318i e36 spark plug leads
- 2001 325I speedometer error code reset
- Help! power widow/mirror switch NOT working.
- 2000 BMW 323CI E46. Should I buy it?
- should i buy a 2006 325xi?
- Bmw 320d cabrio M-Pack 2005
- 2000 bmw 328ci: headlights flicker...common prob???
- 2009 BMW 328i I am buying!
- I am french and i would like to know your judgement about bmw'cars
- First Buy - Is this a good deal?
- BMW 3 Series E46 DVD Navigation
- E36 325i 1994Model
- 328i inline 6 stumbles
- Please help newbie
- Aluminum Body 3 Series?
- 2007 328i high pitch wine
- Radio code for BMW
- Good News! BMW E46 Has Upgrade! Faster than Before!
- final drive swap
- Help - Buying first BMW
- E36 BMW Reliability at 140k
- Is A 330 xi Worth It?
- short film M3
- Should I purchase used?
- WTB 320i Iintake runners
- E36 automatic trans service
- Auto up window not working
- af news video: 2
- AF's new youtube newsfeed
- How the heck do you get to the front turn siginal bulb?
- 2002 330I OBD II Code P0741
- 2001 330ci heater/AC fan Problems
- Oil problem
- My M5 E60
- Kenwood KVT-516 in 2006 325i?
- Team Edlinger - BMW 320 IRL
- Info about BMW
- Getting a '94 318is that's been sitting
- How to Open the Center Console?
- 2007 330i dim light problem
- Bentley
- 93 325is Fuel Pump
- BMW 1995 328i
- How to reset brakes sensor light on 2007 BMW 335xi
- E30 wiring question - aux fan high speed relay
- Dead Battery
- Oil level sensor light on, oil full
- '93 320i Braking issues
- 95 325i Failed emissions high nox
- Hello from Maryland, USA!
- 2002 330ci engine swap
- What should I look for when buying a used BMW
- '84 325e starts but won't run
- Windshield for may car (2001 320ci)
- Throttle RPM's stick when ASC on.
- 1995 318is....oil on plugs
- 1995 318is...power drain
- Interior lights and rear number plate light come on when I lock my 316i
- Newbie girl needs help!
- 99 328i interesting happenings ...
- I've never seen this one before lol
- BMW diagnostic tool
- 335i Coupe vs Sedan
- bmw help
- e21 bmw 320is pics
- 1995 318I OBD1 access port
- E36 elect window help plz :)
- 1995 318is...setting the digital clock
- Crazy Widebody E46 Sedan
- 1995 318is....windows act strange
- CAR SITE + photo
- Keys inside of the trunk
- 2001 330Ci problems
- Fuse box Diagram for 92 BMW 325ic???
- 1989 325i Coupe - Suspension
- Factory Hardtop Option on 94 325
- 93 320i not turning on.
- First time bimmer buyer
- Need help
- e36 ---HELP!!!!!!!!!!!
- Help - convertible top repair - hydrualic hose replacement
- Are either of these a better bet
- need help plz with wiring on a 325ci .. intake wires..
- 93 325i auto tran 1st & 4th bad
- Fog Light Alignment
- Converting a manual convertible top to a powered one
- ignition switch removal
- A/C fan
- 2001 bmw 330i key problem
- help! need torque spec for bolts
- 2005 E46 vs 2006 E90. Seeking opinions
- 2000 323i Rear Drivers Side Window Problems
- Convertible Rear Window
- Der Meister Inc 2508 West Tennessee Street, Tallahassee, FL
- BMW right front grabbing
- 86' 325e won't start
- Small Oil Filter part broken HELP!!!
- 93 325is wont start
- 86 325E fuel pump issue.
- Bmw m3 gts
- 5 Series Tires Rubbing on back of 320i
- headgskt +stripped bolt holes = new eng
- BMW 320D getting fault code 3FF0 - fixes and repairs?
- 2005 BMW Ci Fake Stick Shift
- electrical snafu
- E46 performance options?
- please help!! the engine starts but shuts off after 2 seconds
- 325is blown head gasket
- Lowered BMW problems... :-(
- Vanos
- Two very different estimates..
- Replacing Rear Shock
- 1993 318 won't start
- 2000 BMW 323i losing power!
- How much would it cost to fix...
- road noise
- Water temp. gauge shot up but no overheating?
- 05 m3/coupe headlights on an 01 sedan?
- oil pressure switch
- Stock Tires (Potenza)
- 1994 3series seat repair
- Service Engine Soon Light
- Dtc code p0340???
- How can I get to directional light bulb?
- BMW m3 rims
- 84 325e Turn signal relay
- Programming Key for 325i
- IF YOU OWN A E46 3 Series THIS IS A MUST READ
- Window won't go up on my 2000 323i
- 2004 BMW 330I Dummy Light
- Tdc
- 2001 325ci
- '88 E30 has gone thru 2 fuel pumps!
- car won't start
- 94 325is rear end
- rough idle
- E 30 soft top rear window
- Cooling fan problem
- CD changer
- Clutch replacement; How high?
- whats better odb1 or 2 i need help????
- 2003 rear wheel bearing insall
- 96 bmw 318 celicius to farenheit
- battery goes flat overnight
- 1995 328i doesn't go help
- Please delete my account
- part out of a E36
- HELP! ran short on clearcoat
- 2003 325i thinking about it
- BMW 335i / M3 in matte black ( waw ) - pics
- 84 318 doesnt run
- 94 318is looking for exhaust
- 97 BMW 316i - overheating saga in need of some advice
- is there anyone out there to help a lady in distress?
- antenna stuck in down position...argh!
- Looking for reasonable-priced performance mods.
- 1995 325i Cooling system overheating troubleshooting
- idle control sensor
- 2000 323i Will Not Reverse!
- Engine Swap
- Control Unit Supply?
- wierd humming/whinning sound in rear of car
- 600$ 1989 i325 Coupe
- 1997, 318 tourer, m.o.t.
- How much 2006 bmw 325i should cost
- Extreme crash BMW vs Volvo [Video], who you think will be in the best shape???
- Window relays
- right rear blinker
- Happy with performance intake performance!
- 323i starter noise
- 1985 318 has no spark and fuel pumps are not turning on.
- climate control
- guibo inquiry
- high pitch noise - goes away when brake is applied
- '89 - 325 Gasket Manufacturer?
- Bmw m3
- blinking oil light
- mid and windows not working
- DSC and ABS
- 93 325is No spark No fuel
- 1989 351i stops
- Interchanging '96 318ti parts with '95 318i
- 2001 bmw 330i alternator help!!!!
- Air conditioning issues
- Shaking in steering wheel while driving
- unsure of loud exhaust
- Effects of broken door lock actuator
- bmw 320i
- bmw 320i
- Is there a website that sells imported engines from Germany?
- 2003 bmw 3 series m3ci
- Steering rack
- 2000 328Ci - How to make it faster? Or should I get a G35?
- 90 325i ABS light
- 318i bmw
- 2004 325i sluggish with P0411 code
- BMW Art Car-Guy decorates car with Sharpie
- I just bought in!
- Instrument Panel change & program
- hardtop question
