View Full Version : Engineering/Technical
  1. tips for my 93 Accord
  2. red "H"
  3. Engine Troubles
  4. transmission conversion?
  5. ecu removal
  6. JDM 88-91 Civic SiR Cluster For Sale
  7. Open and Heat Shielded Air Filter--What's the Difference?
  8. Camshafts
  9. d16y8 into 96 dx
  10. weird vibration that varies with speed and steering?
  11. weird vibration that changes with speed and turns..?
  12. why is my ACT HDSS clutch slipping?
  13. Dodge Caravan Transmission
  14. Engine/tranny Question
  15. Can't decide what new car to get.
  16. Vibration Question (2000 Maxima 5spd)
  17. Need Help !!!
  18. type r cams
  19. Airbag expulsion location
  20. Fuel pressure question...
  21. non-vtec to vtec
  22. PIAA Plasma Light Bulbs any good?
  23. Door mirrors.
  24. Passing Inspections
  25. What mufflers would you perfere?
  26. Exhaust
  27. Cat. conv. problem
  28. Knocking sound on slow turns on my 2003 Acura EL
  29. H22A swap sensor problems
  30. What Happened!?!
  31. Merry Christmas!!
  32. apexi or fields vtec controller setting
  33. 93 Civic HB Swap
  34. Engine/Tranny Question...
  35. TornadoFuelSaver
  36. Need motor swap + F/I
  37. run 12's
  38. CRVTEC or simple B18C1
  39. bunch of stuff
  40. b16a sir1 auto tranny?
  41. Muffler is too loud!
  42. What to do to engine before swapping in
  43. 94 GSR with 96+ Spec R B18C Wiring Harness work?
  44. B16A Header
  45. Thrush Turbo Mufflers??
  46. My Integra ran over a puddle and now my engine has knocking noises!!
  47. Amsoil?
  48. New Ecu??
  49. Mini me conversion
  50. How to ground wires
  51. Help me Buy a new car
  52. motorswap for 95 civic coupe
  53. JDM D-series
  54. non OBD injector question?
  55. 93 sol, what to watch for
  56. Nsx
  57. Hardcore JDM Lovers only!
  58. cam gears & Pulleys??
  59. is it bad to drive with the E brake?
  60. Header or Pulleys?
  61. Black smoke with downshift
  62. R-1 Racing Performance head
  63. Auto Paints
  64. Coilovers Vs Lowering Springs
  65. help with throttle body
  66. How to change brakes on a CRX`
  67. Need Help
  68. Need Advice
  69. New Plugs?
  70. need to get check engine code
  71. Integra or Prelude
  72. Anyone see a crx with power steering???
  73. Honda's VTEC.
  74. goveners
  75. weird engine noise
  76. Engine suddenly turn it off when i came to a stop sign???!~
  77. simple break light question, eh
  78. Loudest Exhaust!!!
  79. The Fast and the Furious Eclipse
  80. 2001 tahoe
  81. Civic Type R cams or not?
  82. Engine year??
  83. B16 distributor
  84. funny idling
  85. Timing belt repair
  86. redline
  87. 1996 JDM H22 authenticity
  88. ZC or not?????
  89. What Is The Loudest Muffler Out There?
  90. 93 Civic HB Motor Swap
  91. 93 Civic HB Motor Swap
  92. Oil film longetivity on cylinder walls
  93. 91 SSE Climate Control Problem
  94. B16a2 or B18C
  95. The Importance of automobiles survey.
  96. help!!
  97. new cam installation
  98. who knows the specs on the JDM Honda/Acura Vigor ??
  99. timing belt
  100. Downshift in Automatic?
  101. Is This It?
  102. Eagle or Crower Rods for High Boost from Turbo
  103. D16A8/9 or ZC
  104. Catalytic Converter Fit Issues after engine swap
  105. robo shifters worth a damn?
  106. Theories on this?
  107. Which motor mounts should I use?
  108. prelude swaps
  109. paint spotting
  110. lowend torque on a/t
  111. pistons, cam, valve springs ect..
  112. integra jdm tranny...need help
  113. Differences In B16 Heads?
  114. I Need Help
  115. Help me please!!!!
  116. 5g Civic b16a Axles?
  117. 2nd gen integra tranny swap
  118. CIVIC H22A Engine transplant
  119. crank angle sensor for 1992 Civic
  120. off the line
  121. Help! weird buzz when acclering
  122. B18B or B18A
  123. ractive strut bar?
  124. Injectors
  125. Stand Alone Ignition System
  126. coil for 1993 prelude
  127. 3.2 TL Starting Problem
  128. 89 Integra...few problems
  129. Exhaust Noises??
  130. The rear drivign lights are not working...
  131. How to Install OEM ITR intake manifold onto B16CRX???
  132. civic 97 hx swap questions
  133. Installing Gen 2 Yangson Design Tail lights
  134. Nos
  135. FlashOptions.com?
  136. my brakelights just stopped working
  137. Brake job on a 97 Hyundai Accent
  138. need help with my B16A
  139. Honda Parts in Germany
  140. clicking noise
  141. IDIOT needs help installing first autometer gauge, hurry b4 i electrocute myself
  142. My Car won't start...
  143. Vehicle Brake Information (very long)
  144. B18C1 into a 94 civic si
  145. b18 turbocharged?
  146. ratchet/automatic shifters
  147. torkstep headers
  148. It's Dead !!!
  149. What kinda of mufflers are on the three honda civics in the fast and the furiou
  150. Power Steering Probs
  151. Effect of Snow/Salt...
  152. engine note
  153. Advan Decals For Sale
  154. info on parts...need help.
  155. is AC bad for the engine?
  156. Bomz High Flow CAT
  157. what's the diff btw b18b ls and rs???
  158. Destroked H22
  159. idle problem
  160. Ignition!?
  161. Blown Head Gasket
  162. Automatic to Manual
  163. JDM DC5 Integra Type R SRS Steering Wheel
  164. engine swamp on a junker
  165. Could anyone info me some stuff about cars?
  166. will switching oil types harm?
  167. b18c engine into a 95 Civic CX easily
  168. Help! brake lights on
  169. transmission and clutch install/do's dont's
  170. Ceramic or Stainless Steel??
  171. Perfect spark plug?
  172. Integra front end on civic
  173. b16a torque specs
  174. HELP B16A Engine Problem!!!!!!!!!!!
  175. HELP B16A Engine Problem!!!!!
  176. new alternator
  177. Do I need rear new trailing arms for 5 lug conversion in a 97 Civic?
  178. tranny rebuild
  179. shifter bushings
  180. looking 4 a jdm brown top zc
  181. osakajdmmoters.com?
  182. longblock/shortblock????
  183. looking for a SiR2 engine
  184. muffler
  185. Looking for some 240 info ...
  186. the real problem
  187. oil changes
  188. Pectel T2 ECU pinout
  189. some JDM questions for ya
  190. fuel pump relay problem??
  191. A Newbie's question about the B20 swap
  192. what are blocks and heads?
  193. what are blocks and heads?
  194. HP Racing headers?
  195. Pedals for heel-toe downshifting?
  196. b18c comparison
  197. b18ci swap questions
  198. h22 swap
  199. No start condition 91 civic
  200. crank pulley help
  201. Racing Help!!!
  202. dum-dee-dum-dumm-dummm Q's
  203. Jdm engines wholesaler and distributor www.flashoptions.com *BONUS**
  204. Tranny Help
  205. FS: Skunk 2 Cams (B-Series)
  206. auto tranny to manual tranny
  207. exhaust system; '91 318i
  208. translate into liters?
  209. Engine Help?
  210. more help with a tach retrofit
  211. Which shop do you use?
  212. installing a bodykit
  213. bad a$$ civic 1200 for sale
  214. bad a$$ civic 1200 for sale
  215. flooding an FI car?
  216. 91-92 integra b18 question
  217. Power Steering....Keep it??
  218. Mileage
  219. B16A Headers
  220. B16A Oil Question
  221. Mugen LA-EP3 Civic
  222. 2k2 civic - engine bay problems?
  223. sae on oil lable
  224. high flow cats
  225. any 4th gen accords w/ adjustable cam??
  226. honda engine swap
  227. b16a vs. h22a
  228. new injectors and header...
  229. Exhaust System
  230. Timing belt
  231. Exhaust System Back-Pressure
  232. Any good Install Guide websites?
  233. Engine Knock
  234. Drop in a Small Block Chevy?
  235. Stamping Aluminum Body Panels?
  236. Better Header?
  237. Wanted! b18b LS Motor
  238. nickel hydrogen battery
  239. In the need of ECU
  240. Mendral vs. Crushed exhaust piping! Difference that big?
  241. Wiper Blades
  242. civic 1200 or city turbo
  243. fuel pump 1990 Accord
  244. Side Door..Meet A Pillar
  245. JDM parts
  246. A 92-95 Civic D15b7 engine....D16z6 parts?
  247. 92-95 Civic D15b7 engine....D16z6 parts?
  248. Best engine swap for a 94 accord Lx ?
  249. OBD II Accord distributor codes for H22 swap
  250. Tough VSS Question about Compatability
