View Full Version : Engineering/Technical
  1. please help!
  2. Dash Pad Colors Help
  3. Possible Torque Steer in Chev Truck
  4. no spark?
  5. Apexi TT caused electriacl short???
  6. 1000 HP Mustang Transmission
  7. Yet Another Synthetic Oil Thread
  8. head and gasket advice.. HI RES PICS included
  9. Leaded gas and O2 sensors
  10. Headlight problems
  11. saving a flooded car
  12. poor katrina struck '72 XR-7
  13. engine running without exhaust
  14. 1968 302 (Shelby Q's)
  15. puddle of oily liquid under the car...a fairly big puddle
  16. Brother sniped wrong wire car wont start HELP
  17. manual remote start
  18. What limits the RPM of diesles
  19. Pictures of my chevy pickup
  20. CFM Calucations
  21. water/alky injection in na vehicles
  22. Compression Ratios and their effect on torque
  23. whining help please....
  24. Intake runner length
  25. Octaine equivlent of Nitro Methane
  26. help with mopar #302 heads
  27. When is a used vehicle purchase a certified lemon?
  28. long shot in the dark
  29. Engine block materials...
  30. Headers
  31. Isuzu Rodeo Break lights
  32. Whats the best All Wheel Drive system?
  33. clutch/trany problems 02' Firebird
  34. Rear Brakes
  35. How much and how long?...
  36. help identify gm engine
  37. Fastest Modified Trucks
  38. 99 Silverado CD Player Malfunctions?
  39. '70 hemi cuda
  40. 5 speed automatic - explain
  41. heater core
  42. Low-pitch sound from engine?
  43. hp/liter vs weight of engines
  44. 350 4bolt with 305 tpi heads
  45. Zl1
  46. 84 Saab 900- grinding noise when excellerating
  47. Air Compressor Help
  48. Big Block Chevy Interchange
  49. wanted: dodge charger
  50. Hi
  51. 79 403 olds
  52. New Videos, Bob Glidden, PRI, Snowbird Nats and More
  53. making FWD rotate
  54. 1955 ford f-100 for sale
  55. Sensor/Sending units?
  56. Hydraulic torque mounts
  57. Jim Hand's book, and questions about it
  58. need second opinion on brake force computation
  59. automatic transmission shifters?
  60. parts
  61. Pontiac 350
  62. front mid engine vs FR setup
  63. Static electrical shock eliminators
  64. 99 Silverado Radio/CD ERR message?
  65. piston rings
  66. carb question
  67. Ignition Problem
  68. In the early process of looking for a good project truck
  69. 99 silveraldo
  70. Cabon ceramic engine conponents
  71. Surface to volume ratio and its affect on thermal effecency
  72. Hemi vs. Normal engine
  73. bypassing a/c compressor, 97 caravan
  74. New to Cars
  75. OBDII reading OBD
  76. best non-synthetic oil?
  77. 3-speed shift kit?
  78. frame strength
  79. My car wont start!
  80. Hey, I'm new...
  81. Chevy Luv sign in
  82. 94 firebird formula idle problem
  83. new problem! once again...
  84. Keeping original status
  85. 84 Caprice Starting problems
  86. Air-Driven Automobile Engine
  87. R12 Refrigerant
  88. R12 Refrigerant
  89. fuel line leak D:
  90. 1993 Chyrsler Lebaron LE Unusual Problems
  91. Oil Leakage...
  92. Leaving Truck in the Cold For A Month
  93. mitchell1 eautorepair?
  94. Oil Leak From Crankshaft
  95. anybody heard of A1 auto restoration?
  96. Buy the 76 TA
  97. max cold cranking amps
  98. Slapstick Shifter
  99. Question about airbags
  100. Poor acceleration
  101. aerodynamic efficiency
  102. Electrical problem - '90 Chev K1500
  103. tire chains
  104. To Basic a Question
  105. Aftermarket Guages
  106. a way to calculate torque/power from engine specifications?
  107. Underbody evacuation downforce
  108. Would this have caused any serious damage? (Video)
  109. Remote starter problems
  110. Coolant leak
  111. Silverado Fuel guage
  112. 2001 olds intrigue
  113. freeze plugs wont come out :(
  114. flooring the car? blowing the engine?
  115. I put anti-freeze in my oil tank!
  116. Service Engine Soon light along with speedomoter cable quit working..
  117. direct injection engines
  118. twin turbo foxbody mustang little burnoff
  119. 1955 Ford F-250 rebuild
  120. 1955 Ford F-250 pickup info
  121. Auto Electronics
  122. 1987 Chevy cuts out!?
  123. Advertising Mistake?
  124. EGTs - high from running really rich???
  125. governers...
  126. car wont start - security system??
  127. 1999 jeep wrangler sahara 4x4
  128. CRC Permanent Metallic Block and Radiator Seal???
  129. Fan Override
  130. 94 silverado won't start, please help
  131. 1991 Integra problems
  132. still getting gas in oil
  133. source for 12v switches
  134. problem starting car
  135. Help a girl out...
  136. 69 amx hoses
  137. 1998 chevy pickup not starting but turns over and fires
  138. problem with fuel pres. and boost gauges
  139. HIDs help?
  140. crazy problem
  141. 1990 5.7L Chevy Wont Start
  142. basic car question (wont start, probably the starter)
  143. Car wont start when cold
  144. Onan Pistons
  145. '70 Boss 429 W/O Engine...HELP!!!
  146. The Outlaw preformance products
  147. 2005 honda civic 4 door
  148. Need info. regarding Chevy dually brakes
  149. Dash Panel Lights Remain On - help
  150. 1977 C10
  151. Snow Tires
  152. AC/H control
  153. 2003 vibe gt cold air intake. fitting into a 2003 matrix xr ???
  154. 1961 corvette limited slip gear ratio
  155. knocking 5.3litre engine
  156. off road rigs as daily drivers
  157. Retrofit pre 98 fuel pump in 2000 z71 w/5.3l?
  158. I need help
  159. Differentials
  160. Ignition stuck on acessory
  161. Newb needs engine info
  162. cheap offroading truck. but also gets good gas mileage.
  163. Standard Shift Problems
  164. 302 or 351
  165. Diesel
  166. ?'s about 1st gen firebirds
  167. Street Legal HP
  168. power steering
  169. Increasing efficiency - converting heat?
  170. Buick Regal Knock sensor wire
  171. Features
  172. favorite factory Pontiac rims
  173. can't get my 70 vw bug to idle
  174. 1994 Chev C1500 6.5L Turbo
  175. msd 5462 timing control-need wiring diagram
  176. This Week On Your Way Network 11/20/05
  177. Can anyone tell what kind of car this is???
  178. glove box puzzle- Odyssey
  179. Bouncing rearend
  180. Stripped Screw- Odyssey filter
  181. lost my keys
  182. Drain on battery
  183. Body kit
  184. Low gas milage after replacing fuel filter
  185. I need help bad I have tried ALL!
  186. Anyone need used MICHELIN mxv4 tires?
  187. Hazard Light Button
  188. Must read; Don't buy anything from this guy
  189. Must read; Don't buy anything from this guy
  190. a few newbie Q's not in the pinned thread.
  191. Cheap performance mods?
  192. wanted firebird trans am
  193. Seized Engine???
  194. Intermittent & sudden loss of speedometer-91 Camry V6
  195. 2002 Ford F150 lighting problem
  196. SBC 383 Stroker heads???
  197. Engine temperature behavior
  198. Chev 4WD actuator
  199. A Couple ?'s to pick brains
  200. Driveline Drag
  201. Best/highest quality batery
  202. help please
  203. Should I Sue The Shop?
  204. PC Diagnostic Software - The Basics
  205. gas mileage vs. throttle position
  206. GM/chevelle wheels
  207. Died in interstate traffic and then came back to life
  208. what v8 engines meet up to stock tranny
  209. 65 mustang horn
  210. Questions about 81 amc station wagon
  211. What are the advantages of a Pushrod Suspension over a regular suspension
  212. 2000 dodge minivan spark plug replacement
  213. Valve Covers
  214. Car alarm problem
  215. 71 chevelle in nc
  216. **VIDEOS** Vegas Shootout and SEMA Show
  217. Ford F150 factory installed alarm problem
  218. T-2 Torsen
  219. big block vs. small block
  220. 4x4 milelage
  221. exhaust flame thrower
  222. Self locking nuts
  223. Low differential fluid in Chevy Tahoe.
  224. Curtis I Need your Help..!
  225. B20 block With B18 head
  226. turbine hybrid
  227. '68 Roadrunner-bought it new
  228. Ball joint nut won't tighten
  229. Engine Knock
  230. G2P Fuel System treatment
  231. How do you prevent wheel slipping?
  232. 91 sonoma rear axle swap
  233. Rebuilt Tranny...Will it Hold Up..?
  234. no awd in reverse
  235. I got my bumper painted (99' camry) and sensors keep coming up on the display panel..
  236. Car Problem (Technical)
  237. gas vs. diesel
  238. Overflowing gas tank
  239. Rollaway Tool Box Question
  240. LS1 fuel system set up
  241. Can not find VECI label
  242. Converting a FWD import to Rear wheel drive
  243. I desperately need parts
  244. 1963 Rambler 770 Classic
  245. New Rotors are already rusted
  246. EGR P0405 err mssg.
  247. Car Not Starting
  248. Help!! Intermittent starting problem.
  249. 69 gt torino for sale
  250. no spark help
