View Full Version : Golf
- Turbo, Prob on Gti Turbo 2000 please help
- Died! now wont start
- Lowering My 1993 Vw Golf...
- Turbo my 93 VW GOLF
- 1992 Golf GTI
- wipers problems 97 golf
- help with intake install
- Golf IV 2000 - Half my electrical system just gave up
- Golf MK4 coolant warning
- 97 golf won't start
- service manual for mk3 golf?
- remote for a 96 vw golf gl
- 97 Golf 1.6 GL intermittent starting and stalling
- OBDII Code P1296, new coolant temp sensor right?
- timing belt newbie
- HELP -HVAC lights not working-
- 1995 VW Golf Cabriolet won't start
- removing window cranks
- ECP light
- Passenger Window - little white clips broken
- need help check engine code PO442
- Random oil warning alarm (part 2) :)
- tempermental trunk
- 92 Golf GL wont Fire-up w/out starter fluid
- Reving Issues when starting car
- grime on light covers, what should i do?
- VW Golf 1999 Loss of power problem
- want to paint interior plastics
- Need pics of your gol gti
- mk4 1.4
- Looking For Euro or German Headlights
- 99 golf gearbox issue?
- 92 golf hates humidity
- What oil to use
- priming fuel system on 85 Golf diesel
- Free DIY mods?
- Oil Pan Replacement
- keyless entry
- Will They Fit?
- Catback Exhaust Furies
- Billet grill for a 93 golf.
- Tire Turmoil!
- intermittant high rev stall
- just bought 85 golf, lowbeams not working
- I'll post it again.....
- Will a Supercharger
- 1989 Golf SWAP!!!!!
- Faster car
- Gas Mileage - MKIII Golf
- 96 Golf 1.6cl overheating
- Oil pressure light blinks at a stop
- golf parts on a fox
- engine swap
- Help!
- remote won't lock doors (99 golf GLS)
- Chipping a Golf...
- Euro Bumper doh!
- door swap
- 1997 Golf GTi dies when idling with AC
- Golf III GL Crankshaft/Pulley shaking
- clutch
- golf/rabbit seats
- 97 Golf Alarm/electrical problem
- conversion to manual ingition distributor
- '00 2.0l
- oil leack from the carburettor
- 89 golf
- Noises
- Heater Control on 2000 TDI
- engine chokes in hot weather
- air conditioning plague...im dying in this heat!
- oil....air filter...why?
- Short Shifter help please...
- Radiator fan not working
- Help. How to open gas tank cover(1994 Golf.III-4 door hatchback)
- stereo in 94 golf needs attitude adjustment
- 1992 Golf Diesel
- 97 golf 1.8 does not start.
- im a bigginer
- timing belt
- 94 Golf Daytime running lights stopped working.
- Used Golf
- Newbie
- Air conditioner evaporator drain, 88 Golf
- automatic gearbox
- Intake Issues?!?!?! Argh?
- 2000 golf trouble codes
- VW Golf '99 Brake Lights Not Working!
- 92 Golf wont start
- i have a P1476 P0411???
- Leaks!!! HELP!!!
- Thanks a grip!!
- Golf T plate - no dash/clock illumination?
- mk1 golf cabrio cutting out
- 2000 golf overheating?
- Resurface Rotors?
- Best Cold Air Intake for a 93 golf III
- 1999 Mk IV golf starting problems
- 1987 golf gl stereo wiring diagram
- 96 golf won't start
- VW Golf IV alarm won't disarm & power locks wont work
- occasional stall
- lights-on warning buzzer
- 94 golf cranks wont start
- 2000 GLS 4L tail light lens
- Wet start electrics.
- driving on ice?
- 1996 Golf Oil Light
- ignition timing
- 96 golf starting problem, starter sound but engine doesn't turn
- 2 problems
- wipers
- engine code
- wiper confusion
- VW Golf Oil Consumption
- Golf 4 technichal manual
- Over fueling problems in golf mk3
- Sunroof working intermittently
- Golf 3 Turbo Diesel Stalling
- Chiltons For Sale
- Complicated exhaust question
- Remove window
- Alarm problem Drivers door 1996 Golf
- safe radio
- FS 17 inch flik wasp black with tires
- Loud???
- MKIII muffler
- climate control lights come on intermitently
- Alarm goes off if I leave motor running.
- Cold Air Intake
- Replacing Oil Pump
- Golf stereo
- remove service light
- Golf Auto Trans problems...won't upshift
- Sunroof conversion- power to manual
- Golf
- 96 golf good car ????
- What oil brands can I use with my new TDI?
- Intermittant Seat Belt Light and Clock, trip counter reset on their own!
- engine won't start after rain
- Should I buy - Golf '92?
- 96 Golf overheating!!
- Golf 1.3 H Reg - Another Non-Starter
- 94 Golf 111 won't start when cool,ughhh!
- '86 vw golf gt stalling
- Airbag suspension
- 95 Golf lock problem
- Newbie to AF and an engine stalling problem
- Radio Unlock Code for 1990 Golf
- rear bumper
- Sorry if this is off subject...
- Standard trans,no reverse
- a plethora of questions
- 88 16v golf accelerator
- Stalling problem!
- Cluster Lights
- painting a golf
- Golf mk. 4 V5 egine pics
- How to make a 93 cl faster for cheap?
- 88 16v golf idling problem
- No Headlights, wipers, fan blower!
- 1990 Golf Headlights/ fogs
- Should VW make a new R32?
- Temp light flashing and temp guage not working
- Mk3 Dodgy 12v ignition line due to key switch?!
- vw golf won't fire hellllp please
- possible engine swaps
- Ignition Switch on a 95 Golf
- 2000 Golf Bad Electrical Problems
- 1.8 or 2.0
- Green Lights To Red?
- Golf Crank Seal Replacement
- 1993 Golf stalling
- Help!!!!!!
- 87 Golf 16V idles at 3000RPM!!!
- VR6 idle issue + other question
- 1996 vw golf 1.6 cl
- evaporator install 97 golf
- No Power
- No revs on TDI Golf
- sevice code display
- What's early vs late 99 Golf?
- Fan Belts
- Car horn gone crazy
- heater suddenly blows cold air at running temp
- mk3 golf gti gearstick knob
- head lights
- Door Adjustment
- Golf 1.8 CL 1993 cold start problem
- How do i add another transponder key Mk3 golf/Vento
- Burning Oil////90k maint.
- 1985 vw Golf axle nut size?
- 1996 G3 2.0 16v "WON'T START"
- 85 Golf trans swap with 92 Golf diesel
- 1989 1.3 Mk2 Golf, Cutting out when idling
- Help! Battery Install
- tach wire?
- MK4 Golf GTTDI 115bhp coolant problem
- 97 golf seats
- 2005 Volkswagen Golf GLS TDI
- Golf Mk2 1990 1275cc
- Post your Golf!
- engine swap
- Parting Out 97 MK3
- 1994 Golf question
- lectronic wiring?
- Rpm gauge
- Driver Electric Window not working but all the others are
- removal of steering rack and installation pls help
- cold air intake pipe
- problem with 1st and 2nd speed at first changes
- 94 golf 1.9 match diesel
- Programme key fob Golf VR6 1997
- 91 VW Golf GL won't start! HELP!
- 1993 Golf Gti won't start.
- 1992 Golf - stalls when cold
- Check Out this Twin Turbo R32
- how do you change a rear tail light bulb on a 1996 golf?
- 89 golf rattles/burnt rubber smell
- Door a jar light and the interiors
- New keyless entry transmitter
- Door lock problem
- hesitation in engine/cold air intake installation
- lights and heat
- 94 Golf III stopping when hot
- help..with warning sigals...driver side door
- Golf Driver Heater problems
- Stock speakers?
- Golf electrical mystery
- Reverse Lights
- 95 golf heater motor quit running
- help car won't start at all
- alarm malfunction
- XM Satellite Radio
- how much in germany?
- 2000 Golf engine warning light
- '89 steering rack
- I have a problem with my VR6...
- golf or rabbit?
- Micro switch in driver's door (98 Golf)?
- 98 Golf...Three Beeps? Electrical Problems? WTF?
- 96 won't retain coolant
- Need Chevy windshield in Iraq NOW
- removing battery
- 92 Golf Loses spark
- electrical problems in my 85 Golf
- bad electrical problem
- 98 golf won't start
- Alarm problem
