View Full Version : Grand Prix
- Another Transmission Problem
- 2000 GTP Constant battery Draw
- 1996 grand prix button under dash what is it?
- 96 Grand Prix 3.1 No Start Fuel Pump Relay
- Trasnmission Leak
- heat problem
- 95 Pontiac Grand Prix front struts
- '97 GP GTP starts & stalls after 2 seconds.
- transmission fitting thread
- 1996 serpentine belt change
- 1996 Grand Prix no radio display
- 2000 GTP No Fuel
- Headlights randomly working!?
- racing engine
- Whats the Luck? (always something, sorry for writing a short novel)
- 2000 Gran Prix gt 3.8 L IDLE AND RPM`S JUMPING WHILE PARKED AND WHILE DRIVING
- o2 simulator help
- 02 Windshield Washer Pump Problems
- 98 GTP Im Stumped
- Transmission interchange
- parking brake!
- Alternator Going?
- power steering
- 95 Grand Prix mystery wire
- 95 grand prix 3.1
- 98 Grand Prix GTP gone crazy!!
- Rear suspension sound: Strut mounts?
- 2002 grand prix gtp 3.8 SC. list of problems. need some help
- 95 Grand Prix 3100 hesitation/bucking
- 2000 grand prix oil leak?
- Antifreeze in oil MPG way down?
- Temp. sending unit on 2002 with 3.8
- DIC & Ignition Wiring Diagram
- Oil Level Sensor NO GROUND
- Intermittent stalling
- Power steering hose on 02 GP 3.1
- 1997 grand prix water pump
- PRND321 Lights, Oil Level Light, Temp Gauge
- LED foglight/headlight replacement bulbs?
- stalling
- Name this (cooling system) piece
- engine block heater
- Broken rims
- Window leaking
- '97 Grand Prix loses all power
- how to install sealed beams on 92-96 Grand prix
- It's cold out, and I have a window down. Help?
- 2005 GTP hasitation when accelerating
- Snow Tires
- Fuel door about to fall off
- '95 high idle
- 2000 Grand Prix GT: Did They Install a New Fuel Pump or Just Tell Me They Did?
- Opinions Please
- Overheating & no heat
- gas cap question
- Why is my gas mileage so bad?
- Question about interchanging door locks between two different years? Help
- 97 GTP Window Regulator help????
- 2001 GTP Transmission Trouble
- error code 0446 EVAP vent system
- Where to buy fuel level sending unit?
- Boost = Hesitation
- ABS and Traction control lights on
- No Dash Lights in my '01 Grand Prix
- 2000 GP has growling in the rearend
- 99 Grand Prix acceleration problems
- GP wont start
- Engine cooling light is on-99 Grand Prix GTP
- HELP: Installing aftermarket radio
- Fog Lights
- EGR input voltage low
- 98 GTP SC HELP BNAYLOR! Compound Problem, Temp Gauge, More
- 1997 GP Thermostat
- 1997 pontiac gp front strut removal
- where can I find info on 95 Grand Prix GTPs? every post says 97 and newer..
- Water Deflector For Drivers Side Cowl
- steering wheel radio controls
- how to remove hvac controller
- 2004 GT1 shutoff while driving, no power at all!
- Problem starting 05 GTP
- Gtp engine problems
- NO HVAC speed 5
- creaking window? or door? who knows...
- 1995 Grand Prix GTP: help diagnose oil leak/burning problem?
- UIM torque specs for 2002 with 3800 motor
- help
- 2002 GTP Window Regulator
- what is this?
- whistling sound in the HVAC system
- 1990 Grand prix le problem
- 98 GP GT 3800 na with P0171
- Time to change my water pump!
- no spark to spark plugs
- 2001 GP GT "No Overdrive"
- 97 Grand Prix GTP shutting off/tach problems
- Windshield Repair Pittsburgh Weather
- "Pass-Key" Problem
- 2008 fan control circuit problem
- Front Brake pads replacement
- Heater Core?
- 1997 Grand Prix 2 door window problem
- car dies
- Winter Fuel
- Blower motor resistor
- Extended Life Motor Oil
- Incorrect temp indication?
- 99 grand prix AC problems
- Blower Switch
- compression question
- Headlamp Aiming
- Ported TB?
- overheating problem
- Keyless Entry
- Power Steering Problem
- Traction Control Issue
- Hvac
- Got the P0171...
- pontiac grand prix 1998 water in cylinder
- 1995 grand prix trans issues
- 97gtp stutter at hard throttle
- 2002 Grand prix se acceleration problems
- 01 Grand Prix stalled.
- 01 Front Valve Cover Replacement
- Electrical/Starting Problems
- Hub Assembly
- flare type-brake line to brake line?
- '98 GTP super charger oil
- main window switch
- 1997 grand prix anti-theft system components
- starting problem
- Rust under the fuel filler door 2003
- Cooling System Elbows---AGAIN!
- VERY Hot Dome Light
- how to tell 1st or 2nd design
- 2006 Grand Prix clunking in front end
- Transmission leak and vibration- New bearings, tires, axles
- Gravity Brake Bleeding
- HVAC control unit bulbs
- Keyless Entry Receiver Going Bad?
- Brakes "stutter" on a '99 GTP
- 2002 grand prix 3.1 ses light on code po420
- '99 Grand Prix Caliper Guide Pin Boots
- Front-End Knock - Tie Rods?
- Spark Plugs
- 2001 sudden Transmission issue
- Please help!!!!
- 2004 Grand Prix GT Start up issues
- 2004 GP Heater Hose Bypass
- PCM question
- Window Problem....
- 98 Grand Prix GT 3800 144k miles
- Wipers won't squirt & HVAC won't work
- HELP! 2005 Grand Prix GT ZZP PCM Relearn
- 1998 Grand Prix engine replacement
- code po440
- Grand Prix Rim's
- hvac
- 2006 Grand Prix noises
- 04 pontiac grand prix gt
- Right Turn/Engine Problems
- low pitch noise on left side of front end
- RPM drops on take off
- need to make bubble flare?
- Pulsating / Vibration
- brake pedal to floor-brake light on
- 02 Weird problem
- Cold Air Kit
- '97 Ignition Switch Issue?
- Help!! 2004 Overheating
- 99SE only getting 5v on fuel pump
- 1997 gp front tire play
- Please help!!!!
- LIM gasket metal/plastic
- what coolant
- FM Transmitter/Modulator for MP3 Music
- re-new alternator & need to clear codes?
- i cant find the problem!!!!
- '98 GP SE injectors: different types?
- '98 GP SE tensioner assembly removal
- Brake Fluid Contaminant Containment
- 1989 pontiac gran prix
- questions and concerns
- Brake Hardware Question
- Rim bolt pattern off set
- 2006 Grand Prix overheating
- 93 rear strut and sway bar
- Supercharger Bearings
- Auto-Dim Rear View Mirror Exploded
- Why do I have to shift gears in my automatic trans
- abs and tire pressure lights on
- downpipe
- 2000 GT window issue
- Tire Preasure Light
- 2000 GT...alarm constantly going off
- 2000 grand prix engine problem
- how to remove a/c compressor 01 gtp
- 95 Grand Prix Tranny Sluggish
- 98 GP GT 3.8, AC leaking
- 2004 GP - Steering Wheel Radio Controls
- 1997 gtp hard time picking up speed
- hello newcomer
- Do you know what this part is called?
- NO CODES 95 gp
- Recommended aftermarket keyless entry systems
- Programming Key Fob 2000 Grand Prix SE
- newe exhaust help
- Air on 1 side , heat on other
- PLEASE HELP 2000 Grand Prix steering
- clunking on right during sharp left turns
- 98 Grand Prix GT 2 door 144k with water on the pass floorboard
- Cam Interrupter magnet install???
- Heater/blower runs with key off
- 97' gtp no dash or marker lights
- No idle without acceleration
- Where to get PK3 key cut?
- Remote Start for the GTP
- un-steady idle
- 2001 GP Struts
- Clunking sound when steering wheel is straight (2000 Grand Prix)
- Hard transmission shifting
- What to use to clean engine????
- Ignition key tumbler issue
- Lens Cover for 98 GP (passenger side) headlamp
- Oxygen sensor - Service engine soon light
- Front and Rear Brake Torque Specs
- 2001 GP GT clunking over bumps
- Another power window problem
- SUPERCHARGER OIL ??????s
- Antilock brakes kicking on
- 99'GTP smoke coming from inside valve cover
- Orifice removal-wrench size
- A/C hose replacement
- 2002 GT Grand Prix (BTSI type) electrical problem
- 1995 Grand Prix, will not start.....
- "B" Pillar Exterior Applique Question
- P0753 1-2 Shift Code
- hesitation or hiccup while driving
- SRS air bag light on
- 02 Grand Prix Acceleration Problem
- Front Rotor Replacement
- My Muffler Repair Job
- Intake Manifold Gasket End Seals
- Possible Overheating, AGAIN!
- 04 GP P/S whine
- 2000 GTP suspension / Engine Noise???
- Motor Mount Replacement
- water on floor
- Headlights turn off when A/C turned on.
- 1997 GP GT Trailing arms
