View Full Version : Grand Prix
  1. Supercharger rattle
  2. help 05 grand prix gt
  3. High Idle/Stuck Accelator after Fuel Filter Change
  4. High Idle/Stuck Accelator after Fuel Filter Change
  5. Car Hesitation 1900-2200 RPM (3/4 Gear)
  6. 2004 Grand Prix GTP Comp G - Radio Stuck On Phone
  7. 08 with cylinder 6 misfire
  8. Rack & Pinion problems
  9. Missile spark plug
  10. 2002 pontiac grand prix radio problems
  11. Quick 98 GT Coupe mod question
  12. Battery light coming on. Battery voltage PID at 13.6v
  13. '99 Grand Prix GT starts but dies immediately
  14. Fuse
  15. Transmission Cooler Line Replacement
  16. 2000 GP GT soft brake pedal
  17. Power Steering Leak
  18. Car hesitates while driving normal speeds?
  19. Replacing Ignition Switch: Where is hole to release key cylinder?
  20. Grand Prix rims
  21. Grand Prix series 3 engine
  22. 98 premium sound speakers
  23. 1998 Grand Prix no start
  24. Engine interchange
  25. Brake pedal goes to floor 2001 SE
  26. Resonator Replacement
  27. 04 Grand prix broke dawn
  28. Alternative supercharger oil?
  29. 02 grand prix gt window problem
  30. 2000 GTP wont start after Belt and Pulley snapped
  31. 94 GPX GT: Multiple Codes, First Gear Only, No Reverse.
  32. Pontiac grand prix p0300 code
  33. Do I Need an Alignment?
  34. 98 GTP cruise control won't engagge
  35. 2000 grand prix losing antifreeze
  36. 2000 grand prix gt dic conversion
  37. Hud not working
  38. Starting Problems
  39. vibration in my front end.
  40. 2002 Grand Prix GTP window regulator wrong part?
  41. 08 A/C Vacuum
  42. 2002 grand prix gt water temperture light
  43. Outside Temp
  44. spark plug question
  45. 2002 Pontiac Grand Prix Brake Lights
  46. 99 GTP strut replacement
  47. jane 1964
  48. Hot start problem
  49. How do I tell if my car has variable assist power steering?
  50. Radio Noise in 2004 GP
  51. 2004 Grand Prix GTP Comp G Rear Calipers
  52. Whats wrong with my GP??
  53. SuperCharger oil leaking.
  54. 1997 Grand Prix GT information center lighting issue
  55. Cv axle or transmission clunk?
  56. freeze or roast
  57. Crankshaft Position Sensor
  58. 2000 GP GT lifter problem
  59. holy mackeral
  60. Reduced Engine Power
  61. HVAC vents not changing
  62. 01 Grand Prix engine won't rev past 4000 rpms
  63. 2003 pontiac grand prix gt.
  64. Selling My Grand Prix
  65. reduced engine power
  66. 2002 Pontiac Grand Prix wont continue running after starting
  67. Sending unit seal
  68. 3 Cylinder Misfire/No Service Engine Code
  69. Rear brake noise
  70. 2001 Gran Prix leaking gas
  71. Head Gasket or LIM gasket???? Need Help!!
  72. 2008 GPX stalling
  73. Difference from 07 GXP to 08 GXP?
  74. New caliper bad?
  75. Injector resistance check
  76. Farewell Friends
  77. 2001 GTP Tranny?
  78. Driver information center problems
  79. 98 grand prix fuel pump want run
  80. 98 gtp with 97 motor ?????
  81. trailing arms
  82. 98 Pontiac gtp shifting problems
  83. 2004 Pontiac Grand Prix Parking Brake
  84. Two questions and too much play on CV joint?
  85. Rack and Pinion replacement
  86. 94 3100 MAF question
  87. lower intake leaking
  88. injector o rings
  89. 08 cabin filter replacement
  90. 2000 Pontiac Grand Prix Supercharger not fully boosting.
  91. motor mounts
  92. misfire on cyl 3 and 6
  93. 1993 pontiac grand prix 3.1 still not firing after new coils and crank sensor
  94. Problem after new ignition switch and shudder
  95. Is this safe to drive (pic)
  96. 99 gtp cranks no fire though
  97. Car just dies losses power
  98. Plenum gasket leaking again!
  99. 97 Transmission Problem
  100. Jerky & Choppy Acceleration
  101. Battery Bolts - car won't start
  102. Key release solenoid problem
  103. gm vs ford m90 supercharger differences
  104. Upper radiator hose popped at the radiator side
  105. Wipers work only on fast
  106. 97 gp se auto lights won't turn on?
  107. Swar bar replacement
  108. Transmission just got repaired question
  109. TPS Troubles
  110. Misquoted repair
  111. '00 Gp will crank but not start....
  112. 96 GP 3.4 transmission problems
  113. Windshield Reservoir problem
  114. 2005 Grand Prix GT factory alarm goes off by itself
  115. 2000 Grand Prix Won't start
  116. Low Oil Light On
  117. new way to disable DRL's
  118. Which horn?
  119. trailing arm trouble
  120. 2004 Gran Prix remote start
  121. 1995 grand prix intermittent no-start
  122. coating on wheel?
  123. start problem
  124. Passkey III problem on 2002 Grand Prix SE
  125. General questions on 06 GT and 06 GXP
  126. Cruise control, 3rd break light, horn issue!!
  127. 99 GTP blower and vent problems
  128. Radio back to stock?
  129. New Member
  130. 2002 GT Light and Engine Issues...
  131. Engine pops or misses above 4000 rpm P0404
  132. 1997 GP GT TB gasket
  133. '08 Grand Prix GXP noise after starting
  134. 2008 GP heater only blows lukewarm air
  135. Window Switch
  136. First steering pump now rack, what do you think?
  137. Bad CV Axle/Vibration
  138. Multiple issues with 2001 GP GT
  139. Rear window problem
  140. MAF Sensor
  141. Quick question on changing tensioner pulley
  142. 97 grand prix abs and brake light on!
  143. dash lights
  144. 2001 Grand Prix GT coolant issue
  145. 99' pont. gtp sc 3.8l miserable mpg???
  146. 08 Grand Prix blowing ignition fuse #24
  147. New ALUMINUM Coolant Elbows!!!!
  148. the infamous P0420 code
  149. 2000 Pontiac Grand Prix GTP Question's
  150. 1997 gp overheat
  151. ABS Light On
  152. 1995 Grand Prix cooling fan #1 runs after engine shut down
  153. lower engine mount replacement 3.1 litre
  154. 97 GrandPrix GT noise
  155. 2001 Grand Prix GTP Power Steering Lines
  156. Intermittent overheating
  157. 1997 Grand Prix GT CV axle
  158. 2000 Pontiac grand Prix GT RPM spikes/ and car dies
  159. Engine bogs on takeoff
  160. Air Conditioning stops when car is stopped - 2001 GTP
  161. Car wont start
  162. 2002 gtp electrical issue?
  163. 2003 grand prix se
  164. loud pop and grinding after turning left
  165. loud pop and grinding after turning left
  166. Chrome Door Pillars
  167. Replacing Mass air flow sensor
  168. Vibration with A/C on.
  169. has spark wont start
  170. Rear suspension problem
  171. 2004 Grand Prix GTP
  172. Rack and pinion replacement question
  173. Proportioning Valve Leaking (Left Rear)
  174. 3.4 pulley GTP mod questions
  175. Vacuum Leak
  176. Clunk Disappeared
  177. Won't start after briefly sitting
  178. Lower/upper intake replacement 3800 series 2
  179. Muffler tape?
  180. 2002 grand prix wont pass the emisson
  181. 2002 grand prix wont pass the emisson
  182. blown head gasket..maybe more?
  183. ABS/traction control lights with no cruise control
  184. Synthetic Oil
  185. P0101
  186. 7-year battery?
  187. Leaking fuel line
  188. Inside trunk release doesnt work but fob does
  189. Rushing Water Noise in dash of 07 GP
  190. 2008 GP surging, erratic throttle operation
  191. 2000 Grand Prix GT 3.8L PO174
  192. 91 Pontiac Grand Prix (Popping from throttle body)
  193. Strut mount completely rusted
  194. 97 climate control issues
  195. 2005 gtp lose of brakes
  196. Choosing 97-2003 grand prix
  197. UIM/LIM 99 grand Prix gt
  198. 98 GTP fuel pump relay problems
  199. 2004 GP GT Temp running high
  200. Trying to figure out what codes mean for 97 grand prix service engine light!!!
  201. Steering pump (dealer or aftermarket)?
  202. 08 IAC valve
  203. 2003 Grand Prix throttle sensor question
  204. Hesitant acceleration persists
  205. 2002 digital dic conversion
  206. 98 Grand Prix GT 3.8 Burning Oil
  207. How much freon do I need?
  208. gtp 3800 motor swap
  209. Crankshaft position sensor?
  210. Clunk/Click in reverse
  211. NO blower 2004 GTP
  212. 2002 Pontiac Grand Prix problem need help!
  213. Slow hesitent acceleration
  214. 2000 GTP - metal fuel bundle replacement
  215. Major Oil Leak
  216. Here's one for the Pro's, AC Issue
  217. Orifice Tube r/r
  218. 2002 grand prix gt issue
  219. Won't start when hot
  220. 2002 Grand Prix A/C Troubles
  221. 1997 gp a/c problem
  222. 2000 gtp CV/Trany/unknown issue
  223. Door won't open
  224. Where Can I Find My Engine Specs?
  225. 2001 GTP; Couple of issues...
  226. 2001 Grand Prix GT Rear passenger side lights not working
  227. Losing Dash Power When Turning - 08 Grand Prix
  228. Power steering rack leak
  229. Anyone have performance n handling tips?
  230. Plasti-dipped fascia and grilles. w/ pics
  231. lots of issues!
  232. Car Starts Weakly, After Time Doesn't Start at All
  233. 98 GP GT Bad coolant leak
  234. 02 grand prix half hot half cold
  235. Bad Coolant Temperature Gauge
  236. 2001 grand prix gt 3800
  237. Downshifting issue
  238. A/c debacle
  239. multiple codes and running terrible
  240. How to Test the Coolant Temperature Sensor/Switch
  241. Old re-calls
  242. Temperature in 2002 Grand Prix Rises to 230 F on Cruise
  243. This will stump the experts!!
  244. Replaced Oil Switch/Whining
  245. aftermarket chipped key and remote
  246. New here just lookin for some help.
  247. Starrting Probs
  248. 2001 PONTIAC GRAND PRIX GT Halo headlights flickering!
  249. 02 Grand Prix with stuck key problem
  250. Which Oil Pressure Switch?
