View Full Version : Grand Prix
- rear struts - 98 gtp
- GT keep Stalling for NO particular reasons!!
- 2004 Grand Prix coolant "drain cock"/ petcock
- RKE Trouble...Help
- 95 Steering wheel and exhaust question
- 2006 Pontiac Grand Prix Dual Catback Exhaust Questions
- srs light is on asap help me!!!!
- '05 Grand Prix GTP dies after fueling
- Water in Passenger Side Floorboard
- replacing a horn on a 97 gp gt
- 97 grand prix gt
- Looking For Decals
- 2005 Grand Prix
- Engine Temp & Wiper Issue
- 2007 Grand prix gt supercharger pulleys
- Starting problem...
- what call this?
- Help if you can????
- 1999 Grand Prix won't shift out of first
- Adjusting Mode Knob Doesn't Change Direction of Airflow
- 2000 Grand Prix GTP heated seats
- 98 GTP Tranny Problems!!!!
- sound system
- acceleration backfire on 92 ,3.1
- '01 3.1L se odd vibration at 55mph & higher
- motor mount help plz
- Rear bumper mat?
- 2000 GP door lock solenoid replacement
- Door lock actuator
- 2005 Loose Onstar antenna. Leaks. Help
- 99 GT Digital Dual Climate Control
- A/C temp sensor inside car?
- '02 Grand Prix Starting Problem
- Squeak while turning...
- Headers + Exhaust = Loss in Torque
- Monsoon Stereo question
- poor fuel milage
- Grand Prix 99 Gt 3.8L V6 oil leak
- wheel fastener
- Independence Day!
- 1998 Pontiac GTP
- radiator filled with oil
- 97 Grand Prix ..Info on removing driver/pass seats
- Idle Air Flow Solenoid
- 2002 grand prix blower motor resistor
- mass airflow sensor
- Brown sludge in Coolant, 2004 GTP CompG
- 94 Grand Prix GTP fuse box diagram?
- Cracked enigine block?
- 1988 grand prix gas tank
- 98 GTP - Tranny shift range problem
- bad accident...need help with a few questions.
- 2001 grand prix bad tensioner?
- 97 gtp tranny problem
- 1988 Grand Prix Radio does not work
- Can any of you guys help me out here?
- '04 Grand Prix GT Keyless Entry
- gas smell comming through the vent?
- GTP Questions - Eaton M90 S/C
- Engine Problem
- Keyless Entry Problems
- ABS light on, TRAC off.
- Recharge A/C '99 Intrigue (3.8L)
- 1994 GP SE - A/C charge port? R12 or R134a?
- New KYB's! Rear End is still bouncy?
- 2001 GP GT 3.8 A/C Problem
- Supercharger still good?
- AC problems 98 GT
- 97 Grand Prix GTP Performance Package - Good or bad?
- 97 grand prix super charger
- Heads Up Display (HUD) Problem
- SIR-GM1 Compatibility
- leaking anti-freeze at elbow
- 99 Grand Prix Dual Climate Control Question?
- Radiator problem
- help with finding a decent parts store or site
- insurance rate
- Belt Installation 1997 Grand Prix GTP 3.8 litre supercharged engine
- door panel
- a/c cold on passenger and hot on driver
- 98 gtp steaming
- 88 grand prix acceleration problems
- 1988 grand prix starting problem
- 1998 grand prix climate controll and dashboard gear indicator bulbs blinking
- Removal of Spark Plugs on Rear Side of Engine
- Wheel Bearing
- Intermitent dead battery
- Need 98 Grand Prix Technical Specs
- Blinker out
- Basic starter tips for 1994 SE
- How common are LIM and UIM failures on 97 3800's?
- 97 Grand Prix GTP metal or grinding front sound when let off gas lower speeds?
- 2005 Key FOB programming
- Installing An Prestige alarm in a grand prix
- Front Stabilizer Bar broken
- Weird AC problem
- 1989 Grand Prix stops running intermittently
- 2004 radio question
- 94 Pontiac transmission slipping
- Please Help! I Am Going On A Long Distance Trip!
- function of wires to master cyl. '01 se
- HUD in 2000 Grand Prix GT
- SES Light and Engine Dies With Loud POP
- Need MAF for 1997 GTP !
- 96 GP se - a/c, cooling fan, sensor connection question
- water pump help
- Condensation in Passenger side headlight on 02 GP GTP
- 98 GTP Project - Exhaust Manifold Surprise
- need to re-program keyless entry remote
- 2001 GP GT engine runs very bad
- lowering a grand prix
- Engine Oil, Additives and Filters
- Exhaust Question
- Dumb Question
- Hud?
- Please Help If You Can>>>>>>>>>>>>>
- 98 GTP - Re-use the oil pan gasket?
- Fel-Pro Head Gaskets for 2000 GTP
- Air Conditioning PSI
- ways to trick out an 1986 grand prix
- 94 Grand Prix 2DR Passanger Window and Turn Signal
- Steering wheel noise
- Intermintant Starting
- 97 Grand Prix GTP Bad Gas Mileage HELP!!!
- vent blower motor problem
- 99 GP SE headlights stay on
- cooling fans not coming on
- 1991 grand prix se coupe 3.4 wont start
- Bad Light Switch?????
- Rolled 100,000
- Gabriel Mounts ok with KYB's?
- normal temp.
- Mods for a 97 GTP supercharged
- 2004 GTP gas mileage. I need an answer before I buy
- AC Problems
- clicking noise
- 98 GTP - Motor Mount
- Air Conditioning Head Unit Switch
- Starting problem
- engine noise
- My ac in 97 grand prix
- Window motor replacement
- Transmission Woes?
- location of the mall pgm fuse
- 1998 Grand Prix DIC(Driver Information Center) !HELP!
- I'm A Little Torn
- Cooling fan not coming on
- 97 Grand Prix 3.8L Not SuperCharged, starting then stalling out
- Fuel Gauge Zero Scale 98GT
- 2000 grand prix 3100 ses light on
- Fixing a bad head gasket myself
- 1977 Grand Prix SJ, anyone know where the fuse block is?
- 97 Grand Prix SE 3.8 no start
- Missing? 2001 Pontiac Grand Prix
- 2005 GTP Thermostat
- Chrome Grill for 01 Grand Prix Se
- Supercharger performance packages from 3800 performance.com
- check engine light
- Starting problem
- 99 Grand Prix dies randomly
- Camshaft Position Sensor '98 3100
- 2002 Pontiac Grand Prix Fan and Display Problem
- Cleaning Throttle Body
- Temp guage concern & headlight question
- Can't open Drivers side door
- 2 amp fuse
- P1361
- is this a good buy or not
- 99 GT Stalls/Dies Part Deux
- Use of Torco 20/50 non-synthetic oil
- New Head Unit
- knock sensor
- 2005 pontiac grand prix hesitation
- What size Rims does a Grand Prix SE take?
- Pistons
- Scanner Question
- 2002 GTP Fan Problem
- 98 GTP - Where is #6 bolt? (trans-engine)
- 2000 Pontiac Grand Prix check engine light on P0410 DTC
- Where does this thing go?!?
- 1992 grand prix water leak (throttle body)
- '91 Stalling, Grounds locations???
- 99 GP GT Stalls - Code P0452
- 2002 Grand Prix air bags
- AC and defroster problems
- Aftermarket radio and display help?
- Type of paint..
- rear speaker removal
- radiator r&r in 96 3.1
- A/C Question
- another ABS/TRAC question
- 2000 gtp headlights
- 97 GTP Front Valve Cover Gasket
- MAF fuse?
- Acceleration issue
- 91 Pont GP weird transmission problem
- steering pump problem?
- 5x114.3 bolt pattern
- Valve cover breather
- 95 security light
- Gasoline????
- problem with Climate controll unit
- need help...methanol injection install
- alternator nut
- Grand Prix idle/(cooling?) problems
- Problem Car: Resolved
- Replacing crossover pipe
- Performance Shift?
- Brake Job
- 90 Grand Prix 2door right front left fender
- NEED HELP,Problems with my transmission
- '97 Grand Prix SE Supercharged?
- Window problems in 00 GP
- Problem Car
- Programming 2001 Pontiac Grand Prix GTX Keyless Entry Remote.
- '01 3.1L intermittent missfire
- spark plug gap measurements
- 1997 GTP Fuel Pump
- 2000 grand prix
- EGR Valve
- A/C Working but it's Not dishing
- Question about glasspack on my grand prix
- Spraying
- 2004 Temp Gauge Buttoms out after dealer visit
- Broken MAF with PO102
- How many miles do u think I can get out of my 00 Grand Prix GT?
- turbo kit
- Coolant Temp Sensor Code
- 1988 grand prix wont start
- getting codes for 94 grandprix
- 2002 Grand Prix - Key Stuck
- TORX bit for MAF sensor
- Dampener Pulley removal
- Engine sounding like its a diesel????????????
- 1999 GTP tranny issue
- Friend Just bought a Grand Prix, question
- 98 GP Antenna?
- 2000 daytona GTP VERY rough acceleration
- ecm or not
- Where is this noise coming from?
- in dash dvd
- Fuel Pump Re-installation
- Performance Shift question
- which motor mounts
- 1988 pontiac grand prix spark plugs
- 2000 Grand Prix GTP Surging Idle
- 95 Grand Prix rear strut lower bolts?
- Do I need this?
- 90 and 92 ECM wiring
- Pcm module
