View Full Version : Cougar
- courtesy light problem
- Does my "southern belle" hate Oklahoma?
- 2002 mercury cougar
- 95 Cougar V8 refuses to shift.
- help 02 cougar
- help 02 cougar
- 02 Merc Cougar A/C not working
- Free online repair manual (pdf)
- 2002 Cougar soft Brakes
- Is my upstream O2 sensor bad?
- 97 Cougar
- 99 Mercury cougar
- 99 Cougar not starting
- Mercury Cougar on Overhaulin'
- Question about the seat rail's
- Alternator, battery? Who knows...
- LOOKING FOR fuel rail pressure sensor
- fuel gauge
- 94 cougar wont stop blowing hot air.
- 2001 Cougar 2.0L 4cyl 5speed manual, overheat and more
- 95 cougar air conditioner shuts off
- 1986 cougar no start
- 2001 Mercury Cougar, Coyote 5.0 Swap?
- 1999 Fuel Pressure Sensor / Fuel Rail Sensor
- Cougar not wanting to start
- OMG! Mercury Cougar 2002 35th-AN Edition, and to many near death experiences!
- 00 Tie Rod Questions
- something mak'in oil levels rise
- 2002 Cougar: Air Conditioner puts out very little cool air.
- how reliable is an 01 Mercury Cougar????
- Side mirror
- 96 Cougar win't start when weather cold
- 99 Cougar no A/C
- 1999 mercury cougar 2.5 egr removal
- 2000 cougar headlight fuse blows
- Car trouble- PLEASE help...
- 96 XR7 no heat
- 91 brake light problem
- Fuel guage comes on and off and gets stuck at times
- Suspension probs, need HELP before accident!
- 99 Cougar 5 Speed Shifting Problems-No Gears
- Temperature Gauge Issue
- 87 Merc CougarXR-7
- 99 Merucry Cougar Brake Light Problem
- 92 Cougar a/c compressor
- 2002 Cougar CD says initializing but can't load CD
- new to the game
- MercuryCougar Alt / Battery Charging Problems
- Power drain issues
- Ready to give up! :-( Nobody can fix my Cougar correctly!
- 99 mercury cougar charging problems
- A/C Relay
- Figure this one out!!!!
- 00 Cougar 2.5
- 99 misfires and sputters... need help
- Replace Serpentine Belt 2000 cougar
- 2000 Cougar @ 60 mph
- '96 Cougar XR7
- O2 Sensor Mismatch?
- 2000 mercury cougar- Gas gauge, and other things
- 99 cougar has a miss
- I can't get the brakes on my car to work!
- 2000 cougar ABS & brake light ON
- 1999 Cougar Blinking CEL and Bucking
- 2000 Cougar Automatic v6
- Cougar just stopped running
- 99 cougar window clip
- Engine Coding EGR Insufficient and Too Lean Bank1/2
- Check Engine Light Reset?
- 1995 Cougar XR7 4.6L V8
- 95 Cougar - OBD1 Check Engine Light Codes - Help please
- 99 cougar trans or valve issue?
- 1976 xr7 rear window molding
- 1976 xr7 vin codes
- 95 Cougar - Transmission Problems - Won't Shift into 3rd
- 99 couger
- 99 Cougar Brake and Reverse Light Problem.
- 90 cougar supercharged wont idle
- R&R Automatic Transmission on 2001 cougar
- 99 Cougar, I HATE you! Help...
- 2000 4-cyl Engine won't heat up replaced thermostat!
- 01 Cougar V6 "L" Timing Marks
- 2000 cougar starting issues
- 1999 Cougar Starter and Flywheel
- 1999 cougar issues for me
- can't figure out why the engine still revs even after i put in the clutch.
- replacing ignition switch actuator 96 cougar
- 99 Cougar 4 cyl alternator
- '01 Cougar No Air flow 99% of the time need heat and live in WI
- 1994 Cougar- Overheating Problem(s?)
- Weird P0420 code in 01 Cougar
- 1994 Cougar- Rear Coil Spring Replacement
- 1994 Cougar- Power Antenna
- 1994 Cougar- Odometer Stopped Working
- 1994 Cougar- Tuneup Parts Recommendations?
- Severe starting issues and excessive gas consumtion!!!
- Lookin for a car lift
- 2000 cougar new alt and battery still battery light on
- 1990 Cougar engine swap
- 1992 Mercury Cougar LS changing belts prob
- Hey to all
- 99 cougar v6 problems
- First problem with the cougar
- 1993 cougar front end noise
- 2001 Cougar 2.5L V6 CEL P0401
- Recommendations for a 99 cougar
- Hand brake Issue!!
- 99' cougar silver dash removal?
- 2000 Mercury EGR PROBLEM
- 97 XR7 Acc fuse!!!!! HELP PLEASE
- 2000 Cougar Power Steering Leak
- running out of opitions
- 2000 cougar brake switch. HELP!
- 99 cougar altnator
- 99 cougar just quits driving down the road or will not start
- 99 trans doesn't know what gear to be in
- Replace Intake Manifold Gasket
- 94 Cougar Won't start. Horn Sounds.
- LH Outer Door Handle '97 Cougar Needed
- '97 3.8 Cam Sensor Replacement
- 2000 cougar "Wide Open throttle"" Issu
- carbon fiber vinyls
- Mercury cougar! not sure whats wrong now
- 1994 Cougar no start
- '01 cougar fuel injector replacement?
- 99 cougar auto transmission problem
- Warning Chime wont shut off
- 99 Mercury Cougar brake lights not working
- '00' cougar 5-speed lost 2nd & 4th gear
- 99 cougar check engine light code p0155 oxygen sensor?
- 1996 3.8 hard starting
- 95 Cougar upper control arm bolt
- 99 cougar 5 speed hard to shift into gears
- Pulling Heads On A 1995 Cougar 4.6
- 1994 Cougar irradic oil pressure readings
- Front brake problem
- Trans Am Racing Series
- Hoses keep blowing off or rupturing
- 1999 Cougar - Odd Vibration
- brake light
- 2000 Mercury Cougar - P0401
- unknown electrical issue 97 4.6
- Blower in 1991 Mercury Cougar Stopped Working
- my 97 xr7
- 1997 XR7 AC Low Pressure Port Location?
- 1994 idle drops
- 94 Cougar / sensors / fan
- pos 95 cougar need help
- 95 Cougar V.8 front end squeaks
- 1999 Mercury Cougar ABS Fuse-Help!
- ball joint? tie rod? HELP!
- 94 Cougar Moonroof not responding
- 97 Cougar 4.6 has major problems
- 99 Cougar Alarm issues!!!! Help
- 2000 Cougar, several problems
- Coil Packs 97 cougar 4.6 v 8 What?
- Overheating '67 Cat
- Cougar Won't rotate
- 96 Cougar V 8
- 96 Cougar, need major help!!
- 2000 cougar dies in idle!
- 2002 Fuel Filter Replacing?
- 2000 cougar ***no airflow inside***
- Foglights, thieves etc.
- 1996 cougar
- 99 Cougar P0174,P0442,P1744
- Should I consider?
- '00 COUGAR removing dash
- 4.6 to 5.0 eng swap 96 cougar
- codes P1131 P1151 and P0171
- still having problems!!!!!
- spark plug wires
- 2000 cougar cd changer help
- Help! car trouble with 2001 couger!!!
- 200 Cougar will not rev past 4500 rpm
- dtc's wont clear could my pcm need a flash update?
- Rough Idle
- 99 Cougar dtc's p0174 p0171 p0420 tested and replaced parts but no luck.Help!
- 1988 Cougar LS - MYSTERY PROBLEM
- quits during highway driving
- Replacing Dashboard Lights
- 99' 2.5L cougar codes, help needed.
- '67 Turn signal flasher location help
- 2000 Cougar will not start
- 1999 Cougar Parking Brake problems and bumper repair information
- 99 cougar problems need help !!!
- 2000 7.5a alternator fuse blowing
- 97 XR7 Swap ??
- 90 cougar 3 questions
- 93 coug dies when idle
- 94 Cougar bogging/slow to kickdown
- 99 cougar tail lights
- would like to know 2000 cougar
- need help w/ replacing EGR valve
- 94 Cougar 4.6 Please Help!! Starting/running issue
- Brake Upgrade
- 2000 Mercury Cougar Charging problems
- Climate Control Knobs
- Headlight adjustment
- 99 Cougar...I Need Help
- 99 cougar loosing power over 80k
- Head lights
- Transmission Shifting Problems
- Just had alternator replaced. some symptoms ..
- Starting Problems 2001 Cougar...
- 96 cougar air temp sensor
- 5 Speed Conversion
- Simple problem. can't change brake light bulb on 99 cougar
- "96 XR7 How to remove passenger door panel
- 6th gen hood won't open/hiss under the hood
- Wierd question: can a broke gas cap cause the car to die?
- New clutch?
- 1996 Cougar "Possibly buying"
- 87 cougar electronic instrument panel not working
- 99 mercury cougar won't start but
- 2002 Cougar, rough idle, stuttering when defrosting
- 2001 cougar just crapped out
- Signal & Brake Lights
- 01 cougar dash
- 95 Cougar 4.6 V8 - Where is the reset on the fuel pump?
- air fan
- 2K Cougar fuse location behind engine?
- what kind/weight of oil to use?
- 1999 coug' single headlight not working..
- 2000 cougar...a couple of problems.
- !997 Anniversary Edition Cougar
- 99 cougar no o/d, skips 2nd gear, transaxle light
- 2002 Mercury Cougar Problem's.. Please Help
- Speedometer
- 00' Cougar...where to start!
- looking to get a cougar
- 85 cougar loss of power
- 94 Cougar 4.6L (Running Rough)
- 02 Cougar
- Overheating 200 Mercury Cougar
- 99 Fans will not come on
- 1992 Cougar A/C Clutch
- tailshaft housing needed for 92 Cougar
- 99 cougar batt. and alt. help
- '97 Mercury Cougar #1 Cyl Missfire
- '85 Cougar 3.8L - Needs a Good Home
- Confused and Frustrated
- 1999 Cougar starter removal help.
- 99 Mercury Cougar Shift linkage?
- Cougar loud Knock when first starting HARD in Forward/Reverse
- 2000 Cougar 2.5 Power Steering Pump
