View Full Version : Storm
- Geo Storm Question
- Now what?
- Engineering, Mathematics, Design, Calculus, Chemistry, Physics, Mechatronics, Thermodynamics, System, Analysis
- Erratic rpm's
- I need to confirm a problem
- 92 storm hard starting
- What is a Geo Storm
- no spark?
- Why would my IAC be running all the time on my 93 Geo Storm
- Radiator hose issues
- Backfiring in the TBI
- How Many miles on your storm?
- Spark Plug problem
- Removing crankshaft pulley
- New 1990 Storm Owner, with one problem...
- Help! My heater smells like pee!
- 1991 Storm 1.6L Starting and Running Problems
- cylinder missfire
- Compatible A/C Receiver/Driers?
- Timing belt issues
- First Car!
- new storm owner
- "INT RES" light on dash?
- trany swap
- Want to buy engine or parts!
- rear hatchback wagon style
- 1993 Geo Storm Hub Assembly
- 93 Geo Storm no spark
- 1990 geo storm torque,valve lash,belt mks
- AIT plug
- '93 Storm OH issue - I give up
- The TRUE Value
- general
- Geo storm running rough
- Upgrades for my Geo Storm
- 1991 Geo Storm Radio Wiring Diagram
- 1991 Geo Storm won't stay running
- How to remove fitting on end of power steering line? 1991 Geo Storm 2+2
- Power to the compressor
- Geo Storm air intake hose help!!!!
- Starting Problems!!!
- squeak squeak
- Engine in a Geo?
- goe storm question
- light blue smoke
- 91 Storm - Engine Dies Everytime I Stop
- 1993 Geo Storm1.6 sputtering
- Does anyone have the Storm Haynes manual?
- Can a Storm tow anything?
- 93 storm RADIO DOES NOT TURN OFF WHEN KEY IS REMOVED
- 91 Geo Storm GSi, key won't turn at all
- grinding noise when shifting into third gear
- How do i put rear mount on???
- 1991 Storm ECM
- 91 storm gsi 1.6 dohc start problems
- 93' Storm Tuneup?
- 1990 geo storm
- Serpintine belt tensioner 1.8 DOHC
- geo storm clutch
- this one worth checking out?
- Geo Storm and it's kit!
- wtb: black manual shift knob
- to buy a Storm GSi or not to buy?
- geo bogging down
- stereo install
- Water pump replacement
- Check This Out
- Knocking
- transmission
- car keep over heating help
- '90' Starter Problems
- wiring codes for car stereo (HELP )
- 1.6 - 1.8 swap.
- bent valves???
- transaxle swap need info.???
- DOHC for sale? / swap question.
- Tranny Fluid POURING out!!
- '90 GSi Japanese Throttle Body?
- Serpentine belt tensioner for 1.8 DOHC
- Intermittent Problem
- Losing Oil
- Dumb high beam headlight question
- hood scoop on geo storm gsi?
- 92 storm for sale
- Update on Transmission
- A/T Transmission Help need ?!?!?
- FOR Sale 1990 Geo Storm GSI
- warped head...or not??
- How can I read engine codes?
- Fixing shifter boot.
- Front Suspension?
- computer plug in for my 1990 geo storm
- chech engine light
- Have to pump pedal to start
- Need help repairing 1991 Geo Storm
- having trouble finding parts
- Replacing pickup coil
- 92 Geo Storm Gsi 5speed 1.8
- 1992 Geo Storm 2dr Hatchback?
- 93 Storm Freeze Plug
- 93 Geo Storm Block Heater & Manual Transmission
- 91 Isuzu Impulse RS AWD TURBO in GA FOR SALE
- Does a '92 GEO Storm Have a OBD computer?
- 93 Asuna Sunfire Ignition Control Module
- 93 Storm Gsi Shifting problems.
- 91 storm for sale
- Cantankerous 91 Storm
- 92 GEO Storm rear view mirror
- 91 storm..... engine dies
- 93 Asuna Sunfire Signal Problems
- removing door panel
- What do I do now??????
- Stereo wiring
- 1993 geo storm 1.6 clutch ?
- wow!!!!! cute car , no go....
- I Need Help Finding A Manifold
- Female DESPERATE for help fixing a 1990 Geo Storm...
- 91 Geo Storm 170,000 miles worth?
- 93 Storm No Spark
- 93 Storm - Changing Drive Axles
- NEED GLASS & BEARING PLZ HELP!!!!!!!!!!
- '91 Storm low-beam headlight blown!
- 93 Asuna Sunfire for sale(Canada)
- gas
- had 2 geos
- impulse turbo?
- Can't get alternator out
- Hard to start until warm
- want more power?
- Unable To Get Timing Right
- NE1 need gsi fogs and corner lights?
- 92 GSi too much pressure
- 92 storm coolant issues
- 90 Geo Storm ROugh Idling
- Don;t know what else to do
- manual transmition question
- 91 storm wont start
- Geo Storm Kit
- Selling or trading my 90 Storm G2/Solo II/Rally-x car
- 92' Geo Storm Ignition
- My 91 Storm Turbo
- egr valve on a 91 storm gsi dohc
- Blown Head Gasket...Female needs help
- Help with gas milage
- Clicking noise from rear suspension
- GEO Storm 1.6L SOHC -- More than 1 design?
- trying to make my geo an AWD
- Storm Looses power after warming up
- Horrible Gas Mileage
- u/s light
- Stereo wiring diagram - colors?!
- Bose System in 2003 Yukon
- Need wiring diagrams
- help with stalling
- geo storm crankshaft bolt
- what would happen??
- Factory Service manuel
- Help!!!!!!!!!!!!
- trying to figure out a name of a part
- Type R?
- Desperate
- 92 geo storm for sale
- Why did you buy this car?
- 90 geo storm hatchback needs help quick!
- Owner's Manual/Parts for '92 Storm
- Lost my fire
- Installing a GEO Storm Dashboard
- female has questions.....
- OisinT you are one sick individual
