View Full Version : Sonata
- What should I do with my Hyundai Sonata
- Multi-point inspection OEM after warranty work???
- Don't Know Nothin'
- 2008 Sonata 2.4L - Back Probe Crank Position Sensor
- 2008 Sonata 2.4L vs Sonata 2010 2.4L Synthetic Oil Now Recommended
- 2003 sonata oil leak HELP!!!
- Is it electrical?
- Is it electrical?
- Is this normal?
- Change 18" wheels to 16" wheels
- Hi, need pigtail off intake position sensor 2017 Hyundai Sonata Se
- 2015 Sonata Sport 2.0T Slide Whistle Sound from engine
- 2017 Hyundai Sonata SE low-beam on driver's side not working
- 2013 Sonata 2.4 Bank 1 Sensor 2 Repair Notes
- Transmission repair
- 2011 Sonata Limited Engine Light
- P0011 code
- rear wheel bearings
- Hyundai sonata
- 2013 Sonata Keyless Entry acting strange
- Sonata Key will not turn
- 1997 Sonata 3.0gls v6 stuck in reverse on dash..no start..
- Dtc p0713 transmission fluid temp sensor a ckt high input
- 2010 Brake Fluid Type - DOT3 or DOT4?
- engine trouble code 320
- Hyundai sonata help ):
- TPMS malfunction
- OBD Code reader seems to show "0" too quick?
- Symbol lit on dash not in manual
- 2009 Sonata transaxle valve body cover leak
- 04 sonata p0452
- Sonata Headlamp H11b vs H11
- 2010 dtl
- Automatic head lamps
- Dealership Leaves Radiator Cap Off
- engine oil 2007 2.4L
- Air bags
- 2008 Sonata Aux Cord Install, Very quiet
- 2005 sonata
- Hyundai 2.0t 2014
- PO441 code
- Thumping noise while driving
- Removing center console on a 2003 Sonata
- 2003 Sonata repair manual
- 2013 Hyundai Sonata brake problem
- Voltage drops in my 2006 Sonata
- Charging Issue!!
- 2006 Sonata intermittent starting problem
- 2002 Sonata Dies at Stop
- Drowned Sonata
- 2000 sonata 6cyl running hot
- new purchase
- 3 monitors not ready
- Sonata 2012 - Brake Job - What the heck with the rear brakes !?!
- who can help my car ?
- Starter problem....
- brake chatter
- 2007 Sonata Repair Manual
- 2003 Hyundai Sonata Wiper Assembly Problem.
- 2005 sonata
- Service Manual
- 2005 sonata abs light
- 2006 Sonata Check Engine Light & ESC Off Light on
- 2006 Sonata Error Code P0346
- 2006 Sonata won't start, Cam Sensor Problem
- Dumb question? 2000 Sonata 2.4L
- 2005 sonata noise
- '00 2.4L Motor Gremlins
- 2007 Sonata GLS battery info?
- 2007 Hyundai Sonata Check Engine Flashing and Car Shaking At Times
- 2002 Sonata - Electrical
- Strange fueling issue.
- Looking at buying an 06 sonata, what to look for
- 04 sonata timing belt
- Items behind storage compartment
- 03 Sonata 2.4 AT 161K miles A bad idle
- Bought my First Car...Sonata
- 2011 Sonata SE Bluetooth problem
- Paint flaking on bumper
- Ignition coil
- 2011 Hyundai Sonata SE 2.4L
- 08 Sonata - Getting 15 MPG!?!
- 2005 sonata
- swamped sonata
- Changing transmisson in 2006 Sonata
- Starting issue after gas fill up
- Could missing fuel neck flapper cause engine check light to come on?
- 2005 sonata harsh shift 2-3
- 2011 Limited Turbo
- Help!Help!!Help!!!
- Can someone help me?
- Please your feedback buying a 2011 Sonata
- CES 2011 - Hyundai Announces Blue Link for Sonata
- 2001 Sonata - Alarm preventing it from starting...ideas ?
- 2001 Sonata - computer sensor is not reading power train
- Ordered months ago....waiting still! Dealer BS ???
- 2011 Sonata
- transmission probl.
- 04 Sonata cd player problems
- Just bought an '11 Sonata SE
- 2005 sonata trany fluid
- 2.7 engine removal
- 2006 sonata air question
- Starting Problem
- To buy or not to buy?
- Sonata or Altima
- 2006 sonata won't start
- Bizzare Radio Problem; suspect UFOs?
- Any luck with damaged cars?
- 2011 Sonata GLS
- manifold gauge readings
- 09-Sonata, Fuel Tank Air Filter Replacement
- '02 GLS, MIL light is on but no trouble codes. Also, any other cars to swap parts?
- 99 Sonata- Camshaft broke TWICE?
- 2006 Sonata Remote programing
- 96 sonata gl parts help
- 01 sonata rattling window
- 06 Sonata Wiper Motor Replacement
- brake info
- 1999 GLS Sonata rear brakes
- Alarm help
- 2000 Sonata V6 front crankshaft seal
- front bearing - new or junkyard replacement?
- 2008 sonata accelerates unexpectily
- 2000 sonata transmission and check engine
- 2003 V6 Sonata sounds like a diesel
- 06 Sonata hood release
- 2005 Sonata transmission fluid was gone
- 02 sonata GLS Code P0441
- 05 Sonata cut out
- 03 Hyundai Sonata things to look for?
- 2000 Sonata will not start!! Have spark and Fuel
- 2007 Sonata
- Hyundai, Struts and tranny 09
- 2005 sonata noise rear pass. side
- Sonata Surpentine Belt
- 2005 Sonata stalling after fill up
- Sonata MPG indicator
- 06 Sonata transmission issue
- 2005 sonata 2.4 noise
- 2005 sonata 2.4 need to change spark plugs
- 01 Sonata Engine Stopped while in Motion
- Where is the fuel pump relay 95 Sonata?
- Throttle Position Sensor bad on 2006 Sonata
- cigarette lighter not hot when ignition key removed
- Sonata Lawsuit
- keyless entry
- B1382 Airbag code 2003 Sonata
- 04 Sonata weird electrical problems
- Good Price for a 2004 sonata?
- 05 Sonata Timing Belt
- 2000 2.4l Sonata code po304 failed inspection
- 2004 Sonata electric mirrors stopped working
- 2004 Sonata Radio...FM stations not working
- 2000 Sonata air bag, fuel pump question
- 2004 Sonata When do I change timing belt?
- Purchase 2004 Sonata roof rack and ski rack
- Need diagnostic help or referral link
- 2007 sonata
- Programming 2004 Sonata keyless remote
- High Idle Speed
- Battery Prob?
- How many miles on an '04 Sonata 2.4L?
- 2000 Sonata 2.4 serpentine belt changing
- 2005 sonata v6 stalls
- 2002 6 Cyl Sonata Serpentine Belt
- Hard to Close and Lock Trunk
- Grinding Breaks
- does anyone even answer these posts>?
- 2004 Sonata eating head lights and rotors
- Rear brake pads
- 2000 running on 3 cylinders
- automatic lock module location
- 2000 Sonata v6 p0430 code
- 04 sonata engine stalling on reverse and other...
- 2000 Sonata check engine
- Cam Plugs/seals on a 98 sonata?
- 2000 sonata problems
- 02 sonata charging issues
- Can't get old license plates off
- Noise when startting on a cold morning
- acednm
- Car A/C Problem of Sonata GLS 2000
- 2004 Sonata slows down in the rain
- 06 Sonata 3.3 PO504 Help
- 06 4 cylinder a/t opinions=
- mantaning speed
- 1998/Right tail lights OK left side no voltage.
- 2006 GLS V6 - Noisy Lifters?
- 2002 Sonata Alarm system issue
- 04 sonata performance
- 02 Tail lights
- 2004 Hyundai Sonata Starting Issue
- Ongoing mystery lurching, check engine
- 07 Sonata keyless
- 2000 Sonata pings! a lot! any help?
- Thanx biigpuker. you were correct about sensor.
- 3.0 engine timing belt question
- keyless entry not working
- P.o.s>>>>help
- I can't unlock the drivers door???
- Oil Burning??
- '07 Sonata auto trans shift points
- If you have a 2005 Hyundai Sonata, do you have water in your trunk
- 2000 Sonata seems to loose power when the ac is on
- 2006 Sonata front rotors
- 2006 sonata wont start
- 2002 Sonata stalls after start
- 2006 Sonata Keyless Entry Programming
- 2000 Sonata downshifts and dies after 10 minutes of driving
- 99 sonata "no power...gas line???"
- Car Does not Want to Change Gears
- License Plate Light - 2000 Sonata GLS
- 2002 Sonata Roof Lights
- Dud 2006 Sonata
- D.I.Y. suspension mods for '08 Ltd
- 2008 vs. 2009 Sonata Ltd V6
- 2004 sonata hyundai-tail lites out
- '02 Front Hub Bearing
- Location of junction box
- bad mileage
- Starter not working properly 93 Sonata
- Mystery Oil Leak
- Oil leak
- How Do I Loosen the Front Caliper Bolts on 2000 Sonata 2.5?
- 2002 sonata
- 2002 Sonata - Radio is out !!!!!
- Hyundai Parts Personnel
- Oil Leak Update
- Oil leak
- Fuel filler door latch will not stay closed
- 2006 Hyundai Sonata Trunk Shocks?
- 06 sonata V6 burning smell
- '06-'08 Sonata suspension mods...
- 92 sonata - broken speedometer and odometer..
- 04 sonata seat belt problem
- 95 Sonata OBD1
- starting problems
- Calipers
- Gas cap
- help! with sonata stereo wiring
- no dash/console lights in 1999 sonata
- Hyundai Lubricants
- 2005 Sonata accelerating on its own.....
- 2000 GLS Input speed sensor
- Timing Belt Question - Hyundai Sonata 2004
- code p0720 problem, need car
- 1999 V-6 GLS Sonata coolant sensor
- Sonata Hard Starts then Pings then No Problem
- Hyundai 2000 code P0171
