View Full Version : Sonata
Pages : 1 [2] 3
  1. serpentine belt diagram
  2. 2007 Sonata Steering Wheel Radio Controls.
  3. How do I change the thermostat?
  4. Keyless Entry Programming Code Needed
  5. 1995 sonata keyless entry programming?
  6. Lost key and keyless remote
  7. V-6 A/C replacment procedure?
  8. 2006 Sonata high mount brake light
  9. 2005 Sonata A/C Won't Work w/Remote Starter
  10. Build Date
  11. Keyless entry question
  12. 2000 Sonata - 2.4 L - O2 Sensor
  13. Shake rattle and roll
  14. Brake Chatter
  15. Where is the injection fuel???(show me pic)
  16. Help me in 2002 sonata gls 2.0
  17. blinking light sencor
  18. 2000 Sonata stuck gears
  19. 2000 Sonata - Ignition after gas fill-up
  20. Engine head crack...
  21. Help
  22. Side marker lights
  23. hello guys new here
  24. 1999 sonata (how do i take the serpentine belt off) i need help asap! please!
  25. 2006 Sonata will not start!!!!!!!
  26. Firing order for a 2004 Hyundai Sonata V6
  27. Misfire Cold Start 02 V6 Sonata
  28. 06 Sonata Horn Location
  29. starter
  30. Front pass. side window
  31. 2002 troubleshooting feedback
  32. CD player stopped working on 99 Sonata
  33. no start on 06 sonata
  34. 2001 sonata air bag light issue
  35. Window Problem
  36. 2002 Sonata 4 cyl. Timing Belt/Missing Teeth....
  37. 06 sonata noisy front suspension
  38. sonata 2.0l fuel pressure regulator
  39. 99 Sonata / Connecticut Emissions vs Computer
  40. Alternator Removal on a 00' V6
  41. Problems with Engine Immobilizer/Anti-Theft Device...car won't start!
  42. 2002 Sonata 4 cyl. no.3 spark plug wire, no spark?
  43. Sonata Camshaft Position A Sensor replaced, won't start....
  44. 2002 Sonata 4 cyl. OBD II CODE P0340 Camshaft Sensor A....Help....
  45. 2002 Sonata 4 cyl. Yellow Error Lite On, Won't Start....Help!
  46. 2002 Sonata V6 GLS Rapid Accel/Decel Problem
  47. 2005 Sonata, Noisey Lifters
  48. Supercharger 3.3L anyone??????
  49. Quality,satisfaction, ????????
  50. '07 Sonata Lights (Part Numbers)
  51. ABS light on intermittently / loose screws on trim
  52. 93 horn location/probs
  53. What Fram Oil Filter for a '06 Sonata V6?
  54. Sonata 2000 V6 Engine Swap
  55. Alarm Acting up
  56. Mass Airflow Sensor
  57. 2003 Sonata. Dashboard Battery Light on?
  58. How do you reset the computer in a 2001 hyundai sonata
  59. Headlight fuse? there is one, right?
  60. 2006 hyundai sonata 3.3 litre oil filter
  61. 2007 Sonata Dash Removal
  62. crank sensor location on 01 sonatat
  63. Need to change a tranny
  64. cams for the sonata 06 2.4L
  65. first time sonata owner were are the mods?
  66. 96 sonata starting probl.
  67. O2 Sensor
  68. alarm shutoff
  69. a/c problems
  70. Is A 2003 Sonata really that good
  71. engine noise
  72. Swappable Engines?
  73. How many miles on your Sonata?
  74. 2002 sonata transmission woes
  75. strange power loss on a 06 hyundai sonata
  76. 99 Sonata console removal
  77. 05 Sonata radio issue
  78. 2001 Sonata 4-cyl Engine Swap
  79. Need urgent help with our sonata
  80. 2001 gls V6 idle eccelerates to 3000 rpms while in park
  81. battery cable 2003
  82. Stuck shift lever
  83. What's Up With The Service Upgrades?
  84. What's So Special About Battery?
  85. STUDIE bodykit
  86. 2002 2.4L engine vibration problems
  87. really weird problem
  88. 'o6 sonata gls keyless entry
  89. Phantom Horn Honker
  90. ECT Switch on 98 sonata
  91. Having some issues with our sonata
  92. sonata 2002 fuel filter location
  93. Loud Humming at Rear Wheels in my 01
  94. What weight oil do you use?
  95. 2003 Sonata Stalling
  96. 2000 Hyundai Sonata Wiper motor
  97. 2006 sonata headlight replacement
  98. 99 Sonata radio replacement
  99. 98 sonata gl
  100. Disable 2006 seat belt chime?
  101. Car Idle Speed?
  102. Overheating '99
  103. 1999 Sonata V6 timing belt
  104. '06 Sonata Fuel Efficiency Changing
  105. New 06 Sonata LX-price?
  106. Check Error Codes
  107. 2000 Hyndai Sonata V6 Sluggish Acc. High RPMs
  108. wiring diagram
  109. serpintine belt
  110. 2006 Sonata Door Leak
  111. 2006 Sonata Overheating problems
  112. Engine Whine
  113. 06 LX noisy tires suspension
  114. Sonata Battery Light Dash On...
  115. TCM location
  116. 95 sonata radio reset code
  117. 2005 window eching mystery
  118. Sonata Alternator Removal...
  119. 2002 Hyundai Sonata Start/Alarm Shutdown.
  120. Water leak in my trunk
  121. '05 Sonata Issue - Please HELP!!!!
  122. strange power loss
  123. 1999 sonata v6 spark plugs
  124. Belt Noise
  125. Next Gen Sonata Quality
  126. '07 Sonata release date???
  127. remote entry
  128. Speedo and Cruise stops workin
  129. programing remote entry?
  130. 99 V6 serpentine belt replacement
  131. need for a steering wheel airbag cover
  132. service costs
  133. When is the best time in December '05 to buy an '06 Sonata GLS V6?
  134. Disable AC with defroster
  135. 06 Sonata GL dash lights?
  136. Questions
  137. My 2005 Sonata sounds like a diesel
  138. Automatic Transmission Shifting Problems
  139. Car Hesitates/Bucks when accelerating and switching gears.
  140. Car stalls on its own, seems like the power trail is in trouble... PLEASE HELP
  141. Cassette won't eject error code Er8
  142. How to replace a Crankshaft positioning Sensor in a 1999 Sonata
  143. Pistons swapping cylinders???
  144. High Idle for Sonata'97
  145. WTB 1999 Sonata Headlight
  146. anyone have a 2006 Sonata?
  147. A/C Problems
  148. 2005 sonata keyless entry programming
  149. Fuel injector plug
  150. 1999 sonata 2.5l crankshaft sencor code help
  151. reset computer
  152. 2005 sonata power loss
  153. 99 gls rear suspension
  154. Battery / Computer / Sunroof Problems
  155. Can't believe fixing brakes could be so costly!
  156. How bad are the 96 Sonatas?
  157. radio static on am when car running
  158. data link
  159. Sonata Lubrication points
  160. 2000 v6 hyundai Sonata Computer Problems
  161. 2000 v6 sonata
  162. 2000 Sonata "mysterious massive power loss"
  163. 2006 Sonata LX Questions
  164. 06 seatbelt chime reprogram?
  165. Timing belt went then the valve bent?
  166. 2000 Sonata - Erratic Acceleration
  167. check engine light 'ON'
  168. dashboard troubles
  169. sonata 01 gls, bucket seat
  170. The exteior features of Hyundai Sonata
  171. gls power seat stopped
  172. 4th gen gls v6 brake light in cluster
  173. sonata performance
  174. 2000 Sonata Will Not Start
  175. Car won't start
  176. No air
  177. Do Sonatas look like the Lexus GS series cars?
  178. 2002 Taillight Change
  179. Center console (fascia) removal
  180. 2002 Hyundai Sonata Spark Plugs
  181. Just Test Drove the 06
  182. 2000 Spark Plug Replacement
  183. hyundai sonata transmission
  184. 93 sonata idle problems
  185. 02 sonata engine light
  186. check engine light ( code P0715)
  187. check engine light ( code P0715)
  188. 2003 sonata remote
  189. AC Refrigerant
  190. EGR Valve
  191. Washer fluid pump
  192. 01 Sonata problems
  193. check engine light on
  194. weird noise from power steering
  195. Need info for serpentine belt replacement
  196. '06 Sonata at dealers now!!!
  197. 98 sonata firewall hole for amp. install
  198. check engine light comes on
  199. air bag light is on
  200. 1995 Sonata
  201. Nebie
  202. outside door handles
  203. 97 Hyundai Sonata front window will not go up??
  204. Sonata transmission overdrive
  205. How to Remove Roof Rack? 2004 Sonata
  206. What oil do you use?
  207. Dot 5 brake fluid
  208. Rear left disc brake problem
  209. Steering Lock
  210. 01 Gls V6
  211. axle nut torque
  212. Buy a new Sonata
  213. Subwoofer Install
  214. New Air Intake
  215. Drivers seat belt
  216. Transmission numbers
  217. Engine Mount/Trans right side
  218. Need help fast
  219. Engine/Electrical Problems 1995 Hyundai Sonata
  220. Front Brake pads on a 1998 Sonata
  221. last 6 digits missing in VIN#?
  222. question about timimg?
  223. Installing new Head Unit
  224. 2000 sonata 2.4L (Bad engine)
  225. locked out of trunk 2000 sonata
  226. Dome Light
  227. New sound system install
  228. Keyless Entry
  229. How do you remove the alternator from a 95 sonata gls?
  230. 99 Sonata GLS - Looking to buy one
  231. Upper Control Arm
  232. Remote battery
  233. clarion radio warranty - 2002 sonata gls
  234. Register or Insurance
  235. 2000 Sonata GLS Spark Plugs
  236. 1999 Sonata question thinking to buy
  237. Hyundai..has lifters off..can I just popped them back on!
  238. 2006 Sonata
  239. changing spark plugs on the sonata 2.4v
  240. Hyundai Sonata,1997, has oil coming out of tail pipe
  241. 1990 Sonata GLS - Need Fuse Diagram
  242. Cigeratte outlet and 12 volt outlet
  243. buy 2002 sonata
  244. Have a New 97 Hyundai, advise please
  245. Hyundai Sonata may have jumped timing...or is flooded?? I need help!
  246. Hard Shift
  247. Anti-sway bar for the Sonata 2002?
  248. drained battery
  249. 2001 crankshaft position sensor
  250. 97 Hyundai Sonata will not start!!
