View Full Version : Prelude
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. H22A swap
  2. question on ecu swap
  3. out of ideas
  4. rubbing sound at start
  5. evo2 exhaust system
  6. electrical problem
  7. Prelude idle issues (again)
  8. check engine light. decrease of power.
  9. prelude
  10. vtec problems
  11. cam gears
  12. Which Funkin Harness??
  13. Help Me Please
  14. H22 or H23 Tranny?
  15. engine swap
  16. carb number question
  17. Vapor Lock???
  18. OBX Cams Camshafts
  19. Prelude Remote Programming... HELP!
  20. Stronger Master Cylinder???
  21. How do I take the sunroof off?
  22. jet upgrade
  23. wheeel offset on 5th gen lude
  24. My 92 Si
  25. Strange noises....power loss
  26. Good Honda Buys
  27. seat belts dont lock
  28. what to do?
  29. top of the line prelude
  30. which rims for prelude.
  31. 17" Rims "Problem"
  32. lowering the car
  33. 2000 or 2001
  34. h22 front clip
  35. best exhaust
  36. leaking coolant... from 3 places
  37. Leaking tranny oil. HELP!!!
  38. Usual Tranny Problem
  39. suggestions
  40. Prelude S Vs. Si Vs. Vtec
  41. turning over, no start intermident
  42. H22A engine Serial Numbers
  43. Help me start this biaatch!
  44. JDM Type S conversion
  45. USDM parts
  46. How fast are these cars exactly out of the box?
  47. Looking for 92-96 with blown motor
  48. Lowering Your Car W/out Getting New Springs
  49. boost a H23 or swap or a jdm h22
  50. Need help with clutch
  51. Installing new racing seats, help!
  52. Transmission for sale on Ebay
  53. H23 tranny in H22
  54. funniest vid ever!!! must watch
  55. What Motor Can I Put In My Car
  56. DIY grounding kit
  57. h22a with h23 tranny
  58. advice on a prelude
  59. fx100 vs. act heavy duty clutch
  60. H22 tranny
  61. New Clutch
  62. Need help with tie bar
  63. Fuse diagram
  64. ABS Light
  65. 4WS good or bad?
  66. boosting H23 or H22?
  67. uninstalling a/c compressor & need help
  68. Need Head Now
  69. rough shifting
  70. abs
  71. 95 prelude Si to V-tech?
  72. engine code info
  73. psi compression 91 lude?
  74. Prelude Headlight Problems
  75. Oxygen Sensor ??
  76. clutchmaster fx100
  77. 1989 Honda Prelude Leaky Sunroof
  78. Wont stay running HELP
  79. Cylinder #4 not firing...causes?
  80. HELP!! No AC light
  81. low end hp gains
  82. AC pressure switch connection
  83. Tokico suspension
  84. driving technique
  85. AC Question. AC Compressor!!
  86. idle problem with 86 si
  87. Cleaning your Air Filter
  88. No Ac!!!!
  89. Body Kits For 4th GEN
  90. Fuel system help
  91. offset for wheels and tires
  92. fan not turning off
  93. Whats wrong with my clutch?
  94. 95 rear caliper/piston
  95. ...how about it...
  96. 86 prelude help
  97. 92 Prelude wont start!!
  98. f22a swap to f22b
  99. how do I remove front speakers on a 93 lude. please help
  100. Fuel Injector Cleaner on 93-octane
  101. H22 bearing problem. please help
  102. accord to prelude A20A3 swap
  103. plugs and wires noticeable difference?
  104. wow! dont buy g-force sport
  105. TWO QUESTIONS: o2 Sensors and Dash
  106. Missing Tweeters???
  107. studs?
  108. 1989 honda prelude rotor removal?
  109. %th Gen Clutch
  110. 92 prelude idle problem
  111. E brake handle location by year
  112. Need a rear bumper cover.
  113. WHAT ENGINE IS IN THIRD GEN 2.0Si?
  114. 1999 bmw 330xi vs 5th gen prelude
  115. What do you think about this engine?
  116. 98 prelude vtec or 95 prelude si
  117. painted interior opinion and aluminum floor mats
  118. 93 si will not start
  119. R.i.p.
  120. clutch goin out?
  121. idle issue
  122. Changing Rotors
  123. Tornado Gas Saver
  124. How much does aPrelude weigh (please help)
  125. 97 Prelude Auto trans. shifting delay/hesitation from 1st to 2nd DTC P0700 HELP??
  126. anyone used nology plug wires?
  127. ECU or wiring?
  128. 92 Prelude brake rotor and Auto Tranny questions
  129. 92 Prelude FOR SALE
  130. 98 SH Engine Problems
  131. trading my car?
  132. Upgrade costs
  133. just wanted to say whats up to everyone
  134. ABS wheel sensor
  135. quietest exhaust setup
  136. problem with clutch
  137. getting a 89 prelude si
  138. FOR SALE! - CUSTOM 5gen Prelude TV Visors (could work in civic too)
  139. h22/h23
  140. VTEC Prelude Vs. Type SH
  141. Right Headlight(s) not getting power
  142. are there any 5th gen aftermarket headlights?
  143. Trouble Code Trouble
  144. 1982 'Lude Brake Light Stuck On Since in Storage
  145. Nology Wires
  146. H23a transmission for sale
  147. wheel well fender water guard thingy-ma-bob
  148. What can the Prelude Really Do?
  149. Clock Question
  150. cylinder head on ebay
  151. HID 6500K Conversion Kit vs. H1 Xenon Bulbs
  152. best year?
  153. H22a SWAP ACTin all Funny!
  154. removing speed limiter
  155. What exactly is a Prelude Tune-up
  156. Confused
  157. Knock Sensor/Running Lean
  158. Timing issue on a Mazda B2300/1994
  159. quick question
  160. Prelude Production Numbers
  161. h23 Vtec conversion kit
  162. Voltage Regulator
  163. Two questions
  164. atts
  165. key wont turn in door lock
  166. prelude rev limit
  167. AEM CAI Rev limit
  168. How do I install aftermarket Pedals?
  169. New to the forums - Basic questions
  170. Timing Belt Replacement
  171. click here for a good laugh
  172. 91 prelude 2.0 si for sale
  173. recall
  174. windsheild washer pump
  175. is Tokico a good brand?
  176. Need help replacing oil pan on 92 Prelude S
  177. Timing Belt Whine
  178. prices
  179. h22
  180. timing gun settings for a h22
  181. honda prelude question
  182. Prelude v-tech gas type
  183. Long Sleep
  184. other cars w/same lug pattern? 4x114.3
  185. Hub Centric Rings
  186. timing belt
  187. speedometer is slow to turn on
  188. changing rotors
  189. changing rotors
  190. Hesitation/Rough idle
  191. 87 Lude 2.0si
  192. z3 Steel Fender
  193. Help me decide - Apexi N1 or GReddy EVO2
  194. Immobilizer locked me out after swapping ECU
  195. Immobilizer activated
  196. prelude pix
  197. Rough driving at lower Rpms. only taching out at 6500
  198. 92 prelude body type
  199. buddys prelude missing bad!!
  200. PreludePower.com
  201. lost lug key!
  202. fuel issues drivin me crazy
  203. exterior mods program?
  204. How long to get Crower Cams?
  205. Rough Idle Question
  206. "Breaking In" new clutch
  207. skipping speedometer
  208. MSD Ignition / SS Blaster coil??
  209. I Need A New Tranny!!
  210. 4th gen question
  211. strange screatching noise
  212. new 1/4 time
  213. Request for your help
  214. wiper fluid motor?
  215. Performance between SI and VTEC
  216. It's time to bid farewell to my '00 Prelude
  217. Am I being ripped off? Clutch job?
  218. 92 prelude engine??
  219. H22A vs H22A4
  220. I need input from the Prelude community, especially H23ers
  221. Does it matter if camshaft company matches valve spring?
  222. GTECH pro
  223. just installed my AEM v2
  224. HKS, Greddy, Tanabe... which would be best?
  225. How much (approximate of course) would this cost?
  226. Standard vs. SH
  227. problems with vtecH
  228. weird knocking?
  229. help my friend as a 91 lude need idea's
  230. chk eng light 98 lude
  231. hey guyz..Oil Change question..
  232. lude bumper.
  233. front lip
  234. radiator
  235. Locating the Knock Sensor
  236. Shifter Vibration
  237. where can i find a b20a5 motor?
  238. Check Engine LIGHT! "EGR Valve" lift sensor
  239. clutch issues!!
  240. fluidyne radiator/flexalite fan
  241. body kit
  242. Please buy me.
  243. Exhaust Installed!
  244. egr valve on 92 lude
  245. please help.. trans problems
  246. Good bye Prelude
  247. Exhaust Sound Clips
  248. Where can i Find a REALLY GOOD air filter??
  249. Need Some Help
  250. anyone selling 5th gen parts?
