View Full Version : Jimmy
Pages :
[ 1]
2 3 4 5 6 7 8 9 10 11 12
- 1995 Jimmy vacuum line mystery.
- 98 Jimmy 4X4 Rear Driveshaft
- Loss of power under a load
- Bleeding ABS module -unit
- Snap-On MT-2500 Datalog / Scanner Q...
- Front Driver Side Damage
- Sputtering on accelerate
- '98 Jimmy 4.3 torque AC comp to lines
- 98 Jimmy engine management problems
- Changed heater core now won't start
- Catalytic Converter problems
- Broken Rear Glass 99 Jimmy
- 98 jimmy 4wd front wheels not engaging
- tranny?
- Brake Bleeding - soft pedal - ABS
- 95 reluctor ring for crankshaft position sensor
- swapping engines in my Jimmy
- 2000 Jimmy Weird growling noise followed by a tick
- Leaky intake manifold - pitting
- 1995 Jimmy problems
- need bumper for 99 GMC Jimmy
- Tranny does not shift past 2nd gear
- Bleeding abs brakes
- Heater-vent problems
- GMC Jimmy feature issues
- windows dont work
- Keyless entry fob
- tranny whine
- 01 Jimmy 4.3L running extremly bad! AWE Rotten Eggs
- 92 gmc jimmy wont fire
- 96 Jimmy no 4 wheel drive
- 98 Jimmy, washer fluid motor
- Fuel Pressure Regulator -Ruptured Diaphram
- 98 Jimmy Tranny issues
- parts ???
- Rear axles S-10 Jimmy (Blazer)
- 4 wheel drive indicator light for 98 jimmy
- 1996 gmc jimmy trans problem
- 99 Jimmy Cruise throttle cable
- 93 Jimmy. Whining from rear and the truck dies.
- Aluminum Transmission Pan
- 2000 Jimmy V-8 swap?
- 2001 Jimmy Cluster problems
- 1996 Jimmy trans issues
- Starting "concern"
- please help charging issue
- dead battery, bad alternator?
- Intake Manifold?
- swap out 2000 4.3 to 05 4.3 jimmy
- issue with starting
- 2000 GMC Jimmy Won't Start
- p1351
- Remote Start WOES!!!! Bulldog Remote start.
- emergency question
- Mystery hose?
- 1997 Jimmy rear axle interchange
- Fuel Pump Replacement, AGAIN!
- 01 Jimmy front drive shaft
- front differential oil level???
- 2000 Jimmy will not enter remote program mode
- 98 Jimmy, heat is hot then cold
- 2000 jimmy, no 4x4 switch lights or 4x4
- 97 gmc jimmy no dash lights, wont start, stuck in park
- 95 Jimmy running rough camshaft position sensor code
- ABS light
- 1996 gmc jimmy head light problem
- dead battery
- Relays
- 2000 jimmy rear axle ????
- Tapping/Knocking Noise
- 1999 Jimmy Emissions
- 95 jimmy
- Fuel gauge jumps around
- convert to newer gm fuel injection
- 2000 Jimmy won't start after new Cap & Rotor.
- 1998 Jimmy Starts but then stals imediately after
- Using Orifice Tube as indicator to A/C Flush
- Experienced mechanic 93 jimmy-Appreciate your time!
- 2001 Jimmy shifts into 4wd on freeway on its own.
- fuel pump pressure
- Knocking noise on a 1996 Jimmy
- 2 problems with heat controls
- 2000 Jimmy wireing diagram??
- 97 jimmy intake gasket replacement help needed
- A "temporary" fix for the Jimmy Heater problem
- Headlight issue
- 95 Jimmy hard to start and then stalls
- '98 Jimmy 4WD- Ball Joint Frustration!
- All auto not working
- error codes p0101,131,143,147,151 and 142 - 2000 jimmy
- 98 Jimmy, wont start or shift from park
- radio lights?
- rear brake backing plate
- 99 jimmy p0452 p0463 codes
- ecm commanding no advace?
- 1994 jimmy won't idle
- 99 jimmy intermittent shifting problem
- Headlight assembly. 99 Jimmy
- PO453 Code
- Vacuum Leak? 1999 Jimmy SLT
- 1999 Jimmy SES light
- 1999 Jimmy Brakes go to the floor
- fuel line replacement 1995 jimmy
- Cruise control
- 95 jimmy odd performance
- Wiring Diagram
- If you are good at puzzles, I've got a good one for ya
- still no start
- Secondary Air Pump question
- 98 Jimmy, stalling, no start
- 95 jimmy tranny problem
- 95 jimmy runs good for 5 min stalls wont start for awhile
- 1999 jimmy heat trouble
- Rearview mirror courtesy light wiring
- 1993 gmc jimmy key stuck
- Brakes went to floor not sure what fixed it
- popping noise from fuel tank
- 1996 Jimmy to 98 Blazer conversion
- change battery and car started, no key
- 2000 GMC Jimmy Intake leak
- Combining Spark Plugs 41-932 and 41-993
- 2001 4wd jimmy no reverse
- 2000 Jimmy Fuel Pump Electrical Connector
- 99 Jimmy "clicking" behind glove box
- can get back in to 2 wheel drive
- '97 sqeaky belt, but not the belt
- '97 with very little heat
- 99 Jimmy TCCM
- 2000 jimmy knocking noise
- 2000 Jimmy Wipers do not work front and rear
- 99 Jimmy Fires but wont start
- 99 Jimmy 4x4 problem
- 1999 Jimmy Heat Problems
- 1999 GMC Envoy Transfer case removal
- 99 Jimmy questions
- ABS quick fix
- 01 jimmy 4x4 front wheel hubs
- 97 Jimmy4.3L extreme engine vibration, random misfire code
- 96 Jimmy, rear window & tailgate won't open
- 95 jimmy fuel pump swirling in tank
- loosing antifreeze
- Starving for air?????????
- 1993 engine knock
- So the intake gasket
- Vents only blow out floor and defrost
- Engine surging at low throttle
- 95 blows #2 fuse - dead short
- Broken Sun Visor Mirrors
- 96 jimmy 4.3 trouble codes
- Won't start
- 1996 GMC jimmy surging
- Engine Fan
- 1996 Jimmy no shift ??bad trans??
- ABS question/help
- can a 95 jimmy CPI unit be serviced?
- 99 jimmy 4x4 not engaging
- battery wiring
- Hammer Out My Fuel Filter
- Lift Glass Circuit Breaker
- Trouble code P0300
- Fuel pump problems
- 1999 Jimmy IACV Where ?
- Bypassing ignition switch
- id rear end
- Code P0300
- interior light on all the time
- 2001 Jimmy not running right
- Jimmy 4x4 conversion
- 99 GMC Jimmy 4x4. Electric seat adj's have quit?
- 2000 Jimmy cruise control vacuum
- Oil Filter Base Gasket
- Thanks for the info
- 96 2WD Jimmy Radiator
- CHanging the rear differential fluid...
- power windows/locks
- 1997 gmc jimmy e-test problem
- 95 GMC Jimmy-No charge
- 2001 Jimmy 4WD problems
- Purge valve
- 1995 Jimmy Oxygen sensors
- Wiper Motor
- starts with a sniff of choke cleaner
- halogen bulb problem (87 jimmy full-size)
- 95 Jimmy starts, dies, misses,
- So Long...
- tranny cooler
- starting problems fuel pressure
- Advice
- 1999 GMC Jimmy brake problem
- hazard brake light fuse
- oil pressure switch
- engine tapping loudly
- new jimmy owner
- Having Trouble Installing Transmission Drain Pan (1997 GMC Jimmy)
- socket size
- 1999 gmc jimmy that wont start
- 87 jimmy electrical problems
- Brake Fluid in Power Steering, HELP!!!
- P0446 Code
- 97 jimmy no 4wd hi
- 96 jimmy tranny problem
- 95 Jimmy oil pressure problem
- 1997 GMC Jimmy back hatch problem
- trans. 1996 jimmy
- 95 jimmy bad distributor gear
- Heater fan
- 97 jimmy no start after intake gasket job
- Intake manifold, coolant leak
- New Rear Wiper Motor is not working!!
- 2000 Jimmy leaking coolant
- Light bulb replacment
- 2000 Jimmy Fuel Pump issue
- Proper Cleaning of Poppet Valves
- 94 Jimmy 4 Wheel Drive problem
- 96 GMC Jimmy Help....O2 Sensor??
- 92 Jimmy Quits while driving.
- 2000 Jimmy missing badly
- FNG- Hello and thank you!
- cpi
- 94 jimmy 4x4 4.3 vortec running rough/backfire
- Heated seats. GMC Jimmy
- 4x4 Service Light
- 1999 Jimmy SLT 4x4 module?
- Where is the fuel filter located on a 1987 s15 Jimmy
- 87 Jimmy engine problems
- Code P0446 and P0404
- 95 GMC Jimmy brake caliper bolts
- 95 Jimmy remote oil lines
- No service engine soon light
- 96 GMC Jimmy black smoke, backfires, Timing?
- no spark
- Oxygen Sensor..How many are there?
- 99 Jimmy Heater Motor?
- Hard start, run, idle, it doesn't do anything right.
- where 2 get new fuel pump ??
- 95 jimmy no 4wh
- Fuel pump cut off switch?
- 1995 jimmy 4.3 4x4 problem
- Ground straps
- 96" Jimmy Tranny costn me money!
- 1995 jimmy 4x4 problems
- 93 jimmy no cold start unless primmed
- 96 Jimmy #3 misfire...STILL
- Jimmy Auto 4WD Problems...
- 00 jimmy won't start
- Transmission... Still alittle confused
- 01 jimmy no power
- Rear bearing R&R
- 97 Jimmy no start
- Another 4x4 question....
