View Full Version : Windstar
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. stalls after running AC 2003
  2. no ac in rear just recharged
  3. nide a trasmission
  4. 2002 200K+ kms stumbles while accelerating from approx. 40kmph. Airbag light...
  5. 02 sensors CEL but thats not problem
  6. P0172/174 and now p0301/303 TSB repair done yet no luck. HELP?
  7. Rear axle beam possible recall 1999 to 2003
  8. 3.8/96 camshaft position sensor - strange instructions?
  9. AC Coolant Lines - Routing diagram
  10. Pic of Winstar w/20" wheels, anyone have?
  11. R&I tranny 96 windstar
  12. front windshield washer
  13. 96 windstar turbine shaft speed sensor
  14. power steering unit & belt alignment
  15. clunking/resistance
  16. Tranny issues
  17. TCC solenoid inductive signature, etc.
  18. 95 Winstar Serpentine Belt Problem
  19. 2003 Windstar stumbles at idle
  20. 98 windstar rear aux cooling unit problem.
  21. Where is the EGR Vacuum solonoid located..
  22. I see misfires in ScanXL but...
  23. '03 Windstar AdvanceTrac problem
  24. Air intake baffle
  25. BIG trouble with my Windstar!!!
  26. '03 Windstar makes moaning sound...
  27. Ford windstar van won't start
  28. '98 Windstar died, would crank but not starting
  29. Fuel Trim banks
  30. Am I loosing the alternantor?
  31. 96 ford windstar problems
  32. General A/C troubleshooting advice
  33. '00 Window driver side window won't roll down, door won't lock
  34. 1995 Windstar Evap changeout
  35. 02 power steering leaking
  36. 98 intermidiate hiss
  37. 95 Trany do not shift after sopping
  38. windstar 1999 hood release
  39. Windstar sppedometer, odometer, air conditioning
  40. Broken CV Boot Cover
  41. 2001 Ford Windstar 3.8L
  42. 2000 windstar stumbling/hesitating
  43. engine transplant
  44. 99 Windstar hard to start when hot
  45. Need your help: What is part number for Vehicle Speed Sensor 95 3.8L Windstar GL
  46. 2003 Windstar shuts down at higher speeds
  47. Multiple cylinder misfire codes
  48. cant read codes
  49. which scan tool reads MAP
  50. Bogging down on acceleration
  51. '99 Windstar Electrical Problem
  52. Wiper Delay doesn't work
  53. Draining battery overnight???
  54. 98 windstar rear a/c issue.
  55. DIY Stabilizer Link replacement (w/pics)
  56. Muffler problems
  57. Heating controls vacuum line
  58. waterpump studs - thread open to engine? 3,8/96
  59. dropping resistor repair 3,8/96
  60. intirior lights wont shut off
  61. 2003 Windstar possible alternator problem.
  62. 2003 Intermittent High Idle
  63. All air going to the windshield...
  64. Another 2001 Winny with a bad coil
  65. Neutral Safety Switch problem?
  66. 1998 windstar getting 1400 and 1403 codes.
  67. Most modern vehicles have a clear coat applied?
  68. suspension making noise after strut replacement
  69. steering disengage at full lock
  70. 2000 Windstar - Rear Wipers inop, my luck ran out
  71. erratic speedometer 3,8/96 - what to check?
  72. 2002 Windstar Idles low but AC causes it to cut off
  73. intermitent no spark
  74. 2002 Winstar stabilizer link bar question
  75. lower intake
  76. '00 A/C troubles
  77. 95 3.8 with 250,000 vacuum issue
  78. 1998 windstar electrical problem???
  79. unknown module box before radiator
  80. '96 Windstar airbag light
  81. 1995 Windstar Coolant leak
  82. tie rods replaced, still alot of movement!
  83. 2000 a/c leak at switch, green tint, what to do
  84. 98 power steering noise
  85. Brake Line Failure
  86. Radiator flush
  87. 99 Windstar trans rough shift
  88. 2000 ford windstar master lighting switch light
  89. Windstar Trans problems
  90. 1999 Windstar TSB 8321
  91. 98 Transmission shifting issue
  92. standard alternator size 2001
  93. Lights died while driving on highway, etc.
  94. Check engine light not able to be read???
  95. lower manifold gaskets
  96. Fuel Pressure Regulator Vacuum Hose
  97. 2001 winstar transmission stopped working
  98. Is upgrade to 16" tires and wheels worth it?
  99. Orange light bulb symbol on dash board
  100. 2001 Windstar Wiper Noise
  101. Radiator Overflow Bottle
  102. Caliper Guide Pins
  103. 1996 3.8L Front and Rear Valve Cover Gaskets
  104. 95 windstar trans removal
  105. 98 door lock problem
  106. negative camber after accident
  107. 200 windstar se trans problem need help
  108. 2001 Airbag code 16
  109. 2000 windstar code p-0353
  110. 2001 Windstar Coolant Leak
  111. transmission problem
  112. I Need the Schematic for a 02 windstar EVAP!
  113. can I run with vacuum removed from FPR
  114. new to me 98
  115. 95 3.8 Windstar continued
  116. Severe wobble in rear on bumps
  117. Possible water pump leak
  118. 02 windstar airbag code 51 pls help
  119. 96 3.8L charging issue
  120. 98 3.8l intake gasket cleaning
  121. 2003 Windstar Isolator Bolts
  122. Question on Windstar engine and transmission
  123. 1998 3.8 Windstar coolant, electrical, missing
  124. SCDS fused harness routing?
  125. 98 - Windshield Wiper Washer Nozzles
  126. 2000 Windstar Front Wipers Wiring Diagram
  127. Brake bleeding
  128. Alternator???
  129. 2000 Windstar Loss of Wiper Intermittent and Park
  130. Power seat only goes up!
  131. Codes 171 and 174- passing inspection
  132. 99 Windstar Need Clockspring, but where do u find it?
  133. Radiator fan will not shut off
  134. 01 Windstar ASB Warning
  135. 2000 Windstar fuel smell on plugs
  136. Overdrive does't work,99 windstar
  137. Odd no start sound.
  138. 98 Windstar Transmission internal wire harness
  139. 98 windstar 3.8 lit - Turbine Shaft Speed Sensor
  140. Clunking sound from passenger front
  141. 98 windstar 3.8 liter instrument panel lights
  142. Winstar will not start sometimes
  143. Tapping noise on Defrost setting and CEL coming on
  144. wiswind help
  145. 99 3.8 fuel injector question
  146. engine overheating
  147. 95 Windstar 3.8 MAF Sensor
  148. Abs
  149. 95 windstar intermittent speedometer
  150. 99 Windstar Trigger Happy Starter!
  151. Front Windshield Wiper Motor
  152. 1999 Windstar Wheel Hub Assembly
  153. windstar 98...3.8 lit
  154. Ignition switch will not turn,HELP!!
  155. Hydro-locked...two rear cyls...
  156. IMRC troubles
  157. Warning lights everywhere.
  158. driver side power window
  159. torque wrenches
  160. 96 windstar 3.0L tramission problem
  161. 01 windstar coolant line
  162. Where is the fuse location for the cigarette lighter?
  163. OT-need help with Jeep axle seal
  164. antifreeze leak
  165. ABS Light came on - passenger rear wheel locking up
  166. Tune-ups
  167. Ford Windstar Heater blend door actuator problem
  168. replace sliding door
  169. 01 windstar isolator bolts
  170. Help! Six check engine codes, and more.
  171. cruise control not working
  172. Need a Windstar key fob?
  173. 98 windstar over heating in the cold
  174. 95 Windstar - How do I clear airbag code 21
  175. Fuel pressure regulator
  176. How To: Remove Inner Hood Cowling
  177. 98 3.8L Transmission - No Engagement
  178. How to remove headlamp assembly
  179. Horn honking in unmanned car at night
  180. '99 3.8L Starting Troubles
  181. 98 Windstar - Window motor or regulator
  182. OFF Topic: x beam wrenches
  183. 99 Windstar 3.8L Replacing Intake Manifold Gaskets
  184. 2003 3.8l, Codes 171 & 301
  185. Problem getting the engine to turn...
  186. Time To Change Battery?
  187. 2001 Windstar Bucking
  188. 01 Windstar hesitating under load, low speed
  189. Could a bad Catalytic Converter cause lean codes?
  190. oil seepage from intake manifold
  191. Driver side mirror and sliding doors
  192. Serpentine belt squeek, car cuts off
  193. battery drain
  194. 96 Windstar - no cold air from AC
  195. '97 3.8l - p0133
  196. 3.0L cam sensor problems.
  197. gas smell
  198. 1995 Windstar ticking noise
  199. rear wipers
  200. DPFE Problem
  201. Valve cover replacement
  202. Power windows (2001) again
  203. check engine light hell
  204. Engine dies at startup
  205. Steering Wheel Removal Socket?
  206. repair the sliding door ajar issue - very easy
  207. 96 Windstar 3.8, 12 codes no start
  208. Air Blend Door
  209. '99 3.8L Missing/bucking Solved! (I think)
  210. '01 -- window motor and heater not working
  211. Power Steering Switch/Relief Valve
  212. Heater Blend Acutuator Gear Fix
  213. Radiator differences in 95 Windstars
  214. '98, 3.8L rear brake job question
  215. Just got a P301 code
  216. 3 codes on my wifes 96 windstar (301,161,102)
  217. no fuel pressure - no rpm
  218. White smoke on start after sitting for a hour or 2
  219. 95 windstar fluctuating idle
  220. DPFE & EGR Function & DTC's
  221. Power steering flush Windstar 98 - No place to work
  222. Brake light
  223. 2002 spark plug gap?
  224. Engine Compartment Fuse Box ??
  225. New coil; still missing/bucking; '99 3.8L
  226. How do i adjust the handbrake??
  227. switching motors
  228. Interior light problem
  229. code p0304
  230. Windstar The dash shutts off !
  231. 2000 Windstar Power Window Problems
  232. No start after 171/174 code repair
  233. Rear Axle Break
  234. 1999 Windstar Heater Blend Door Actuator
  235. Door lock question
  236. 2001 windstar
  237. 2001 windstar transmission problem
  238. 2001 Windstar
  239. 2003 Windstar losing oil
  240. Radio Removal 99 Windstar SLE
  241. Water Pump check out
  242. replacing master cylinder -- '01, 3.8 L
  243. rough engine at very low speed
  244. 1999 Windstar LX Fog Lights
  245. '02 Windstar - P0305 - Deposits on plugs
  246. 95 Windstar 3.8 P0171 Code
  247. 00 Windstar wouldn't start
  248. 99 Windstar - how to replace struts & rear shocks?
  249. A/C Outside Air Door Going Bonkers?
  250. Odd electrical issues
