View Full Version : Windstar
- Burnt transmission fluid
- Power windows
- Changeing serpetine belt
- Weird A/T problems
- 1999 Windstar with no rear heat or air
- '96 Winstar 3.8L with P0304 code.
- Air Conditioning/Loss of Power
- 2000 Windstar Won't Idle - Need Advice
- Steering Gear Leaks, Baaaad!
- 1998 windstar transmission
- Abs
- 2001 Windstar battery light!
- AT "shifting"
- catalytic converter PO420 code 96Windstar
- Windstar 98 I feel like throwing
- door locks for '95 windstar
- Broken Coil Spring
- check engine light
- 97 Heater issues
- sliding door
- oil leak in air filter
- 1996 Ford Windstar alternator/electrical issues.
- 98 rear wiper
- windstar wont start
- 1999 Instrument )Panel
- Mystery Module
- 2001 keypad code
- dashboard lights blinking
- WS vacuum motors
- Passenger power window - 1999 Windstar
- P0170 Fuel Trim Malfunction (Bank 1)??
- 2000 Windstar Headlamp Warning light
- harmonic balancer
- 99 Windstar not cranking
- 15x7"white" 5 spoke wheels w/225 60's
- ATF Fluid change again
- New to Forum
- brakes on 99 windstar
- 95 3.8L Ignition problem.
- 96 ford windstar 3.8 engine knock and transmittion downshifting
- Brake Fluid leak at sensor
- Transmission Oil Cooler Installation
- ABS Revisited
- Seattle Times Article...Bad Gasoline
- Brake Shift Interlock Solenoid
- transmission takes too long to shift
- 2001 FORD Windstar Code 1309
- replaced rear shoes, grinding
- 98 windstar eecs codes
- 1998 Windstar Starburst Wheelcovers
- whistle noise
- Windstar POSSESSED with failure
- Spark Knock
- 99 Electrical problem locks, seat, lights
- Engine knock (code 304)
- '98 3.8L Check Engine Light P0174
- service engine light...HELP
- Cruise Control
- P1537
- 2000 windstar charging
- Windstar ABS & Trac Off Indicators
- Transmission hesitation, 95 - 3.8 157K Miles
- p0402 Where is EGR
- DPFE and EGR
- Power Steering Fluid Capacity
- Code?
- 1995 rear drum brake removal
- 1995 windstar with po171 & p0174 codes
- Radiator Fans do not run except with AC on
- Cruise Control
- 90 Sable Tranny in a 95 Windstar
- 96 Coolant loss, IMRC stuck open, #1 missfire, O2 lean etc etc
- 2000 Windstar Fuel Pump
- ATF Temp
- another air bag light and more
- Windstar transmissions
- Rear Vent Windows Wont Open
- 99 Windstar power steering & Cruise control
- broken hose
- Ford De-carbonize Process - Spark Knock
- 1998 Windstar 3.8 Engine Swap w/V6 from 2001 Mustang?
- 1999 stall when below a 1/4 tank
- Running wire for tranny temp gauge
- Adding daytime running light module
- Obd !
- 95 a/c elec failure vents/clutch
- 99 Windstar tranny shudder at 1-2 shift
- shift cable terminal lock
- Stalling when stopping
- 2002 Ford Windstar Check Engine DTC P0171 "System Too Lean"?? Help
- sick 98 windstar
- 98 winstar tranny
- 1995 Windstar CEL P0340/miss detected
- Winstar blower emitting smell into passenger compartment
- 1995 Windstar transmission
- 99 abs light
- Brake Light Switch Location
- overhead lighting problem
- Blower Speeds
- 98 Windstar 3.8L-rough running at 1500 rpm
- 99 Windstar transmission troubles
- 98 windstart starting problem
- 96 windstar
- spring loaded contacts
- day light allways stay on
- axle shaft removal.
- airbag light
- backup sensors
- help on speedometer
- Steering noise
- All doors locking/unlocking intermittently
- Misfires on cylinder #4
- P0153 - Which is Bank 2?
- 1996 Windstar one-touch down power window stopped working
- Chilton vs Haynes Manuals
- Runs better prior to drive cycle
- check engine light , rough running
- '99 3.8 Intake Manifold: Second Repair.
- Challenge: Sliding Door Locks, But Won't Unlock
- 2000 windstar intermittent start
- speedometer
- 2000 Windstar Brake lights
- 1996 Windstar Tune Up
- replacing 1996 Windstar speed sensor
- Engine whine varies with speed
- 98 Windstar - Grinding noise at stoplights
- 98 Windstar Power Windows Won't Work
- ford ranger temperature control
- Groan in front end when turning to right, sometimes...
- 99 Windstar 171 and 174 tsb done already?
- location for the heat sensor temp guage?
- 2000 charging issues
- Slosh in my engine
- 1999 Windstar
- Why Is The Fuse Panel So Different For Fuse #6??
- Front Disk Brakes
- Front End Vibration
- pulling codes
- electrical info needed - dead radio
- Transmission Diagnostic Question
- keyless remote programming
- trans prob
- chime location?
- rear spark plugs 98 windstar 3.8 liter
- 98 3.8l rough idle + stalling + blower = ?
- 98 Rear AC/Heat fix! IMRC parts MUCH Cheaper also!
- 3.8 running warm
- Help With Instrument Cluster
- Intake Manifold Runner Control (IMRC)
- Problems Still, Power Steering
- Power Steering Fluid Question, Dexron III or Type/F
- 1999 Windstar Rough At Idle And At Higher Speeds
- Coolant leak on a 95, 3.8 155K miles
- ABS Power Relay
- New Power Steering Pump groans and foams
- 2003 SE Idling High
- P0302 misfire cylinder 2 - Chevy Suburban
- Headlight Angle Adjustment
- Hi mileage Minivan....
- mom of 3 with 98 windstar trans problem
- 1996 Ford Windstar (junk) Door Chimes
- strange sound at tank/gascap
- Door Ajar
- Rough Idle 98 Windstar
- Can anyone tell me how to change oil and filter for 96 Winstar LX 3.8? Thanks.
- Moderator
- 'Flaring' the 5/16 coolant lines for Tranny Kit......
- Help! Strange Problem!
- 96 windstar windshield wiper problem
- Can't figure out why my fans want come on without the AC being on
- 1999 WS cornering lamps
- DriveBelt Tensioner on 95 3.8L
- 1996 Windstar windshield wiper vaccum
- Tranny Cooler Install Question
- '99 Windstar specific diagnostic trouble code
- Got a new code 181
- 96 3.8 couple of problems
- Code For Keypad On 2003 Sel
- 96 3.8L with P1538
- '95 3.8 vs. '96+ 3.8
- A/C Vacuum check valve
- Another quick question about 98 windstar 3.8
- freon
- CEL Why will it not go out
- Synthetic and conventional lubricants
- Unknown Bolt in Transmission
- no door lock/unlock relays on board
- Altezza Lights?
- Hard Start - No Start
- Steps to remove the inside panel off the sliding door of ford windstar
- 1996 p0171 and p0174
- water pump
- Oil in Coolant
- 2000 ford windstar clicking during accel.
- 01' Windstar Paint Delamination
- Intake Gasket/EGR Ports
- Speed sensor(VSS)
- 1995 windstar door light
- help
- P303
- Need Help With 99 WIndstar Check Engine Light ...codes p171 & p174...
- abs light
- VSS location
- front door lock sticking
- P0301,P1537,P1538 and Abnormal Cracking Noise in Driver Side Front Wheel Suspension
- rear power window
- Obd Ii Code Scanner And Eraser
- Removing the stereo 2001 winnie
- one 171/174 resolution on rough running and stall
- 2001 blend door fix problem
- Power Window failure
- Front Electronic control module 2001 Windstar
- 96 Trans. Issues
- P0302 only, CEL on '01 3.8L
- Rough Idle
- 2002 WinStar Checnk Engine Light is on
- coolant spraying engine
- Seatbelt Alarm
- Electrical Nightmare
- looking for a hole in firewall/run guage!
- Another Windstar Code Issue: P0113
- Front door locks and windows -power
- Front left flasher
- stuttering with code 0352
- 0181 Where is fuel temp sensor?
- compressor not coming on 200o windstar
- windstar 96 3.8 where is located the VSS?
- 2001 ides rough after heat-soaked?
- What parts do I need???
- Big oops
- All the lights work except for right high beam-any ideas?
- P0302&P1512
- new to this forum -- `97 Windstar
- Coolant Leak
- Keyless Entry 2001 Windstar
- Paint falling off hood.
- Rear Wiper stopped working
- 1996 Windstar transmission wows
- Seafoam use?
- Winshield wipers stopping
- IMRC cotrol.
- 96 windstar head gasket
- codes 0181,0497
- Using Fuses As Test Points.
- Warning Light
- 98 windstar cam timing code and traction light
- ABS 99 Windstar
- Windstar Cargo Van
- 12 vdc output issue! Fuse?
- 2000 Windstar headlamp
