View Full Version : Windstar
- 96 Windstar Few problems
- 98 Ford Windstar PO171 code
- Windstar 2002 climate control problem
- Interpret Diagnostics
- 1995 Windstar Trans-won't shift slips
- Emission Inspection
- 2000 PO401 & PO402 Alarms
- 96 - Stupid Door Alarm!!!
- 2001 idles rough after heat-soaked
- o/d off light flashes
- OEM rotors/pads veres Aftermarket??
- Do brake discs need to be turned in pairs?
- Upper Intake Manifold
- 98 Windstar low idle
- Door Jamb Switches
- 98 Windstar will not start in freezing weather
- rear brakes, 98 WS
- hi
- Fuse box diagram 98 Windstar?
- Door Ajar / Dome Light Flashing
- Wheel Bearing Hub plus Disk Brakes
- 99 Windstar will not start
- 2nd Updated 171/174 codes;did repair!
- 1998 Ford Windstar IMRC Code 1537 and 1538
- slight shake 2000 sel
- starter relay
- windstar engine wont turn over
- P0306 on 96 Windstar 3.8??
- '96 windstar constantly refuses to start
- Cleaning Egr Ports
- 2000 Windstar Temp Gauge
- 98 windstar front bearing
- Our 2001 Windstar pops & misses on 1 cyl.
- wheel alignment done or not?
- when changing gears van hesitates
- ABS & Trac Ctrl lights on & Speedo reading 1/2 speed
- vcr/dvd swap
- 2001 Windstar Heat Malfunction
- Oxygen Sensor ~~confused~~
- Windstar timing cover leak?
- climate control blend door noise
- 98 windstar brakes locked up
- 01 Windstar Electrical Problem
- 1999 Windstar SE - ABS & Traction Control
- 98 ford windstar
- How to jack Windstar up on jack stands
- heater probs
- Problem code P0420,P0430
- p0401 again
- spark knocks
- Dome lights
- '02 Windstar Trans 'shudders'
- Catalytic converter
- 99 Ford Windstar - steering wheel shakes @ 40 mph
- abs flashes and light/wipers/and turn signal don't work at together
- 99 Ford Windstar -Sliding Door Problem
- 96 front wiper fuse 18 short
- My heater going out?
- P0171 and P0174 = Bye bye, Windstar!
- Update, code 174-175 maf! light still on?
- Power Steering Return Hose Length
- 2000 Windstar-Rear Wiper!!!
- Should I replace 1995 with a 2002
- Thermostat Rating
- P/S Pump Hose Seals
- replacing computer
- Parking lights flash when ignition turned off
- 2002 Ford Windstar P171, P172, P174 and P175 codes
- Isolator Bolt Fix
- ? remove fuel filter 2002 Windstar
- squeel getting better
- Windstar transmission filter o-ring
- Ignition diagnostic monitor (IDM) ???
- Rear heater fan possessed (2000 Windstar)
- How to Open door Panel in 2002 Windstar
- squeel
- 99 Windstar Power steering pump
- front end probs
- P0715 trouble code?!? '98 windstar 3.8
- struts and springs
- Radiator flush and fill on 3.8L
- No GD Heat Again In My 99 Windstar!
- no heat at all in a 89 acclaim
- no heat.....
- Help with a 95 power loss on long trips
- Rear defroster not working, where is the relay?
- 96 Windstar Misfire
- Air in fuel rail
- 99 Woes
- what code reader to buy?
- 174
- windshield wiper arms
- Replace rear bumper cover
- Winstar door switches
- 96 windstar serpentine belt came off...why??
- pcm problem
- Isolator bolts & port seal replacements.
- Merry Christmas..Have a Misfire
- 2002 Windstar (Check Engine Light)
- RPM Surge at stopping
- transmission shifting problem 95 3,8L
- Windstar '96, 3.8L
- Won't start after disconnecting battery
- 1999 ford windstar front washer motor
- freestar vs. winstar
- Power seats
- Coolant leak help needed
- 2003 windstar keyless entry code
- 1998 windstar remote start
- 98 Windstar, very little brake pressure and will not hold pressure
- 96 Windstar Isolator Bolts
- need help
- Windstar shudders @ 1500rpm
- Anyone got alignment (camber, toe) settings for a 96 Windstar
- Code 1537 Bank 1 IMRC question
- 1998 windstar evap
- Is 99 Service Manual similar to other years
- 2000 Windstar speaker repair
- No Heat in 1995 Windstar Please Help !!!
- Starter Tumblers
- Transmission location
- 98 Windstar
- It's the Water Pump
- 1999 Ford Windstar Overdrive Light Flashing
- I need some help with my Windstar -98
- More problems......
- Code 1537 ? (98 Windstar)
- 99 Windstar Service Manual
- 1999 Ford Windstar with no front heat
- Imrc
- Help Please...cant Shut Car Offf
- 1998 Windstar Power Window
- 95 Windstar fuse panel
- 2001 Windstar knocking
- 2002 Windstar Fuel Pressure Problem
- No parking lights
- 2001;chk eng lght; code 174=175 MAF ?
- Big problems with 96 Windstar
- 98 Windstar VSS replacement ??
- Car won't turn off!
- 98 smoking from hood
- 2000 windstar front washer fluid motor
- Misfire help
- No reverse on my '96 Windstar!
- codes 171/174,dealer fixed problem....
- 96 Windstar Wiper Problem
- stalling '96
- fuel mileage
- another new alternator
- Brake lights
- 99 windstar shudders at 1500rpm
- 99 Windstar has no speedo, abs light on, and #10 fuse blown
- Popping from front suspention
- Brake Lights Won't Turn Off...HELP!!!
- Cleaned EGR ports
- Disable side view mirrors?
- Heat for just a while in 98 windstar
- Question on PCV Grommet
- Windstar coolant problem?! HELP!!!!
- 98 Windstar - electrical problem
- Possessed Windshield Wipers
- Windstar dirty coolant...oil and ABS light on...Help
- Got HEAT?
- Larger fuel pump screen??
- check engine lite
- Ashtray/cup holder
- PCV valve; Ford or aftermarket?
- 98 Windstar - Occasional Problems Starting
- oil water cooler 1989 f250
- Valve cover replacemet/De-Carb 2000 Ford WS
- e-test, keep failing
- Brakes and passenger side sliding door
- dtc 171 174
- Transmission Interchange
- auto trans 95 windstar.
- klunk turning steering wheel
- Idle Air Controller
- '99 Electrical Problem--Help Needed
- Hole in oil pan on 2003 Windstar
- 96 Windstar 3.8L jerky acceleration
- 1999 Ford Windstar Battery?
- 98 windstar Power Steering Failure. Please help
- Rattling Front End
- Misfire??
- Engine Starts and Immediately Stalls When Cold
- brake problems on 96 ford windstar
- Radio
- Tapping - Engine Passenger Side
- heater core
- Air/Water Filter Mod Test
- 99Windstar brake lights out
- P1538 IMRC stumper
- How do I remove Right tail light plastic assembly
- Fuel injector cleaning & O2 sensors/fuel milage
- Passenger side sliding door and cruise control
- 2002 Windstar won't start
- 2001 up/down idle only when cold?
- Blown Engine Now What ?
- attemped imrc repair
- 1996 windstar codes trying to decipher
- My 1998 Windstar Wont Start
- '99 Hand Brake BREAKS!
- 2000+ Windstar Transmission Leaks
- Side view mirror removal
- When turning engine stalls.
- Need advise on Isolator/Intake repair..
- How to replace fuel filter on 95 windstar?
- TSB 03-16-1 nightmare
- power steering, rack and Pinion
- fuel filter replacement and rattling lifters
- Windstar Trouble Codes 171 & 174
- Driver's Side Power Window
- Problem on my windstar
- 2000 Winstar Power Doors
- 2001 engine smokes at start up uses oil
- 95 Windstar Oil pump?
- Keyless Entry Question
- Steering light up??
- 171 code may not be TSB related
- 2000 Winstar power door still not working!
- blend door broken
- 98 Winstar Clunking Noise
- 98 Windstar Heater Fan Only Has One Speed
- Alternator replacement a pain in the !@$
- AC Vaccum Problems, Lighting problems
- Flashing O/D light
- Question on Ford Rim Bolt Pattern
- heat
- Headlight Lenses
- Need help with tensioner installation
- 2002 Windstar - PO171 code
- Windstar 2000 SEL Air Intake Plenum. Please, need advice ASAP.
- serpentine belt loose
- 2000 windstar cd changer jam
- 95 Front heater fan speeds
- 99 ford winstar shuts down
- 96 Windstar GL won't start
- Dashlights
- disabling drl
- Passanger side power door
- relly puzzled
- Power Drivers Seat Install
- 1999 ws miss in bank one
- 96 Windstar hard to start when hot
- Rough Idle after repair work done
- Ford Windstar 1998 Brakes
- Windstar 2000 SEL lock button issue.
- traction control and abs light
