Chevrolet
Camaro | Firebird
> Engine and Transmission
View Full Version :
Pages :
1
2
3
4
secondary air injection
What Else Can I Do??
1989 2.8L firebird cam??
my tranny!
Installing a re-built 350 in a Camaro
Throttle body spacer
tranny 1st to 4th?
Corvette to Camaro
cut offs or new pipes?.....
trans swap
Spark Plugs
Adding HP to my car
66 corvette 327ci in an 86 firebird?
performance mods
Priming oil pump - lifters not oiling
unkown engine mod
valve spring question
freeze plugs
Spark Plug Replacing on 96 Firebird
Fuel or Electrical Problem
1989 firebird 2.8L turbO???
need some info
3rd gen v8 headers
price for installing engine????
Exhaust (any suggestions)
TPI to Carb??
94 firebird 3.4 to 94 LT1 engine Swap
Testing a 94 Firebird for the weekend,some problems..
97 trans am 373 gears
Super charger VRS Twin Turbo
2001 Firebird exhaust system question…
MY new CAR!!!!! HELP!!
Xlerator
New Pontiac Mannifold
350 to 383 engine additional performance
sb to bb
SOunds crazy
bank 1 bank 2
350 for a 95 v6
Lt1 ==> Ls2 ??
many sbc questions:)
Electric Supercharger???
nitrous + turbo question
New headgasket - valve lash adjustment on '91 Z28 305
any suggestions???
5.3 vortec swap
Spark plug gap?
need help with cam
Z28 Performance Upgrades?
Exhaust ?
want to put tpi in 1980 firebird
V6 to V8 Swap... Need To Buy An Engine
2000 Trans am WS6
Get Your Car Color # Through Your Vin # ??
94 Pontiac Firebird V6 Help Mods..
327 or 350? Which one is better my Camaro?
Who has an aluminum driveshaft 3rd gen?
No thermostat?
Hows this sound?
1994 Pontiac Firebird V6 3.4 Catalytic Converter?
Differential gear ratio
t-5 swap
Ram Air lid question
okokok... OIL PAN
Cold Air Intakes?
okokok... dammit - couple q's
Loud Exhaust
1994 Pontiac Firebird V6 3.4L Looking For Borla Exhaust
Combo help
Roller rocker arms?
Boom-boom-chicca-boom...
NUTS! Can I use a cracked Dampner
i got ?s do you guys have answers...
Locating Spark Plugs
3800 performance
Sparkplugs
quick question
1995 Firebird Performance Ideas
the bc4
Engine Tag What is it?
Any using a heavy duty or high performance alternator?
Oxygen sensors
NoS
T-Rex cam
3800 v6
OK.. OK... OK... Getting there, questions....
1986 Camaro Z28
okokok... Oil Pan Question
Suspension
2.8l parts interchange
2002 camaro temperature?
2 peice drive shaft
Rebuilding an '89 camaro 2.8
My car...
What is Ram Air
B and M shifter installation
what is the cheapest and easiest way to add speed to my Z28?
Performance Cam fo 3.8L
SBC in a 68 Firebird
Heater core in '89 Camaro RS
turbo-camaro
need help to find performance tpi setup
okokok... Octane Boost???
305 to a 350??
rebuilding sbc heads
More Power
Magnaflow Exhaust
Knock sensor mods
lookin to put new heads on my iroc
Diesel conversion
350 in a 4th gen camaro
Carb tuning effectively
exahust on a firebird...
Will these timing gears work?
V-6 to carburated 5.0 engine swap?
1998 Camaro
92 camaro rs conversion >sbc stroker
curious
92 camaro build up
need boost gauge
open headers
From 3.4L v6 to 5.7L V8 LT1
looking to get more hp and better pick up with my iroc
Question about 2.02 valves in lt1 heads
granatelli 90 or Vortec 90
Recommended CAI?
stock/SLP
Ram Air?
Trans Am Carbs......
K&n
Cooling fans running
Giving my 84z more horsepower ??
Z28 Speedo Calibration
Modifications to a 1989 Camaro V8.
cammaro and firebird trans swap
79 trans am air breather
Don't know what to do next, NEED HELP!!!
Cams
Engine Swap Help!!!
engine swap
2002 Ram Air WS6 mod ideas...
chevy camaro swap help
okokok... Camshaft ID?
Throttle linkage to cable
I have a 87' firebird want to put in 77' 400
Is a c4 corvette engine faster than a 1995 z28 camaro?
I would like to replace a v6 3.4 liter with a v6 3.8 liter in my 95 camaro.
New Clutch
3.8/automatic Ecu Swap...
305 Chevy to 455 Olds... what 2 do?
update.... (more problems)
firebird fuel pump
Electric water pump???
Is it worth putting a v8
decisions, decisons...
rebuild help! (sorta)
3.4 Performance?
underdrive pulleys
looking for suggestions on rebuild
communication VORTEC & Allison
Good news and bad news
Anyone Swap LS1 into a 3rd gen using aftermarket K-member???
Engine Swap
Ststurbo
V6 F-body...... 9.5 @ 136 mph
bleah needs to be done :(
building a 94 lt1 but need to pass emitions in tenneesse any suggestions ?
87 TA shift cable?
need help with engine swap
engine question
stupid question probably...
How much would it cost to swap an LS1 or LT1 into a 98 base Firebird?
94 firebird 3.4 swap 5.7
Performance Chips
LT1 Performance....
Top Speed????
Just curious...
Electric superchargers
big block trouble!!!!
Little Engine Help...
quick help... need to run the starter...
redution pully on 3.4 camaro
firebird camaro exhaust swap
Good street shocks
Shocks......
i need some help about a 350 idk if nyone of uns could help me but its worth a shot.
need some info about a 350 block and 305 heads
Removing smog pump in 73 fbird
subframe connectors
Why not as much power??
v6 Cherrybomb
trans. swap
1998-2002 Firebird/Trans Am
86 firebird rear end
4in catback
is there a good chip out there?
Posi???
Built For Boost But Not Boosted.
what next?
Manifold Replacement
help !!!
Help with Rear-End
powerglide in my 81 camaro?
Programmers
94 v6 camaro needing help with specs
Rear Gears.....?
454 in 86 bird
383 stroker quetsion
just headers?
94 Camaro Big Block Swap
Which Pontiac heads for more compression?
too cheap of turbo?
cat back exhausts??
Computer Chip
Gears?
'86 exhaust on '85 car make a diff?
nitrous pressure guage
buying parts online
most bang for my buck?
1977 camaro
ls1 in iroc ?
What muffler?
Ignition
kn intake???
launching an automatic
71' Buick 455 in 79' trans am?
3.4 L v6 camaro looking to upgrade..
turbo/supercharger
Muffler on a 2.8
powerdyne?
LS1 injectors in TPI???
Possibly a LT1
Exhaust suggestion?
Engine Rebuild / How do I go faster?
Lingenfelter Cold Air Intake?
Aftermarket LS2 parts
brake swap
TBI to carb conversion
street avenger vs edelbrock
exaust question
Are V6 Camaros Fast??
I am no longer going to use Mobil 1 oils
98 v6 power adds
Edelbrock Headers
Programmer/Tuner for v6
Shift kit improver or transpak
1996 3.8 Stainless Valves
Diff. Between WS6 n Trans Am
camshafts
01/02 Differences
