Chevrolet
Avalanche | C&K | Silverado | Suburban | Tahoe
> C/K
View Full Version :
C/K
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
95 k2500! No brakes! Help please!
Overheating!!!!
93 K1500 5.7 running rough
Roaring/road noise under floor
95 Chevy 1500 (Steering Column Shift)
1990 chevy 1500 4.3 issues
Engine won't switch to closed loop, need help
'92 4.3l power problem
rear diff fluid frothy?
need confirmation of my thinking
Chevy shifting problems
putting transfer case in neutral?
Another P0306 Misfire Problem
fuel pump
Power loss and backfire 5.7
5 speed manual trans problems
electical problem 89 pickup
Intake Problem!
1994 K1500 5.7L V8 AUTO- I screw'd up
loud knocking need help!
1994 C1500 help
Going insane!!
96 1500 Z71! Leaf Spring Swap?
Easiest/Cheapest way to lift a 96 Z71?
Tranny problem on 1990 C1500 with 700-R4
Using older 350 engine in 1991 K 2500
96 chev pu lacks power and surges
Turn signal makes wipers go
4l60e shift issues after rebuild
hard to start beginning of day
HELP!!! 1999 chevy truck
TH400 Advice
4 wheel drive does not work
New Starter Bad?
modding a 4.3
will a1995 4.3 interchange with a 1993 4.3
95 1500 4x4 rear end noise
97 K1500 electrical problems
93 3/4 ton pinging
p0171 and p0174 codes
1991 wont start..motor from 1985 no spark HELP
Engine Still Not Up To Temp
89. C1500 dash warning lights not lit up
89 C1500. Dash idiot lights
1997 k1500 gmc erratic speedometer/tranny shifts
Need to vent
97 4.3 won't start.
4l60e gone nuts
Chevy spindles
K2500 gvw
89 K1500 no brake lights, no hazard lights?
4L60/700R4 tranny rebuild
Missfire in 97 1500
97 5.7L Z71 Alt/Batt Question
1998 Chevy 1500 wont stay running
No right turn
Grille Swap
Steps for replacing a distributor?
Fog Lights
speed-o & radio problems
94 Z71 running rich
4l60e no 2nd gear
Installing stretch belts
Dual battery setup question
83 gmc c20 parts
91 chevy open diff swap to posi lock
88 4.3 cooling fan
'88 K1500 speedometer/Code 24/RWAL code 9
Better Fan Clutch
95 problem
Missfire Ugh.... 5.7 Vortech
1994 Chevy K1500 Screech
why does my grille differ
The dreaded COOLANT leak!!!
Receiver Hitch
Random Misfire, 98 K1500 5.7
1995 Chevy problems
1991 C/K 1500 Startup problems
'88 K1500 Won't Start
Performance questions
disturbed distributor
brake problem
Engine Bog, No acceleration~ My Fix
Removing Truck Bed
Starting Problems
rear axle bearing and seal replacement
1996 C1500 Stall in drive
fuel pump tester
1992 no headlights until it heats up
Coolant loss issue 1998 5.7
Vortech Fuel Injectors
no 4x4 it;s bad
1990 K1500 Rear brake failure??
Spindle nut torque spec
Distributor problem
1998 5.7L starting problems
Exhaust Question
Good samaritan loses.again
89 4X4 problem no 4X4
Oil pressure sending unit
1997 chyenne 350 heater/air problems
I need an intake manifold
Dual fuel tank selector
89 5.7 timing
popping from the carb..
which holley carb?
coolant puddling on intake
97 1500 doorlock actuator
Tranny swap...
1997 Z71 transmission OD and 3 rd slipping
Died while driving
low power at high rpm
Help!!!92 k1500 swap
Anyone have any prodction numbers for 1998 C/K?
92 k1500
diff swap
83 350 won't start
Valve Stem Seals
1992 tbi 350 won't idle
94 z71 how do I know when I have a bad fuel pump
Front axle leaks
vibration in rear end.
Sliding Rear Window Latch
Bowtie emblem glued or bolted?
98 K-1500 noise...
Front drive shaft spinning
Headlight warning buzzer 1991
1993 K2500 Heater Issue
Have a K1500 v6 4.3L... what kind of MPG can I expect?
k1500 350 V-8 shudders at idle
1990 chevy ck 1500 loses power when wet out
1994 K1500 4.3, 5 speed manual popping out of gear
K1500 recalls
U-Joint or Rear End Noise?
missfires
Horn location 91 Cheyenne C1500
90 Chevy 2500 Pickup Will Not Idle Hot
Cat off my Suburban
'89 Suburban factory lug wrench
90 chevy 1500
95 k1500 4x4 wont engage
89 K1500 starts then stalls
86 c1500 fuel gauge
91 C1500 4.3L Possible Bad Fuel Pump?
88 k1500 350TBI I'm puzzled!!!
'89 Suburban timing
88 chev 5 speed trans
Coolant flush/replacement
Reverse lamps inop
Please Help!
Pesky Oil Leak
'89 C1500 front wheel bearings. Drift size?
low voltage fuel pump relay
4L60E transmission slipping
'98 K1500 Heater - All or Nothing
95 k1500 wheel driver side wheel
lug pattern
97 K1500 Exhaust Options?
2nd battery in 1997 k1500
1997 chevy C1500 5.7L low humming/vibration
95 k1500 305 problems
93 c/k 1500 v6 heat not very hot
u joints on drive shaft
Light Bar???
Temp At 240 Please Help....
96 K1500 wont start
1988 Chev PU Clutch problem
2000 K2500 Brake problem
4.3 Tbi oil pressure
5-Speed manual Transmission Fluid Type
HELP! Bad transfer case???
will the frame from a 1989 chev halfton fit a 1987 body
new motor with timing problems
synching crank sen.& cam sen.99 5.7 vortec
Cigarette lighter fuse keeps blowing! Help please!
Transmission
loud clunking in the front end
Smoking is worse after valve stem seal replacement on a 350 V8
Does a GM oil pressure switch serve as a fuel cutoff ?
Muffler suggestion 91 Silver k1500
1996 gmc 4.3 distributor phase issue need help
Engine Help!!
94 need help
Mode door will not work
Extremely wierd hesitation at low rpm
Surging while A/C is on
Fuel Pressure Test 1998 5.7
6 lug rotor application?
1999 express van is back
AC and Heater Control Problem
1982 C model pick-up diesel V8 6.2 L Transmission Reverse.
90 2500 Speedo Woes, Reads Nothing, low or Erratic.
Brake Booster adjustment???
Changiong the antenna on a 88 Chev PU
strange vibration??
timing/ backfire issue
Just Can't Figure It Out?
Manual trans fluid
1996 K1500 - 4.3L engine is missing - any thoughts?
1980 chev with no power
350 won't start...sometimes!
Engine miss(stutter) in passing gear
Tach
Speedometer
1994 c1500 wont start
New 98 5.7 stalls when stopping
98 Tahoe 5.7 - Compression Test
Misfire has me puzzled?
K1500 Maintainance and Efficiency Tuning Guide needed
A/C problem
Tail lights
94' k1500 starting/electrical problem
97 K1500 Z71 Head Gaskets
1998 1500 w/tilt ignition cylinder replacement
'89 k2500 4x4 blowing 4wd fuse
headlight switch diagram needed
96 c1500 4.3 vortec rotates but does not start
98 Z71 not shifting
!!!!!!1997 c1500 5.7L making weird noise!!!!!
99 Suburban wont accelerate
1995 Chevy 2500 keyless entry
A/C and Shifting
'91 C2500 keeps blowing fuse
Bad lifters,adjusting valves....
2001 Chevy 1500
88 chevy truck IAC valve replacement
97 chevy 1500 rear springs/lift kit
Fan Connection behind Glove box
93 to 94 motor swap
350 carb/fuel problems.
Hydraulic brake booster leak
93 1500 4x4 4.3
98 Z-71 Problem - Please Help!
5.7L misfires
Distributor
C1500 tire size?
90 454 TBI hesitation and boggs
No driving rear tail lights?
91 GMC K1500 Won't Start
1996 K1500 abs problem
Curios?????
4.3L 93 c1500 Misfires and backfires
Valve issue?
fan clutch
97 chevy p/u tranie problem
