View Full Version : Intrepid
- 2002 Dodge Intrepid SE anti lock brakes?
- 04 Intrepid w/2.7l V6 will not start
- shifting
- 1999 intrepid oil leak
- Rear timing cover leak repair - need your help!
- 1996 intrepid won't read for emissions
- 1998 Intrepid -[Motor will not turn over}no start
- Blend door actuator electrical testing
- front door panel help
- 99 intrepid 3.2 wireing issue
- 2002 intrepid 3.5
- 1995 engine codes
- 2002 dodge intrepid wont crank 2.7 l
- intrepid is possesed
- Intrepid 2004 battery light comes on/battery alternator good
- Transmission Range Sensor
- drivetrain vibration mystery
- Help! Engine/oil problems
- Changing thermostat on 98 Intrepid w/3.2L
- dodge interpret 2004 car problems
- 04 intrepid wont start
- 2000 Dodge Intrepid problems
- 1998 Dodge Intrepid
- 2004 Dodge Intrepid P0172 Running Rich Problem
- Service manuals
- Cel emissions fix
- Intrepid battery removal
- serpentine belt
- 2002 Intrepid hvac fan operation.
- 2002 Intrepid shifter stuck
- engine swap what to chamge
- White Exhaust Smoke
- Small Engine Jerk, help!
- ignition referanc singal car run stalls restarts
- 04 intrepid
- Cruise Control Stopped working
- No Heat
- Intermittent warm starting problems
- 1999 Dodge Intrepid 2.7 Lost Ground
- 93 Dodge Intrepid wont start
- looking at 95 intrepid
- 1999 Dodge Intrepid Running Hot
- ac and electrical confusion
- a/c issue's
- Crankshaft vs Camshaft.? or Both
- 2003 to 2000 engine change
- 1996 Intrepid lower suspension bushings
- Transmission Code P0731
- Rear Main Seal or Crank Case Seal?
- electrical problem help me!
- 1998 intrepid 2.7 o2 sensor
- 1998 dodge intrepid
- '98 Intrepid 2.7 bad computer
- 97 intrepid electrical issue?
- rear main seal replacement
- Having 3.5L spark plugs in a 2.7L engine.
- Misfire help on '01 SE
- I need help....
- 3.5 Harmonic balancer removal is there a trick?
- engine mounts...3.3v6 intrepid
- over heating issue?
- 2.7 to 3.2 Engine Swap Question
- 95 Intrepid 3.3l can't accelate please help
- Quick Question - Wiper Control Knob
- Valve Lifter
- Spare Key
- Important!! new questions 1994 intrepid 3.3v6
- 2004 3.5L Intrepid code P0016
- code number p0441
- 1994 intrepid
- 94 intrepid washer reservoir
- 1999 Intrepid random stalls
- 99 Intrepid belt and radiator questions....
- Drive cycle after computer reset on 2002 RT 3.5L?
- 2001 intrepid shifter problem
- 97' Intrepid, turns over but will not start.
- 1994 Intrepid dash lights not working, won't start
- help needed intreoid 2000
- 96 Intrepid EGR valve meltdown
- melted coil pack
- help my car is stalling
- 1994 Intrepid suspension part name
- 2002 2.7L Intake manifolds
- 97 Intrepid 3.3 Sub Frame Bushings and Mounts
- Air Conditioner stays on.
- 1994 dodge intrepid wont start
- 2000 intrep. revving out of control
- 2002 Intrepid
- 1994 3.3 leaking fuel out of exhaust
- 2002 Intrepid Transmission
- 1994 Intrepid Stalls at 2 rpm...
- 94 3.5L Rough Idle, No codes or MIL code 12
- dodge intrepid 1999 3.2
- Right front bounces when accelerating
- fuel pump problem
- 98 Intrepid, 3.2 water pump replacement
- V8 Intrepid
- Need new 2.7 engine for 99 intrepid
- torque specs ????
- Someone Help Car Died
- 94 intrepid speedo not working. not vss
- 96 Intrepid won't start
- 97 intrepid over heating problem
- 94 Intrepid, losing power, gas mileage, tranny
- 96 Intrepid rack and pinion steering mount bushings
- Oil light blinking
- 1999 Intrepid blower motor resistor
- 96 Intrepid ES - Ticking noise
- 2002 Dodge Intrepid 2.7 L Electrical Issues
- 99 intrepid overheating......PLEASE HELP
- help please
- 98 intrepid keeps losing charge
- 2000 antilock problem
- 2.7 high and or rough idle
- 99 dogdge 2.7 timing help
- What is this????
- no headlights/turn signal switch problem
- 96 intrepid cv shaft removel problems
- 99 intrepid 3.2 timing belt
- 96 electical problem (i think)
- 95 trouble codes
- Intrepid Struts Replaced
- 1997 intrepid dies
- headlights
- 94 Intredpid runs for a while then dies
- Engine swap problems .
- 96 3.5 motor into 2001 Intrepid
- alternator or starter problems on 96 dodge intrepid
- 2003 Dodge Intrepid engine swap question!
- 98 Intrepid A/C heater fan
- 94 Intrep Key won't turn
- 1999 intrepid tranny problems
- 94 Intrepid - Intermittent Turn Signal
- Location of Trans LR Solenoid Valve??
- 02 wont shift into OD? help please
- Questions On A Driveline Swap
- pls help with my 97 intrepid
- 1999 Dodge Intrepid 3.2L 24 valve SOHC timming process and tools needed?
- 98 intrepid no spark.
- Auto shutdown relay problems on 98 intrepid 3.2l?
- 1998 intrepid 3.2 Heater/AC
- Front coolant leak 2004 2.7L
- HELP Please 99 2.7 won't start
- Please help me with this!!!
- 00 Car. advice please. Rod bearings
- transmission
- 94 Intrepid Limp mode?
- Brake Caliper and Knock Noise solved, sort of!
- 95 Intrepid EGR Valve
- I need help bad!!!!!!!!!!
- 04 dodge intrepid wont shift out of 2nd gear
- Everyone knows the 2.7 is junk do something about it
- 99 intrepid a/c question
- 94 intrepid radiator fan fuse keeps blowing
- 95 Intrepid Tranny Issue
- 1998 Intrepid- Alternator location/replacement
- 1995 intrepid 3.3 bad missfire
- 1995 Dodge Intrepid
- Expected VSS connector voltage
- Entry System
- major and chalenging problem with my 1998 intrepid
- 04 Intrepid "jerks" when accelerating (3.5)
- 96 Intrepid ES - starting issue
- 2002 intrepid oil sensor location?
- 1997 intrepid gauges
- 97 Intrepid 3.5 coolant leak
- 1997 Dodge Intrepid 3.5L what side is bank one?
- 95 Intrepid. Stall, no start.
- 97 Intrepid starting problems
- 1998 Dodge Intrepid Turn signals/flasher Not working
- 1998 Dodge Intrepid - Window, Turn Sig Problems
- airbag light has gone crazy
- 02 Intrepid 2.7L swap 2.7L seabring
- Intrepid motor change
- Need a little info
- 2001 Intrepid 2.7 has no compression or spark
- 97 intrepid oil light on at stop light
- Its Electric!!????
- Serpintine belt Question
- Chrysler 3.5 Intrepid
- 95 intrepid factory stereo amp
- dosent run great now
- fault codes
- runs great now
- difference in intrepids?
- running like crap
- 2001 intrepid
- Compression Test?
- 02 Intrepid 2.7l to 3.5l conversion help
- Car Jerking please Help!!
- stability issue 2000 intrepid
- 96 Intrepid 3.5l fans always running
- problem with harmonic balancer
- rev limiter kicking in too soon
- replace starter on 2000 intrepid
- 2000 intrepid no start
- 1996 Dodge Intrepid ES 3.5 Liter Starting Problems, turns Over
- horrible gas mileage
- Looking for an electrical expert - 99 Intrepid
- 2004 intrepid dies
- 2001 Intrepid Washer Fluid issue
- 98 dodge intrepid 2.7 v6 stalling
- 2000 Intrepid 2.7 Spark Plug problem
- 1997 Intrepid Won't Cold Start
- fan problems
- 94 intrepid trany limp mode when turning left
- 2000 Dodge Intrepid Ignition Switch
- Bosch Titanium +4 spark plugs
- 2003 intrepid wiper motor or switch problems
- COMPLETE LIST OF PARTS 1998 2.7 Intrepid
- Code P0340
- 2000 Intrepid electrical issues
- 2000 Intrepid oil light comes on at idle
- 99 Intrepid ES - bump shift in Transmission
- Blew my 2.7, what to do?
- oil light on I need Help!!
- 96 Intrepid 3.5L Wont Fire!!!!!
- 2.7 issue 1998
- help!! 02 Dodge intrpied wont start now that its cold
- 2002 Dodge Intrepid - my heat stopped working this morning!!!!!
- 94, 3.3l, hasn't run for 1.5 years
- 01 Rt
- dodge intrepid 1996 problems!
- 2003 intrepid electrical issue
- 2000 2.7 ticking issue
- 1996 intrepid problem
- How is it possible?
- Intrepid 1995
- Transmission problems. Have codes.
- Shuts down
- Where is the bcm on a 99 intrepid
- 98 Spitting and Sputtering
- 98 Intrepid heater problem
- 2000 Intepid has 4 codes pulled
- Blower Fan Module
- heater setting low/med/hi prob
- 1999 2.7 Water Connector
- Heater blows cold
- I am 1/2 way through my engine transplant.
- 98 Intrepid Grinding noise
- Transmisson Issue
- 95' Intrepid tranny problems
- 1999 intrepid motor change
- 2001 rt clock spring
- Starting Problems
- 1994 dodge intrepid stalling
- is it possible to put a corvette engine in a 02 intrepid
- Power seat removal
- How do you make a 2.7 v6 last?
