View Full Version : Intrepid
- 2002 Intrepid Side Mirror Switch Help
- 97 Intrepid 3.5 L Stalls Intermittently
- Cooling Question
- abnormaly high idle in park!!!!!!
- A/C not cold
- 2000 intrepid want start
- 2000 Dodge intrepind engine ?
- 2002 Intrepid A/C Blows cold on drivers side only
- Power windows on 96 Intrepid
- 94 Intrepid
- Exhaust Leak?
- 96' Intrepid "ELECTRICAL"
- There should be a recall on 2.7 engine
- break & air bag lights stay on
- Help! problem with check engine light trasmission codes
- 2002 Intrepid electrical (blower and overhead lamps)
- Knocking noise when hitting breaks
- PCV Valve in 2001 3.5L Intrepid
- 2001 Intrepid
- 2003 dodge keyless entry
- Engine surges
- 3.5 stalls when stopping
- Intrepid Suspension problem....i think...
- adding keyless entry
- Interchangability of Speedometer (i.e., Custer) Assemblies for 2000 Intrepids
- 1997 Steering wheel catches fire
- Possible solution to make Chrysler fix 2.7 engines
- Overheating Problems?
- 3rd to 4th gear slippin'
- 2004 Intrepid ES - General Opinion
- 2001 Keyless Entry
- question about shifting gear
- intermittent starting problem
- fuel pressure
- Intrepid 95 cruise control not working
- Inner Tierod Bushings
- Air Bag light -- '96
- 2000 Intrepid - Blue Smoke, Oil Light
- Hood struts don't work
- Crashed My Intrepid Have Questions
- How to remove front bumper Intrepid 95
- Repairing Magnetic Pick up
- 2004 dash lights
- Wanted Intrepid w/blown motor
- 96 intrepid
- How difficult to replace timing chain -2.7?
- check engine light
- 1998 Dodge Intrepid 3.2L Engine Problems
- 2000 Int wont start, running out of options...
- Intermittent electrical problems
- How Do You Repair A Dashpanel With A Blown Airbag
- 2000 Intrepid - Dash Panel - Main Wiring Harness - P04759892AB
- A Silly Question: Break Fluid
- need help buying
- Won't start, flickering lights
- My dodge intrepid 99
- Help
- 1995 Intrepid fans runs all the time. Anyone help?
- 1997 keyless remote
- What is the procedure to read / clear the Check Engine light on 96?
- 1997 intrepid inquiry
- 99 intrepid engine switch 2.7 to 3.2
- 95 intrepid ES trans problems
- 00 Intrepid knocking
- BCM trouble
- Turn Signals
- Intrepid stalls on highway
- 96 Engine Surges
- question about tires
- Voltage problems
- Blower Motor always on.
- Trouble Code Help
- Engine Trouble
- Screaming 02 Trep
- Help Sick trep
- Remote Radio Switch '01
- Whistle/squeal with throttle when cold
- electric -blowing fuses.
- '96, R. Front thumps bad on bumps.
- What will fix this?
- 96 tranny acts funny cold
- Is This Normal???
- Battery, Alternator or starter?
- headlight replacement in a '93 Dodge Intrepid
- Need help replacing passenger mirrors
- 02 ES heat and A/C air STINKS!!!!!!!!!!!!!!
- Body Control Module Switch
- Have 1994 Intrepid for parts complete.
- Reverse problem on '93 Intrepid
- 95 dodge intrepid is stalling
- Informative Material
- oil light coming on 2001
- "LIMP MODE" 93 intrepid
- 94 Intrepid - Air bag light, A/C, and more
- need a 3.2L engine
- 99 Intrepid Oil Pressure Problem Need Help
- 98 intrepid starting problem
- '93 control arm won't budge
- Door Locks for a 94 are they hard to change
- 2002 3.5L Stalling Problem
- 93 screwy trany
- 99 Intrepid keyless entry control box
- 42LE Transmission
- Flasher Replacement
- 93 Noisy Doors
- 99 Intrepid TDC for Timing Chain Replacement
- 2000 intrepid dying
- headliner
- communication erros
- Intrepid Belt and Hose Change
- 96 Intrepid computer problems
- Super Nice '02 Intrepid R/T for sale
- Flickering dash lights
- waterpump on 99 intrepid
- changing a stereo for a 97
- 94 intrepid hard down shifting
- Intrepid 2000 engine light just came on
- stereo removal 2000 Intrepid
- '97 Intrepid transmission problem
- 99 intrepid Timing Chain Problem
- 1999 Intrepid Heater a/c fan resistor location
- Here we go again. Error codes 1694 and 1391
- How to check fuel pressure
- Tranny Cooler lines
- Transmission problems
- ALT / PS belt change
- Help! 96 ES dies when shift into gear.
- Take a look at my website
- Help - Ignition lock jam
- Questions on modifications to my 1997 Intrepid
- 3.3L Intrepid Engine Interchangable?
- 01 with a knocking noise
- Fuel pump?
- 2004 intrepid starter makes grinding noise during start
- troble code p 0551
- Blinker trouble
- all kinds of parts for sale for 99 Intrepid
- code 11
- Ignition problem?
- Error code P0172
- 2001 Intrepid R/T Wiper Switch?
- No speedometer
- Infinity System
- Vibration Passenger Front (96 Intrepid)
- Door locks -- 1996 Intrepid
- Stereo 1996 Intrepid
- 97 intrepid - Blower resistor replacement ( How/Where)?
- Where is Camshaft Position Sensor in 04 Intrepid SXT?
- Timing chain tensioner changed now will not start.
- replacing egr valve on 3.5 97' Intrepid
- looking for 04 Intrepid Body Kit
- 99 Intrepid hiccups/stalls when tank full
- 94 Intrepid probs
- dodgeintrepid.net
- wiring diagram
- 99 trunk release schematic
- Code 72 (Cat Conv Failure) on 1997 Intrepid 3.5L
- glazed over headlights, 99
- 97 3.5 Intrepid code 21 & 17 -??
- Won't Start
- 96 Intrepid electronics
- How to replace the blower motor on 93
- fuel filter on a 98 Dodge Intrepid
- Trouble codes for all Intrepids 1993-2004
- 94 Intrepid strange transmission....
- crooked intrepid
- 1996 Dodge Intrepid blown start/run fuse under hood
- whiper problems
- Prevention and Solution Questions for 99' 2.7l INTREPID
- how do i take off air cleaner??
- Headlight bulb replacement
- 1997 Dodge Intrepid - Where is the EGR valve located?
- 2000 Intrepid - 2.7 L - Running Cold
- Class Action Suit against Chrysler
- missfire detected in cylinder six on a 3.5L
- replace infinity amplifier
- 2004 Intrepid Stall and Check Engine Light
- 2001 Intrepid R/T stalls when slowing down
- Headlights
- Spark plug wires
- i need code help
- 2000 Intrepid engine stalls when turning right!
- Intrepid 2.7 to 3.2 swap
- oil light won't go out
- 02 Intrepid ES heating system sucks!
- 02 Intrepid ES Auto tranny woes
- 2000 Dodge Intrepid , Help
- Power Loss on Acceleration and check engine light!
- Intrepid electrical problem
- brakes
- Dash Lights
- 1997 intrepid will not spark or trun over
- Suspension question
- how do i install new turn signal flashers in a 1993 dodge intrepid?
- Does anyone know about the radio antena?
- Short Circuit
- trunk stuck
- Infinity Amplifier location
- 1994 Intrepid Radiator fans wont come on
- HELP!!! CLAMP & CRANK SENSOR
- 99 Intrepid - Convert Kilometers to MPH
- 99 Dodge Intrepid in wreck
- 2.7 owners
- '98 Intrepid has intermittent start problem
- possible bad fuel pump
- On the freeway going 0mph
- car battery??
- 95' 3.5L Interferance engine?
- having problems
- I have a 98 intrepid and interior blower wont stop
- 97 Intrepid Cold Start Problems Help!!
- map light bulb???
- Brake Lights on 2000 Intrepid
- Intrepid will not go into gear until warm
- what's your idle speed???
- cold tranny
- my bad tranny
- Can't get 1999 Intrepid out of park!
- Does anyone know how to program the keyless entery for a 94-95 dodge intrepid?
- The truth about oil
- 1998 Intrepid won't start
- electrical diagram someone???
- '96 trep 3.5L T-Belt
- windows wont defrost
- Tranny
- 2.7 dodge intrepid class action lawsuit
- 99 Dodge Intrepid 2.7 misses at idle
- radio removal/installation
- Starting Problems
- oil pressure light
- Infinity-right side good,left side bad ???
- Intrepid won't start $#@*&%&!
- Leaking
- Too much torque?
- My Intrepid Problem
- Engine stall when slowing down
- 2002 Intrepid
- 02 Intrepid needs new tranny.
- low fuel, air bag, gear indicator ligth coming on, no reazon
- intrepid 97 3.5 ltr
- 1997 Intrepid Blower not working, blown fuse
- 1997 intrepid radiator --- does it have a drain
- 93 Intrepid wont run????
- Parking Brake Indicator Light Problem
- 96 Intrepid Won't Start
- 1998 CV Joint replacement problem???
- Standing up against Dodges Intrepids
- need performance?
- need new rotors 2002 intrepid
