View Full Version : Sebring | Sebring Coupe | Convertible
Pages : 1 2 [3] 4 5
  1. more hp
  2. 2007 Sebring trunk latch
  3. 1997 Sebring coupe transmission problem, help pls !!!
  4. Sebring Dash Lights
  5. Chrysler 1998 SebringTransmission down shift
  6. 2000 sebring no bus ccd
  7. 2002 sebring lx noise from back
  8. Driving problem
  9. Replacement of Crank Sensor in a 1999 Chrysler Sebring JXi Convertible
  10. 2006 Sebring Touring sedan
  11. Headlight Replacement
  12. BIG help help please
  13. another 1998 lxi conv. not starting!
  14. removal of door panel
  15. Spark Plug Popping Out
  16. 2000 Chrysler Sebring fan switch help
  17. Mpg
  18. 1996 Sebring Convertible Has A Mind Of It's Own!!
  19. brake light
  20. 1998 sebring jxi convertible cold weather p/s noise
  21. underbody shields?
  22. i need serious help with this
  23. 2001 Conv - RPMs All Over The Place - Engine Revving
  24. 99 Sebring JXI brake light problem
  25. speedo is way off and tranny problems
  26. Keyless remote
  27. 97 sebring convertable top wont open / close
  28. digital odometer turned off and rpm isnt working either
  29. 2001 Lxi Coupe Transmission noise when cold
  30. I need a little expertise here....
  31. 2001 Sebring LXI Opinion Needed
  32. Glove compartment
  33. 1998 Chrysler Sebring LXi Coupe stalls makes weird noise in park or at low speed.
  34. 1998 Chrysler Sebring LXi Coupe stalls at low speed.
  35. Problems with Remote Starter Installation
  36. I Ran Thru A Huge Puddle And Now My Car Wont Start
  37. Removing a thermostat
  38. New Transmission Problem not already listed
  39. Heater AC and Lights Problems
  40. Creaking noise coming from front tire wheel, help!!!
  41. 2000 chrysler sebring jxi convertible
  42. 97 Sebring Dash Lights
  43. Spongy brakes
  44. Antifreeze flowing when cold
  45. 2003- Transmission & radiator leaks FYI!
  46. Should I buy this Chrysler Sebring lxi?
  47. HELP ASAP! 2000 Sebring
  48. 97 Sebring convertible seat belts lock up
  49. timing question
  50. where is it
  51. 2001 sebring front grill remove
  52. oil change
  53. oil seal
  54. 2001 sebring lx front grill removal
  55. oil leak
  56. manuel trans sebring
  57. 1999 Sebring LXI engine noise when cold
  58. Radio Question
  59. very slow acceleration to 0 to 200 rpm
  60. Interior lights stay on
  61. 2004 4 Door Sebring Keyless Remote, How to Program?
  62. How Much..?
  63. Stupid question: where is the power amplifier? (1996 JXi)
  64. 2001 vibration 45mph+ when on accelaration
  65. 1999 Sebring door lock wiring diagram
  66. 2004 sebring Headlight Adjustments
  67. Convertible top adjustment
  68. 97 sebring!looking to cstm..
  69. 2001 coupe to 2003 coupe conversion, possible?
  70. question about the dashboard
  71. Head Gaskets?
  72. Can't find info on 1995 sebring transmission
  73. 96 LXI Problems
  74. 1996 sebring conv. remote fob
  75. Dual Exhaust Question
  76. Transmission Fluid
  77. Sebring JXI 1997
  78. 2002 Chrysler Sebring Brake Light on Corners
  79. 99 sebring convertible clicking sound
  80. 96' Sebring Coupe 2.5L Front Brakes
  81. 99 sebring conv. door sensor issue
  82. 01' LXI Conv. AC Compressor-DIY???
  83. 2002 Chrysler Sebring Sedan LX 2.7 v6 Noise?
  84. Help 2001 Sebring stalls
  85. help
  86. Siren Noise 2004 Chriysler Sebring LX
  87. 04 sebring LX
  88. HELP!! 96 Sebring JXi Convert will crank but not start
  89. 99 Conv-Blower Motor Resistor Keeps Blowing Out
  90. 99 Sebring Convertible - Won't start. Key problem, or part of the antitheft system?
  91. 96 Sebring Coupe Transmission Problem
  92. 2002 Sebring Coupe Remote
  93. Is there a mod to perform to allow the fogs on an 02 to light without headlights?
  94. Sebring Key Starts Intrepid
  95. 2002 Sebring Convertible CD player
  96. 1996 Sebring Program Door Lock Remote
  97. Heat core replacement.
  98. Convertible rim offset JX
  99. Problem with AC (Sebring JXI 97)
  100. 97 Sebring Conv Cooling Fan
  101. Torque manaagement disable? Ill affects?
  102. 1996 2.7L Spark plug change time? PLug brand?
  103. Dash removal
  104. 2001 Sebring LXI Power Window Problems
  105. 02 LX shifting issue
  106. Engine Codes
  107. p1698 code 2001LXI
  108. Recalls
  109. Stalling at 65mph!!
  110. Small Oxygen leak? New Gas Cap?
  111. Blown door panel speakers
  112. Headlight question
  113. Looking for advice on aftermarket performace for Sebring
  114. Cold Air Intake Systems
  115. Air condition Problems
  116. Help Me Install My Alarm
  117. Chrysler Sebring Facelift
  118. Sebring Convertible Radio
  119. 2000 jxi conv
  120. 96 sebring convertable
  121. 04 Sebring question
  122. Painting issue...
  123. 2000 Sebring Jx No spark
  124. 2000 JX Conv-Blower Motor Resistor
  125. I need to remove
  126. 97 Sebring Stuck rear window
  127. Please Help me
  128. 1996 sebring convertible right rear turn signal does not flash
  129. front pop or bagning wen turning full in reverse
  130. 2000 Fuel Filter?
  131. 96 Sebring hesitating and stalling intermittently
  132. Coolant Bleed Valve
  133. What's the deal?
  134. Window Leak
  135. grinding noise cold
  136. replace rear glass in 2000 sebring convertible?
  137. 97 sebring Lxi radio reset
  138. 2001 lx sebring
  139. Who has the link for the "how to" on replacing plugs and wires
  140. Air Bag Light
  141. Programing the Garage Door on the visor
  142. Factory Amp or Stereo Problem?
  143. deck light message where milage is
  144. Battery indicator light
  145. 98 LX Coupe DRIVER POWER SEAT
  146. How reliable are Sebrings?
  147. 1997 sebring JXI not starting
  148. 200 watt amp and a 10" subwoofer
  149. oil light
  150. need location of a sensor
  151. CV joints bad???
  152. 99 Sebring convertible...15" to 16" wheels
  153. DTC codes
  154. 180 degree thermostat
  155. Radiator drain plug removal 2000 JXI 2.5
  156. 1997 Sebring Conv Fuel Problem
  157. rear defroster
  158. 05 sebring performance
  159. 97 sebring Lxi, whats the biggest rim you can use
  160. 01 specs
  161. oil and grease spay leaks front wheels
  162. Replacing plugs, wires, and what else?
  163. Extended Warranty for a used Sebring
  164. 97 sebring LXI, tops out at 4000 rpm, should it top out higher?
  165. Trying to get more off the line,,97 sebring Lxi
  166. Air circulator insert
  167. Mystery Noise!
  168. Defroster wire broke off
  169. 2000 Sebring engine tick
  170. dropped q-tip down injector port
  171. car noise
  172. 2002 Sebring blower motor
  173. keyless transmitter
  174. Sebring Chrome Wheel problems
  175. there is a High squeling noise when i reach speed of 35 and 65
  176. How to Remove Sebring interior part
  177. Where the heck does p0161 mean
  178. 05 GTC Boot Cover
  179. 96 Sebring convertible rear window
  180. Cleaning the top
  181. 2001 Chrysler Sebring "clunk" noise near my feet
  182. audio system
  183. transmisson problems
  184. Sebring-locked steering column-can't start!
  185. 1998 seabring
  186. Won't start-steering column frozen-key won't turn
  187. Free Horsepower Mods??
  188. 98 seabring convertible top goes down but wont go up!!
  189. 1999 sebring crank sensor
  190. '00 Sebring Dash Gauge Light Problems
  191. something weird spark plug poping out?
  192. 98 JXI Convertible - Rear Tail Lights
  193. power windoe
  194. LXi battery
  195. engine surge - 2004 sebring touring - V6
  196. LXi Amp
  197. a/c problems
  198. Questions on semi-stick
  199. 03 LX spits & sputers
  200. Door makes clicking sound when opened
  201. fog lights
  202. Sebring LXi Pipe Size
  203. 1996 sebring jxi
  204. Anyone buy injectors from rockauto.com??
  205. Taillight
  206. catback exaust
  207. LXi Intake
  208. starts then dies
  209. 2001 Sebring LXi
  210. Water Damage
  211. A/C, Heater Blower Works only on High
  212. Need some advice.
  213. fog lamp and headlight brights problem
  214. Starting problem and rough running
  215. Sebring - Power Source/Cigar Lighter quit working
  216. Stock Speakers in a 2001 Sebring Sedan
  217. Radiator drain plug location.
  218. radiator drain plug location
  219. alternator replacement?
  220. Maintenance Advice
  221. Poor gas mileage, engine dies, rough idle, 98 JXI
  222. Radio Lights flashing after jump start
  223. 93 lebaron tranny problem
  224. 2001 sebring conv. - removing center consol
  225. 1997 sebring
  226. Watch out for rip off mechanics
  227. Help! 99 sebring convert. door /electrical problem!
  228. Help Installing A System in a 01 LXI
  229. Harsh downshift
  230. Boot for sale
  231. sebring with no power
  232. A few questions, need help
  233. 99 Sebring runs rough
  234. All lights flickering
  235. 2000 Sebring with a power steering noise
  236. 2000 Jxi- No Spark
  237. Struts
  238. Sebring Radio Problem
  239. Random Alarms___
  240. running out of gas??
  241. New Member To This Site
  242. Gas Mileage?
  243. Help with my 2001 sebring lxi please
  244. Sebring jxi 97 Idling
  245. 97 Sebring
  246. 2001 LXI Battery replacement and "squeak from front wheel"
  247. 20 Inch Wheels On A 2002 Lxi Sebring
  248. water pump replacement
  249. Fan Switch won't move air to front panels 96 (def & floor ok)
  250. What else can go wrong with my sebring?!?
