Buick
> LaCrosse/Allure
View Full Version :
LaCrosse/Allure
Synthetic or Conventional oil?
Help me with 2006 Buick LaCrosse 3800 engine.
2006 LaCrosse 3800 engine have to give it gas pedal to start when warm? No error codes...
2013 Lacrosse Backup Brackets Missing
2009 buick Allure Torque specs
2014 Lacrosse - battery/alternator problem???
Heating/AC Cooling Fan not working
2010 Lacrosse
rear axle question
2011 lacrosse cxl c/v ??
2008 Lacrosse 3.8 Series 3 timing job
2008 buick allure
2011 Buick LaCrosse CXL V6 - New Engine Needed
Temp gauge not working and Check Engine Light on.
click no start 2011 lacrosse
Torque converter.
Intermittent Overheat Problem.
2006 DIC - Oil Warning reset doesn't work...
Lacross Passkey III issues
ABS & Traction Control Sensor
Odd noise
2010 Lacrosse hard starting after fueling
2013 LaCrosse Throttle Body cleaning
Oil change on a 2013 LaCrosse 3.6 L
2005 Allure - Odd issue
2006 Allure - Heater issue
Oil filter coming loose
lacrosse engine
HID Headlights
Lug nut socket for 2013 LaCrosse
AC Delco Oil Filters
2013 LaCrosse cabin filter
2006 LaCrosse radio issues
Thinking about a used Lacrosse...thoughts?
2007 LACROSSE all guages are out
2013 LaCrosse techical literature
Tire monitors, 2013 LaCrosse
Front License Plate Bracket, 2013 LaCrosse
Key Fob Issue
2006 LaCrosse transmission slipping in 2nd gear.
2005 buick lacrosse cxs
Anyone bought a LaCrosse after a Lucerne
2006 lacrosse transmission fluid type
2008 Allure/LaCrosse wiring diagram.
2008 Allure/Lacrosse Dash air vents broken.
2007 LaCrosse door doesn't always close
2008 Lacrosse P0300 code runs but terrible
2008 Lacrosse 3.8L Stalls only P0171 code
2009 allure seatbelt warning light
2006 Allure
2008 lacross cxl power locks going berserK!
2009 Allure/Lacrosse console light
2007 LaCrosse rear end clunk
2012 LaCrosse spare tire?
2012 LaCrosse downshift???
Yet another issue
2 codes
2006 lacrosse water noise
changing headlamp in 2008 lacrosse
Replacing 2006 Lacrosse Grille
2012 Buick LaCrosse Quick Spin Review
2011 Buick Lacrosse TPMS
07 Lacrosse/Allure Caliper bolt torque
spark plugs
2011 Lacrosse Driver Info Center Problem
06 Lacrosse, DRivers door stuck?
2005 Buick Lacrosse
2008 Allure warranty period?
Hard upshifting on 05 lacrosse
How does one remove the reading lamp?
Installing AUX input on stock radio
onstar
cd player
Dash lights burnt
Buick Lacrosse
Lacrosse 3.6 oil level
Trim Removal (Below AC control)
Rented a Lacrosse......My thoughts......
GM Tire Inflator
Key Program
2006 license plate location
Change 2006 Allure Headlight
Ignition - starter issues
Changing Fuel Filter 2005 LaCrosse
Steering Control
2010 Buick Lacross unveiled
cupped tires an struts
2009 Dashboard Illumination: New Panel Avail. ?
AutoTap and 05 LaCrosse
2009 LaCrosse: Radio & Odometer Problems ?
Dashboard Illumination Level Very "Flaky" On New 2009 LaCrosse
New 2009 LaCrosse Sr. Citizen Owner Questions, Please
'05 LaCrosse CXS Major Trans issues NEED HELP FAST!!!
What the LaCrosse Super SHOULD look like
Does this car have electronic throttle ?
2005 Lacrosse power steering fill
2005 LaCrosse Minor Problems
Lacrosse Transmission Problems
LaCrosse driver info center problem
Keyless Remote Programming
buick air filter
upshift, too low rpm
Whirring noise from Drivers side dash
Do it yourself oil change on '06 Lucerne CXL?
2006 LaCrosse Steering
2005 Buick Lacrosse CX misc. issues
Allure: no complaints?
New and Old Members Please Read
LaCrosse CXS Body Lean
LaCrosse Power Steering Assist Adjustable?
Thinking of buying a LaCrosse
Not sure which one to get the CXS or the CX!
LaCrosse CXS performance?
Buick Lacrosse in severe wreck
III 3.8 liter
Recall Out Already on LaCrosse
Series III 3.8 liter Engine
Air Conditioner Always ON
Vvt??
No Lacrosse in Canada
Lacrosse Coupé
Cannot Wait to Buy One
