Chevrolet
> S-10
View Full Version :
S-10
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
4.3 Voortec Fuel Injection Setup
Engine Swap
96 4.3 no fuel pressure
95 S10 Ball joints
Co$t of a 400 Small Block swap?
Wide band or Narrow Band?
Erratice Speedometer
Slave/Master Cylinder connection
Tiny Electrical Problem
Fuel Level Sensor issue fixed
Engine swap
92 long bed with bad u-Joint
Possible heater core trouble ?
1999 Seats
1993 S-10 4.3L Starter Problem- ignition switch
clutch problems
96 s-10 blend door actuator
How to identify a replica Xtreme?
somebody help me out here please with torque specs
Vacuum Hose Routing
4L60e A/T compatibility
brake rotor(caliper removal?
engine swap
rear diff
automatic transmission problem in 2003 S-10
95 s-10 problems
Help Quick!!!!!!
2001 S-10 ABS and BRAKE light problem
i need a certified gm tech's help
Turn Signal Indicator
'86 S10 Body Mount.
02 S10 Ext Cab Advice
Engine codes
1988 S-10 Service Engine Soon Light
Something I've always wondered (about tires)
94 s-10 4.3tbi vortec Posi?
code help
s10 questions
Need help with understanding CA emissions
1996 S10 Fuel Press. Tester ???
94 S-10 Will not hold timing
2003 s-10 emergency brake problem
brake lights
lift
1989 S10 Fuel Problem
03 S-10 error P0101 AND P0420
Catalytic Converter Replacement
please help
S-10 Manual transmission capacity?
94 S-10 SS starting problem
Questions about 4-wheel drive vehicles
Door panel removal
91 S10 2WD 4.3L 173000mls
Brake Rotors
Squeaking coming from inside the dash?
1988 Chevrolet S10 Truck 2.5L Firing Order??
Rear End
2001 S-10 2wd 4.3 V-6 cam specs?
Oil Brands?
89 S10 4.3 neutral safety switch problem?
gas in oil
93 Blazer fluid question
quicker potential
WANTED Las Vegas Air Bag Installer
lowering
'88 s10 popping sound front while in place
Automatic floorshift for 97 s-10
Question
Please read!!!!
How many screws on a 1991 s-10 trans
When to replace timing belt
2000 S-10 ashtray installation
Knocking in the tourque converter or trans
Help with an 89 s10
Where is the ecm on 89 chevy s10
Will they ever recontinue production of the S10?
HELP speedo not working
2000 S-10 Blower Motor
Do all 2004 S10s have 4WD?
91 s-10 2.8 to 4.3 swap
The hood won't open on my S10!
Hall Effect Switch
93 S10 Engine?
2.2 to 4.3
schreechin noise
How much will a new coil pack cost?
What do you guys think about this???(rollpan questions!)
S10 problems?
How much air do you keep in your tires?
Can't find headlight relay
studdering on accel. only after heating up
S10 2WD lift kit?
96 s-10 headlights
Tire Change
replacing roller on a window regulator...
What do you call the new S10's now?
Question about the Quad Cab S10
Can't relase spare tire, '91 S-10
98 S10 Location of ABS Control Modules and Sensors
Throttle body gurus needed
s10 frames
89 s10 blazer 4x4 engine trouble help
1991 S10 2.5 liter - Unkown Sensor
What would you buy?
How to move tensioner
non replacable instrment cluster bulb??
1996 4.3 engine swap
Radiator drain?
Rocker Panel Kit
22's on a 2wd
oils
1988 Chevrolet S10 Truck 2.8L Firing Order?? PLEASE HELP
Not Sure
need a new alternator
What is a Pulse module and where does it go?
General S-10 rear end question
Upper Control Arms
MAF yes or no answers !!!
RPM Gauge reading high
Drum brakes
Steering Wheel not centered
2000 Chevy s10 surging 2.2l auto
96 S10 breaker blowing
98 s10 pickup. 200mA battery draw. help!
What is a plenum and what are poppet valves?
instrument panel bulbs
93 S10 will not Accellerate HELP
Please help! 91 s10 blazer 4.3 wont start!!
Fuse box
91 S-10 4.3L Parking lights not working
Which sensor is it?
broken steering column HELP
late 90's starter problem
Air injection pump 2000 blazer
98 s10 wheel fitment
rattle/grind coming from rear of tranny
Which tranny is in my truck? Borg or Venture?
HELP! '99 overcooling, 2.2L, 5-speed
2.8L Problem
Dropped Airbag Sensors - Are They Still Good???
Forum Rules! READ ME BEFORE POSTING!
S-10 alternator
1995 S-10 2.2 Starter engage
2002 s10 abs lights always on
86 2.8 V6 S-10 Choke Questions
2003-Shudder when starting from a stop
syclone question
91 s10 ext cab trans help
Radiator Air Bleed ?????
91 s-10 4.3 timing marks
83 2.8L 4x4 carb problems?
HELP - Removing Rear Glass on a '98 S-10
What size connecting rod bearing?
code 15 88 s-10 blazr 4.3L TBI
1986 S-15 Timing issue
dummy lights WTH?
stroker motor
96 S-10 4.3 X Tran removal
Looking For Information on U-Pull its in NJ
2000 S10 Evaporator Drain
transmission crossover
EGR circuit?
what are the best shocks?
97 S-10 A/C Help
Please help I have my truck apart now
Help! Loud Knocking Noise
Transmission problem?
new project
Rattle noise in 4.3L V6 VIN W
carrier bearing replacement
service engine soon
Ignition Switch problem
Transmission Component Slipping
anyone got a vacuum line diagram 4 a S-10
2000 S10 O2 Sensor Failing
91 s10 stalling/sputtering when warm
How do I replace my spark plugs?
1999 s-10 2.2L oil pan gasket replacement
Leaking Hose. Need help identifying hose.
Battery light
1998 S10 Wiper Problem
1997 s10 body allignment
turn signals only with lights off
1988 Chevy S10...Please take the time to read and respond
88 4WD s-10 Blazer vacum lines
fuel filter won't come off
? 92 S-10 wont run right until it warms up?
2001 Blazer Tires & Axle
Running lights on but headlights dead
4.3 to SBC swap
dipstick prob..?
91 s-10 putters on highway
Which sensor
89 S-10 died and won't start
Fuel Pressure
Hard to start 96 4.3
Dual Oil Filter Relocation Kit
91 S10 Code scanner wanted..which 1?
Newbie to Site and need HELP !!!
89 Speedo out
S10 PROBLEM.help
95 s-10 clutch problems
No spark on 91 4.3 Blazer
need an exhaust system
98 S10 Radio
radiator replacement
Chirping Noise
Echeck 98 s10
Exhaust for S-10 (Please reply!!!)
vibration in 92 s-10 blazer 4.3 Tbi
Timing chain...cost of repair
Oil cooler lines 93 S10 Blazer...
help with colors of A and b wire on assembly line datd link
97 to 98 conversion
what is happening
bed swap question
2001 Blazer Oil Drain Plug Gasket???
exhaust on the 4.3 engine
1989 S10 advice
door lock relay
The strangest thing happened to my S10 the other day...
91 S10 need computer for tune up?
S10 power
Reverse Lights
tranny leaking
92 4.3L TBI to CPI?
Hard to start 87
92 S-10 popping the hood - broken cable
How I replaced starter on 92 S-10 4X4 man. trans
Engins Shuts down when I put it in reverse.
1991 S-10 2.8l Vss
91 s10 blazer engine stumble
a/c compressor help
Vibration
1989 Chevy S10 / GMC S15 Modified!
94 passenger power mirror
EGR valve
Grinding in Steering Column
97 S10 won't start
s-10 won't start.
how to hook up stereo
134A Capacity of AC
2002 ZR2 Changing Headlight Bulbs
how would the LED's install for brake/turn signal
1994 s 10 blazer 4.3 cpi
Guage troubles on 1999 S-10
Recall Notice (#06202)
Motor vibration
86 s-10 still cutting out. IM LOST!!
91 2.8l v6 Fuel Pump randomly comes on
