View Full Version : S-10
- Lower Radiator Hose Removal, with Transmission Cooler lines
- 2002 s-10 clutch switch
- erratic idle, cold start
- 95-95 S10 Blazer question
- brake line replacement
- Timing Chain replacement?
- Please Help
- Bad acceleration at first then clears up
- have 89 s10 that has the brake light on solid on the instrument cluster.
- Crank Shaft Censor
- s10 won't start without gas
- Shaky Brakes
- Problem when idling
- s10 tires
- AC Recharge
- 1997 Chevy S10 2.2 Starts Then Dies
- 93 S10 Blazer brake pedal goes to floor slowly
- starter problems
- 96 S10 AC Issues
- no power to coil wire
- Moment and lifters
- o2 sensor
- oil burning addiatives?
- oil loss
- Brake problems 1999 s10 zr2
- 94 S10 CPI problems, Assistance needed
- 4.3 Vortec Dead Skip or Miss at Idle
- Parking brake adjustment nut - needed!
- Wont go into 4-wheel drive
- Please Help with starting issues.
- Transmission shift cable bracket
- Fuel pump part
- Need help removing third door panel (2000 Chevy s10)
- 85 S10 no start 2.5 iron duke
- getting gas in my oil?
- My chevy S-10 wont start
- injector poppett sequence
- s-10 rear end balancer?
- 1990 S-10 Tahoe Pick-up(2.8 engine)
- Flywheel turns but serpentine belt doesn't
- Engine bogs down at 39mph
- 97 4.3 v6 idles fine but chugs at 20 mph
- S10 350 Headers
- herrow, new here, with project
- s-10 fuel gauge pegs on full when key turned on
- 95 s10 power loss
- S-10 coolant leak
- 1991 s10 help
- please help me
- What is the spark advance supposed to be in idle for s-10 blazer?
- p0331 rough idel
- engine swap
- check engine soon light
- 99 s10 Ignition Coil Testing
- Dorman door hinge
- 1984 s10 keeps shutting off on me
- 4.3 TBI Fuel Pressure Test Questions
- 2000 s-10
- New Thread, Mar. 21, 10
- 2001 s-10 4.3 miss and p0300
- Keyless entry relay
- 1994 Chevy S-10 Idling extremely high...
- O2 simulator,
- Keyless entry Stopped working
- six month problem
- Exhaust Help Please!!
- 03 s-10 steering
- 1990 S-10 4.3L V6 Spark Plug Gap
- 4 cylinder vs exhaust
- 1990 S-10 floods itself
- 98 s10 idling trouble
- catalytic conrverter
- need more power
- VACuUM HOSES
- 92 s10 blazer no brakes
- (91 S10 Blazer 2wd) Using a offset/repair bearing on rear axle
- Which way is up? (head gasket, that is)
- 2002 Chevy S-10 4X4 encoder motor
- 88 4x4 front diff trouble
- 83 s-10 w/ 350 having fuel problems..
- Expansion/freeze plugs
- 1994 2.2 S-10. Doing rear main seal, questions on supplies I need.
- 1995-ish S10 Horn Fuse Number and Location... Need Help ASAP
- 1995 Chevy Blazer starting issue
- Door Handles
- engine swap 85 engine into 88 truck
- 4.3 idles way to high
- 1991 s10 timing
- 1992 S-10 2.8L V6 Idle Craziness
- Tach fluctuates 200 RPM at highway speed
- Steering Play
- s-10 wont start now
- Hello All
- 4.3 vortec power loss & won't go over 20mph
- computer fuse?
- frankenstein firing order
- Alternator stops working around 2800 rpm?? Replaced alt and still occurs! HELP!
- 2001 s10 wcode 4.3 misfire on 3 cyl..spider or reg?
- 1989 S-10 Blazer Wiring Diagram
- What size torx to remove tailgate "brackets"?
- blazer body on a truck frame?
- no power
- no power
- Trans prob on a 89 s10 tahoe
- 98 S10 4cyl. EGR Valve problem.
- '94 S10 4L60E no 1st or 4th gear, just rebuilt
- 2001 s-10 abs light and pulsating
- 94 s10 5sp 4X4 front axle
- ECM Fuse problems
- 85 4x4 transfercase vacuume probs
- 99 S10 Blower motor
- Stalling
- Lights on with ignition
- 1997 Chevrolet s-10 pickup
- Smoking out of oil filler tube
- 1995 s-10 wont start
- S-10 no start
- 1987 2.5L, 4speed manual, considering engine swap, trying to figure out best route.
- 1987 S10 Needs help!! Engine? Possible Trans issues
- wiring problems
- exhaust ?s
- Cap Swap
- 96 s10 no reverse
- 4WD will not turn on
- 95 s10 v8 shifter linkage and various ?'s
- Caliper replacement - Leaking
- 2000 S10 Blazer 4.3 burns up coils
- 91 Blazer Blows Smoke
- S10 oil pressure unit?????
- 96 s10 problem
- 1993 S10 Bumper mounts
- 1996 S-10 Turn signals?
- 95 s10 runs rough after rain shower/moist mornings
- Timing problem S-10 ???
- P0452
- 220 tbi running really rich
- loss of power at high altitude?
- 97 S-10 2.2 5spd White Smoke!
- stalling after replacing fuel pump
- Ford 9" and S10 question
- 1991 4.3 engine missing, low on power
- Bought an '85 S10
- Transmission interchangable
- 93 Grill on 84 S-10
- zr2 4wd quesiton
- any gm tecs on here?
- 03zr2 transfer case poping in 4x4
- S10 Rodeo
- 1990 4.3 starts then dies
- trans vaccume lines--and more, 85 s-10
- 2002 s10 p1860 code?
- 2001 Blazer 4.3 into a 1996 s-10 problem
- 2003 S-10 Radiator thread problems
- Open the bleeder
- Clutch fan replaced, so why?
- Oil level
- Reverse lights not working
- engine swap
- 2 Wheel Drive to 4 Wheel Drive
- Intermittent loss of electrical when trying to start
- turn signal swicth 93 s10 blazer
- 2000 s-10 steering shaft
- Pour coolant in, coolant gushes out(2.5)
- s/10 2.2 engine cross refernce
- a/c only blows under dash..
- 92 S10 have coolant leak
- Ball Joint
- 4.3 vortec ?
- Oxygen Sensor
- 98 S-10 2.2 no start
- Cleaning Engine
- 2001 s10 ac and heater fan
- 1999 s10 guessing fuel problem
- ac blower fan switch
- 87 s-10 4speed..loss of power when shifting into 1st gear
- 92 S-10 lifters
- Fuel Line for 2.8 engine
- headlights flicker
- Parking Brake
- 1995 chevy S10 2.2 engine
- Drive Shaft Lube Fitting
- Tempeture Gauge in 83 S-10 2.8
- wheel rubs a arm
- 83 Chevy S-10 2.8 Check Engine Light
- 4X4 BLZR - what is the thing under battery tray?
- Battery neg to Engine?
- How do you prevent Vapor Lock
- 2002 S-10 Aux. Power outlets
- 95 S-10 complete electrical failure(engine too)
- Ext. Cab Rear Driveshaft U-joints
- 2 Barrel Carb 83 S-10 2.8
- 1998 s-10 a/c help
- 2000 S-10 4.3L V6 AC Replacement Questions
- firing problem
- 1991 s-10 4.3 2wd
- 1999 S10 front brake caliper removal
- 1983 Chevy S-10 4x4 2.8 V6
- can anyone help?
- Alternator wire(s)
- 2.2 Head
- will not start!
- 2.8 to 4.3 swap
- Fuel pressure problem on a 2001
- Too many kilometers?
- Tips on installing manual transmission
- AIR Check Valves-- SES Light Back On
- 1994 s-10 4.3 5 speed 4x4 SWB
- Code 42 & 44
- 98 S-10 Rough Idle
- "00" s10 tranny P1870 code
- Frame Options
- 95 2.2 runs rough when engine is cold
- 87 S-10 won't start
- 4-Door ZR2 Pickup?
- Plastic Fuel Tank?
- 1995 S-10 4.3 won't start
- rearend swap
- 99 zr2, no sound from any aftermarket radio help
- Windsheild Washer Nozzle Replacements...
- The usual P0101 and P0410
- 2.8 Injectors
- low oil pressure after engine change? but oil pressure was 60 when pulled!
- ABS won't shut off 2003 S-10
- 1990 S10 2WD 4.3L Not getting fuel.
- S10 1996 won't crank intermittet problem
- ac problem
- 94 S-10 with no reverse in transmission
- S10 hard starting problems
- Dash lights,Tail lights
- Air filter
- Liquid sound after I start my truck
- engine swap, 98-99, smog pump hoses on headers??
- 97 s-10 no spark
- No Headlights
- Head gasket sealers
- 02 S10 wont start...................
- 2000 s10 extreme vibrations
- Need offroad roof rack
- For better results...
- 97 S-10 4wd won't work.
- tranny swap or engine swap
- 96 S-10 wiring harness in a 94 Model S-10
- 2000 S-10, ABS and Brake light issue - have codes, need advice!!!
- 86 S10 blazer noises
- Ecotec Swap?
- 4.3 Vortec
- ECMB fuse WTF
- 2001 s-10 service engine light flashing
- needing help diagnosing
- No heat
