View Full Version : Pick-Up
- '91 MPG seems low....
- 86 yoda turbo
- 91 Pickup Starting Problem - Just a click and whirring noise
- 95 pickup engine dies when starter stops
- 76 20R carb problems
- '91, 5-speed won't engage gears...
- crappy idle 89 22re
- 91 pickup electrical questions...
- 1986 22-RE Running Hot
- 91 SR5 pu has no power at all
- 5-speed swap
- Confused 94 Toyota P.u. 22re
- 22RE engine to replace 22RET
- 86 yota has NO power and won't start
- will a 85 or later cab fit on my 82 frame?
- 1989 Toyota Pick-up fast idle
- problem with pickup starting, not alt., starter, or battery
- my brothers truck. 87 pick up
- 98 Toyota Tacoma
- 86 Yoda Turbo Clanking Noise
- Brake booster problem, or gasket vac leak?
- 95 Toyota pick up timing belt
- new gas line to carberator
- parking / instrument lights stay on after rain
- disappearing oil trick
- Nothing will fix my Heat
- choke / fast idle not engaging when cold
- fixing up my truck
- Turbo question
- re: 92 p/u water in dash
- 83 4wd 22r / camber problems
- 92 p/u. water in dash.
- Gauges all died, and the air blower ('92 4x4)
- Need help removing cam gear from 92 V6
- Removing the bolt under the valve cover
- What fits what... 87 Toy truck 22R carb
- Parts for the 87 toy truck
- Heating Problem
- Head work on my 87 Toy
- 86 TOYOTA PU 22R ENGINE-will not idle
- nuts and bolts question
- Cd player install question
- 90 pickup 22R knocking! Plz help!!
- 1991 Toyota Question
- Check engine light after Oil change
- Bronze or Tinted glass
- 1991 pickup troubles. Ideas??
- Toyota Question
- 92 toyota pick up speed sensor problems
- front wheel bearing seal
- '91 Pickup Won't Start When Warm
- heater
- harmonic balancer bolt removal
- Transmission issues. Swap?
- 1990 Toyota Question
- 91pkup engine prob
- 91 eng prob, head gasket?
- crankshaft pulley bolt
- timming cover question
- 93 emissions connector?
- 1990 Head Gasket Repair
- open circuit relay
- Help!! water in oil?? negative liquid test
- Flowmaster
- '91 4cyl wont start
- 3.0 bullet proof head gasket????????
- 91 3.0 Liter engine swap
- power loss and check light
- 20R sounds like a lawn mower
- Rebuilt 87 22r motor problems
- 91 3.0 4x4 Starter Replacement
- Rear Main Seal
- '94 22re running hot
- front end rattle
- Leaking coolant
- 1984 yota fuel pump relay
- Cold Start Problems on 22R 2.4 Engine
- 84 yota problems.. any help?
- Ignition Switch 82' pick-up
- 86 yoda OIL IN CARB!
- 1990 Sr5 Shifting Issue
- 05 sentra headlights?
- 89 v6, which power steering fluid?
- 91 Head Gasket replacement
- R-12 to r-134 AC conversion on 89 Toyota 4x4 V-6 pickup
- 87 Toy Rebuild Kit
- 1985/86 toyota p/up blownhead gasket or a cracked block ?
- 85 buring oil
- what would it take?
- Fuel pump relay
- backfire...can n-e one help??
- trailer lights
- Thoughts on this?
- 1994 toyota code 71
- About to pick up an 82 pick-up
- Problem shifting 86 toyota pickup
- 85' 2wd pickup gone crazy
- 93 toyota valve cover gaskets
- questions about 22r/re/RET turbo swap
- 1994 blown head gasket?
- 89 v6 hard start (hot and cold)
- 94 Toyota Pickup Overheating
- Radiator HELP!!!!!
- Cheap way out (rear end)
- idle fluctuates when brake applied
- 22re coolant and oil problems
- My 89 Toyota 4X4 V6 pickup want start
- where can I find new face gauges for my dash please HELP!!
- Lifting 1983 Toyota Pickup
- How to tell
- 89 4x4 p/u 3.0
- Need Tacoma Advice
- '85 1-Ton
- '89 Toyota Pick-up "Fuel pump - Sending unit??"
- 1990 22RE Temp went to 3/4 hot, then drop to normal. Why?
- obd1 or obd2?
- 22re Gas mileage
- 1990 toyota truck problem
- 93 PU 2WD-Emmissions Label
- 4.3 swap radiator?
- Need help making the decision on 22RE engine swap
- 1983 Toyota pickup electrical issues
- 1987 toyota 4runner power windows
- Oil pump o-ring leak...
- How much
- 89 Toyota Pickup 22re Radiator Problem
- how do i get codes on 86 yoda 22r truck?
- Body Swap... 81 yota 4x4 to a 2wd body
- help 86 toyota problems
- Steering Damper?
- CD Player Installation for 1980 PU
- EGR situation
- 93 22re will not idle
- Missing Mirror
- removing bell housing bolts
- Losing coolant
- Bad park-neutral switch on 89 4x4 automatic pickup
- 1994 fuel filter location-help.
- Rigging relay to starter to overcome intermittent starting issue on 4x4 Toyota
- Park-neutral switch on 89 4x4 Toyota w/ intermittent starting problem
- Compression repair product for 89 4x4 V-6 toyota
- compression readings
- Bleeding clutch on 86 50r? truck
- 22re motor swap HELP
- Accessories for 2007 Toyota Hilux in USA
- Dumby lights driving me up a wall!!!
- Swap Help
- What is this part on an 89 4x4 V-6 Toyota pickup (xcab/deluxe model)??
- New owner with shock questions
- 1989 Toyota xcab V-6 deluxe pickup--starter
- 89, V6, Doesn't Start
- What have you done and what has worked?
- 94 22r idle high, brake makes idle fluctuate
- What should I do?
- 1989 Instrument cluster
- 86 Yoda, Coolant Temp Gauge
- Manual trans to automatic
- '89 22re won't start
- Speedometer noise on 1989 extra cab 4x4
- OD problem with 86 Toyota
- 1989 Toyota 4X4 4 speed SR5 pickup won't start
- check engine light
- Question about overheating, 86 Yoda Pickup
- holes in manifold?! input appreciated
- Which bed
- Idler Arm Replacement 86 yoda Pickup
- 94 pickup part out
- 1994 4x4 Pick Up Toyota
- 20R distributer points problem? truck wont start
- 86 4runner starting problem
- performance chips / ECM mods
- 22 r harmonic bal removal
- Thought I was a Mechanic!
- New Here, Questions!
- 22R running crazy.....help
- vsv locations 94 22re pu
- U-Joint help please
- metal pipes
- Interior for a 1985 Toyota Truck
- Pollution equipment on 86 22R
- Hard Start when warm.
- 1980 toyota pickup 20R engine
- 20r/22r hybrid rocker arm binding
- 3.4 Supercharged swap into 94 Pickup
- Parking Brake
- 22re quits after 7or8miles
- Wheel and Tires
- 86 toyota
- replacing 02 sensor
- no compression at all
- inner frame dirt
- water leak
- warm idle, or lack there of
- oil pressure gauge
- clutch pedal, to far forward
- asking price for 88
- 88 pickup, about asking price
- swap 22re for a 22r
- 1991 Shortbed - Should I buy this???
- 88 manual transmission
- 22r won't heat
- 93 4x4 clutch
- 88 22r fuel pump return problem??
- 86 toyota 4x4 (22R) Gradual Overheating
- tach wiring
- 22re rebuilt engine
- 88 Pickup/ how easy to fix/parts
- 1980 Toyota Pickup Parts?
- Problem starting 92 toyota pickup
- 86 toyota pickup 22r automatic electronic overdrive
- Will a 22re stand up to a small turbo
- 86 pickup w/ 22R temp goes to 220 initially then back to 190
- how simple fixes can ruin a day.
- carb adjustment
- 92 Toyota Pickup 22RE turns over won't start
- Speedometer Not Working When First Starting Off
- 95 Excab 6cyl 2wd code reader
- bleed fuel line?
- dimensions of the 3v
- Removing heater control assembly, 1984 pickup
- tranny
- New truck, looking for a little more performance and efficiency
- Vacuum Diagrams
- rough idle '94 pickup
- cooling problem in '94 pickup
- 93 toyota pick up 4cyl. knocking and squealing??
- Help me please?
- Idle keeps me cold!
- How do I remove oil pan 92 Toyota pickup?
- Toyota pickup audio speakers
- 91 22 RE spark knock problem
- 1986 pick up
- 22re engine rebuild or new
- Not in the manual, does anyone know what it is called?
- Shock Problem on 2WD with Suspension Lift
- 92 SR5 keeps blowing the EFI fuse
- $4.89 Head Gasket Repair, Done!
- I need help Boys!
- Help
- 1989 Toyota Pick-up NEED HELP
- fuel system question
- Fuel Filter Location?
