View Full Version : Malibu
Pages :
1 2 3 [ 4]
5 6 7 8 9 10 11 12 13 14 15
- possible coolant leak per GM
- 1999 Malibu Window wont go down
- Battery trouble Issue
- '99 Malibu Windshield Molding
- 1999 chevy malibu bad fuel pump
- Exhaust System
- 99 malibu this one has me stumped
- Scanner values
- 98 Malibu hard start when cold
- 99 Malibu electrical problems - update
- 05 Mailbu Runs on after turning off?
- Is extended warranty worth the money?
- Fog Light Bolts
- 99 Malibu 3.1L electrical problems
- lights dim and car wont start sometime
- 2003 malibu 3.1 jerking/serging?????
- The Coolant Air Bleed Stuck!
- '99 3.1 issues
- 2006 malibu and impallas
- 03 Malibu Brake Issue
- 2006 chevy malibu keyless remote
- Intake gasket: temporary fix
- Fuel gauge going crazy
- Instrument Cluster Inop Exc. Temp Gauge
- Installing Glow Gauges in 98 Malibu
- Gas Mileage
- 2005 Classic; premature wheel bearing hub wear?
- 2004 Malibu(bew body style) dash removal
- programming remote
- 03 malibu heater only works on 5
- Stub Shaft Removal
- Beaten to Death - Head or LIM Gasket?
- 98 chevy malibu ls engine mount problem please help
- Tranny Mount?
- Help
- Brake and ABS light on
- HELP!! scan Communication Error
- Replacing the lower IMG on my Malibu
- Cooling fans stay on
- Lower control arm bushing question
- 2004 Malibu Slightly Overheats
- replacing Transmission Filter
- Heater fan resistor
- Temp Sensor Replacement: to DIY or not to DIY?
- Dex-cool and Malibus
- '04 Classic tranny fill/level plug
- Ello Peeps!
- oil Filter gskt blows out
- How to change oil and oil filter on 2001 malibu
- 06 Malibu Maxx LT Braking troubles
- 2001 malibu has hesitation when i give it gas
- 2001 Malibu Overheating and Hard Start
- 03 Malibu gas and temperature meter go down
- HELP troubleshooting
- help please: is it a 1971 malibu?
- Oil Leak Question
- 99 Malibu, dashboard lights went out, check vehicle light came on
- 1998 malibu No Start
- Front Sway Bar
- 99 Malibu wont downshift.
- Malibu 2003 No Start
- 2006 malibu rear bulb replacement
- 2004 Malibu headlight replacement help
- 2001 Malibu front end noise after hitting a deep rut.
- 2003 Malibu brake light - opposite operation
- 2004 Malibu Maxx Grill
- 97 Intake manifold change-needs advice
- 06 Maxx Wheel Hub Issues
- Please Help! Big Problem!!!!
- Thleft system or starter
- 1997 Malibu Won't Start
- Changing PCM...What does it take
- 2002 Malibu hesitation
- A problem with replacing my left taillight cover
- Porisoty in a rim.
- 2002 Malibu Hesitation / Temp issues
- 98 Malibu AMP Installation - POWER WIRE
- 2004 Malibu shakes when braking
- 2001 Malibu Steering Wheel locks up
- CD Player Quit Working
- 3500 V-6 Check Engine Light
- 2005 4 banger gas gauge issue
- 99 Malibu dies inconsitantly
- 1997 malibu cuts off
- 02 Replaced Intake Gasket, now leaking/burning oil
- 07 Malibu block heater
- 2003 Malibu Interior Leaks
- 1999 Malibu Remote Programming
- Shift button won't release- stuck in park
- 05malibu ls
- 05 malibu ls govener
- Bucking?
- Engine won't warm up
- Fuel Gauge is Backwards
- RPO code sticker.
- Hi, does my car have ABS
- cv joints
- Do all malibus have rear tire wear problems?
- 98 malibu wont get out of park
- gas meter gauge problem
- Sudden Overflow from the coolant reservoir
- heater blower
- Wiring code for 99 Chevy Malibu?
- Add transmission fluid 03 malibu
- Key & Remote Locking & Unlocking Problem
- How to replace drivers side power mirror on 2004 Classic/Malibu
- 2004 Malibu Trunk Release
- 98 Malibu 3.1...Difficulty finding source of noise
- '05 Malibu seat belt warning light
- 05 ecotec
- 97 Malibu V6 3.1L Cruise Control Not Working
- 97 Malibu V6 3.1L Audio Receiver Replacement
- 97 Malibu V6 3.1L Remote Keyless Entry
- 1996 malibu,wont go into overdrive
- What temp do fans turn on? Don't think mine work
- 2004 Chevy Classic ECOTEC where are spark plugs?
- 2004 Classic ecotec where are spark plugs?
- programming 04 malibu key fob
- 97 Malibu V6 3.1L Belt Noise
- 97 Malibu V6 3.1L Fuel Milage and Acceleration Become Poor
- Bolt Torque
- 97 Malibu V6 3.1L ABS Light Always On
- 98 malibu won't crank
- Brake lights arent going on....
- 97 Malibu V6 3.1L Noisy when speed up
- 98 malibu 3.1 p0341 cam sensor code
- 98 malibu wont crank
- 98 Chevy Malibu
- 99 Malibu - Intake Manifold Gasket
- Fuel Pump
- The dreaded P0410 code
- Check engine light
- bong- bong chime but no lights or indication
- Can I put a 05 malibu eng in an 03?
- 02 Malibu losing coolant
- 98 Malibu Keyless Entry Programming
- Wanted manual for 2006 Chevrolet Malibu Maxx
- Check Engine Light
- Replaced Fuel Filter, now won't start
- can you figure this out?
- engine
- Owner's Manuals - PDF versions
- '99 Malibu - low coolant
- A/C seals?
- 2003 Malibu stalled and won't restart
- MIL light threw a P0410 code.
- 4cyl or the 6cyl Malibu-What's your opinion?
- After market Caliper bolts..1999malibou
- Is there a better Evap Diagram? 98 3.1L
- what order do the front three spark plugs wire 1997 Malibu
- 2005 Malibu radio resets by itself
- Is this caused by a faulty fuel cap?
- #3 cyl misfire
- 98 Malibu operating temp on gauge
- headgasket coolant leak
- under dash lights
- Proper Scanner-freeze Data For Po44o Code
- Gas Cap blows off
- Adjusting headlights
- 05 Malibu heater blows cold air
- catalytic converter/hesitation
- Timing chain tensioner installation
- Tire reccomendation Malibu Maxx
- Running Amp wire
- where is the ac recharge
- replacing a/c control
- radiaotor overheating/watering coming through cap
- Cruise control '03 malibu won't engage
- machine rotors
- Finding 03 Malibu 3.1L Power Programmer?
- issue with malibu horn system and coolent
- tie rod end
- 2003 Malibu Governor HELP!
- misfire cyl. 1
- 2002 Malibu: A/C, Gauges, Criuse, Radio
- 2004 Chevy Malibu Maxx Broken Power Seat
- Car turning off while driving
- 1997 Malibu overheating radiator
- Hard start when cold, fine after that
- ABS light
- 1997 Malibu left tail-lights wont work
- electrical problem on 03 malibu
- 05 Power Steering Loss
- Fuel Economy mods.
- Heater Problem
- 2002 malibu power window won't close
- Changing A Starter on a 1997 Malibu
- Lower Control Arm Replacement
- Oil Pn Removal - 1998 Malibu
- 1999 Malibu fuel gauge and A/C trouble
- adjusting brake light switch
- 2005 Malibu Radio and RDS?
- 99 Malibu - ctr brake light works, other 2 don't
- Front brake pads
- Engine Swap
- 2005 "classic"
- upper engine noise under load
- fuil filter
- junk fuel level sensor
- Malibu 2003 heating problem
- 2000 malibu weird smell when changing temp
- brakes seizing?
- Remote Starter & PassLock II issues
- wind noise
- 2008 Malibu tire pressure.
- transmission fluid level
- '05 Malibu Electrical Issue(s)
- abs light and stutter at high speeds
- 2003 Malibu...does it have alarm? How to arm/disarm?
- 99 Malibu spits & sputters & dies
- 2004 malibu fuel and temp guage problems
- How change steering rack&pinion?
- 1997 Malibu Won't start
- 2006 Chevrolet Malibu LT
- Need help with sensor problem in 1999 chevy malibu
- funny noises
- Transmission fluid all over the place....
- 1997 Malibu over-heating and oil-water coming out of the tail pipe, now wont start
- Rough start
- 2006 Chevy Malibu, Bad Alternator within first two years
- Re: A/C Compressor
- Need Help With My Car
- need help on reseting theft system on my 03 Malibu
- 2001 malibu problems
- Reuse lower intake gasket?
- Head gasket, Which way up??
- 2003 Malibu Won't Start
- 2006 malibu bulbs and autoshift
- can't open rear door
- 3100 Upper plenum doent sit flat on lower
- just installed new rear pads and rotors
- Malibu Brake Pedal
- no spark
- Wheel cover rattles 2005 Malibu
- 99 Malibu radio display PCB
- 2000 Malibu left tail light problems
- theft light on when driving
- power steering...!
- 98 Malibu Rough Idle
- malibu 05 keyfob to unlock doors not working, locking does
- replacement keyless entry remotes!
- Unhook the Antenna in a 06 Malibu Maxx
- help me out!!!
- Help 97 Malibu Is Overheating After New Thermostat
- 2003 Malibu hub nut spec
- 2003 Malibu Air Condition
- How to stop the CAR to start?
