View Full Version : Mystique
- Frustrating Overheating Engine
- Radiator - Black Foam Spewing from Top Port
- passenger side cv removal
- Removing the driver's door window
- Sunroof drains
- Time to replace turn signal/flasher switch?
- need major help with a 98 mystique with the 2.5 v6
- Trans question 2000 Mystique
- will not accelerate, dies
- Radio, Dome Light and Power Mirrors won't work?
- Fuel Pressure Sensor 1999 Mystique
- 98 Mystique low transmission line pressure
- Automatic door locks
- 98 mercury mystique- crank-no start issue.
- 2000 removing/replacing window parts
- Mystique "from hell" ,PLEASE HELP!
- Baddest mercury on the street?? Any ideas on what to do next??
- Anyone here ever modded a mystique??
- Power Window losing its Mojo & Posstibly trying to Sever my Fingers
- 98 mercury mystique shifting wrong only when cold out
- Headlamp mount install help
- Mercury mystique weird brake problem
- 1998 mercury mystique 2.0L Engine Lift Points
- 97 Mercury Mystique Overheating
- Mystique LS Lock Nuts (NO KEY)
- Changing starter
- Starting Trouble
- Hardtop Convertible 99 Mystique
- 99 Mystique 2.5L Oil Filter Location
- 99 Mystique turn signal/flashers
- Any Ideas???
- electiral issues...
- help a poor fool
- Coolant leaking
- Mystique 2.0 auto no spark/fuel ideas??
- brake pressure switch
- 98 mystique stalls
- Transmission Problems--PLEASE HELP!!!
- 1995 RPM's drop when cooling fan comes on
- 1998 Mercury Mystique Transmission
- TSS removal
- after market light and covers
- 95 head light covers
- Fuel injector cleaner??
- O/D light flashing!!!Hesitation when acceleration!!!!
- 97 Mystique Over Heats and Causes Tranny Issues
- Abs On!!
- 1996 Passenger side CV shaft support bearing
- 95 Mystique stalling
- Mystique 97 - Engine Mount / Motor Mount???
- 96' mystique ls 2.4 ltr
- 98 Mystique Blower issue
- 2000 Mercury Mystique Noise
- I am looking for the crankshaft position sensor
- 1995 mercury mystique with a big problem
- 1997 mercury mistake low idle
- 95 mystic timing belt
- 95 mystique losing revs
- battery light on dash
- location? LQQK Please help
- 1998 Mystique running hot
- 1995 mystique GS odd noise explained??
- 1998 Mystique 2.5 P304
- 1998 Mystique 2.0 4cyl. Zetec DOHC Timing Problems
- 1998 mystique 2.0 4 cyl idler pulley replacement
- 95 Mystique beeping
- 1999 mystique wont start
- wont start when its cold (98 mystique)
- Mechanics. 95 Mystique
- 98 Merc water pump
- Car is Possessed
- crankshifts sensor needs replaced
- 1999 Mercury Mystique Transmission
- battery light almost always on
- Door chime malfunctioning on 98 Mystique
- 95 Mystique scan tool
- Knocking noise-Timing Belt? Wont start!
- Need some help with alternator ..
- 1996 Mercury Mystique Engine Replacement
- mystique 2000 problems
- jerking...
- a/c recharging
- 98 Mistique OBDII code 1131
- 98 mystique f-strut issues
- Blower Motor resistor on 99 Mystique
- 98 Mercury Mystique Transmission
- inner tie rod removal
- Car Quits
- Bad struts or is it??? 99 mystique
- 97 License Plate Mounts
- Wet Floor - 97 Mystique
- Uneven wear on front tires
- 98 should i buy?
- Considering 97 GS
- can't find the sensor
- Speedometer quit working
- Echeck problem .Please help
- Brake light problem...
- Timing set???????????
- 1996 mystique stnd. transmission, idle fluctuates up and down
- Jerking Car!!!!!!!!!!
- How to replace the O2 sensors?
- Where's the connector to check codes?
- Timing check??????????
- Check engine Light Burnt Out???
- Rear passenger door stuck shut?
- rough runner, HELP!!!!!!!1
- Hood latch/ dashboard cover
- Air bag
- Trunk Key Don't Work?
- Amplifier Location
- 1996 Mercury running hot
- 98 Mystique (Mistake) No Start Help!!!!!
- 97 rough idle when in gear
- HELP!.....Check Engine Light - P0171
- Air Bag Light Blinking, 41
- Car problem not sure if its fuse?
- 95 mystique won't start
- broken flex plate- zetec- alignment
- Overdrive light flashing & hesitation issues
- Oil in the Air Filter? What's this?
- 98 broken timing belt
- Mystique 2000 stops
- 98 Mystique Syncros
- 1995 5-speed problems
- Battery Drain: Mystique 2000
- 2000 rear door noise
- wiring
- stereo.. Antenna will not go up
- 95 mystake idles then dies
- mystique 2000
- messed up dash
- 1998 mystique
- Zetec head for sale $95 Free shipping
- COolant Temperature sensor
- Hard to shift from DRIVE to PARK
- Keyless Remote Programming - 2000 Mercury Mystique
- 98 mystique heat guage
- Shift Lock Problem
- Gas Gauge problem!
- Temperature sensor
- newbe, please help.
- mercury mystique Torque specs!!!
- Super Lighter!
- Fuel PumP
- Mystique Stalls Intermittently HELP
- 99 Merc Tracer Auto Transmission overdrive kicks in and out violently
- Thumping noise
- Sunroof stuck!
- Replaced PCV, now won't start
- raidiater drain cock
- Highway Hesitation or Jerk
- mystique mess again
- increase horsepower
- leaking oil pan
- Sudden burst of power?
- how to replace ignition lock
- Mercury Mystique Mess
- 1995 Mercury Mystique overheating Please Help
- electrical problem
- 99 Mystique O2 Sensors (again)
- gas lines
- Air filter replacement
- shaking
- replacing AC accumulator--1995 Mystique
- Mystique/contour 95-97 check engine light
- radio
- v6
- warped dashboard cover
- Beeping
- code p0151
- Problems with 96 Mystique
- 95 Mystique Megafuse
- 2000-75,000Miles-Timing belt?
- you'll all be happy to know...
- 2000 mercury mystique radio issues
- check engine light...
- Power antenna question
- Transmission
- speedo cabel
- Fuel Economy question
- '96 Speaker wire colors, which ones r which?
- 5-speed Mystiuqe
- Engine running on three cylinders
- Headlight removal info needed
- 1997
- 95 Mystique V6 engine code 452 HELP
- some advice on 95 2.5L 5sp man
- New owner of a 97
- pulling to the left when braking???
- 97 mystique
- 95 mystique problems
- Rear door stuck shut, any advise on getting it open?
- 97 mercury mystique
- Brake lights out
- can someone give me advise
- Power window is gone...
- Mercury Mystique 4 cyl. 1998
- taking out the radio
- idling like a tank...
- Help Engine Check Light.
- spark plugs
- No heat, Car shakes, Low Idle, Windshield Wiper Moter not working right, etc.
- No Heat
- Weird Heating Problem
- Remote entry
- Timing belt change.
- 95 Mystique engine diagnosis
- What turns the coolant fan on, a sensor?
- diagnostic port 95 Mystique
- Anyone know how to time the dual cams on a 2.0?
- VCT Solenoid problems
- 1995 mistake won't turn over - again
- 95 mystique fuse panels
- How to remove water pump?
- How to check codes and what they mean/
- air bleeding coolant system mercury mystique
- Air Conditioner Problem
- need help! gettin cams timed with engine(95 2.0 ztec)
- 1995 Mercury Mystique ABS Control Module
- Throttle plate
- radio install
- window lift motors
- Leaky Trunk
- How does one disassemble trunk lid ?
- Belt slipping
- Overheating Problem, plz help!
- cigarette lighter
- changing cigarette lighter
- Longtime Mistake owner here
- 2000 Mystique missing and check engine light on
- New Mystique owner
- Check engine light on
- help: breaklight/blinker wiring problem
- engine/steering/electrical/transmission failure??
- engine swap if possible
- taillights
- Egr ...........check Engine Light?????
- timing belt diagram
- engine failure
- Occasional Hesitation
- help please
- 96 Mystique 2.5L
- O/D Light Blinking. It's annoying!!
