View Full Version : Impala | Impala SS
Pages :
1 2 3 4 5 6 7 [ 8]
9 10 11 12 13 14 15
- Impala owners - suggestions - LT1 BUICK
- Belt Chirping/Squealing... Tensioner or Power Steeringt?
- 2002 Impala Security/door locks
- 2005 impala heating up
- Calling all LT1 Experts
- 2003 Impala LS. Clunking noise??
- 2001 Impala LS squealing
- New to impala
- gm passlock 2 disablement
- Going To Find Out How Fast A '06 Impala Ss V-8 Will Run Flat Out!!!!!!
- Engine dies while driving and no-restart
- Time for a short block?
- Anybody else notice the 04 SS noises?
- '02 Impala 3.4L:Low-Speed Fan Gone
- Burning smell
- MAF sensor on a 2001 Impala 3.8l
- 02 IMPALA LS slow aceleration, delayed shift, loass of pep
- A/C Help please
- Impala Issues
- 2003 Impala Bulb Replacement
- 4sale!!!
- 2000 Impala V6 3.8L VIN K loud shrill
- a/c question
- Code P0481
- My 03 impala DIC (drivers' information center)
- Impala
- hub not pulling out
- CEL code P0440
- Anybody Know What The Top Speed Of An '06 Impala Ss Is???
- 04 impala Ls 3800 vs 06 Cobalt supercharge SS
- Tail Light covers
- 2002 impala change oil light reset
- Removing Dashlight bulbs
- 2007 Keyfob Programming
- 04 Impala Ls Stock Vs Honda Civic 05-06 Manual
- 2000 3.8L MAF Wiring
- 06 Impala SS Trans Fluid??? Help
- Security Light On constantly
- Rear amp in the trunk, How do you bypass the wiring to get sound from the speakers?
- Replacing Rear Pads & Rotors HELP!!
- 2000 Impala, ABS and Trac question.
- Aftermarket Floodlights/Brighter Bulbs/Quad Lights
- 2003 Impala PO742 code
- Cargo Nets for 2000-2005
- Air Bag problems
- Better performance for a 02 impala
- Heat/AC Actuator R&R
- impala wont start when temp drops
- broken pulley?
- Gas milage
- How do i prevent headlights on when unlock
- Low Tire Pressure Light
- 96 impala ss review
- best oil for 3.4 impala
- 2003 Impala oil light comes on and then off
- 3rd gen impala ss vs 4th gen trans am
- Help Finding Frame VIN 58 Impala
- Low coolant level again
- Problem to Start Engine
- Help cleaning the inside of my Impala
- 77 timing mark?
- Message Center Needs Help
- Re-starting problem...again...again
- Water leak on passenger side fr& back,under the carpet was over 10 gallons of water
- transmission removal tips??
- 2004 LS Brakes Thumpy- how do I stop that?
- Stock Caprice/Impala SS Rims For Sale!!!
- '02 Impala 3.4: Piston Slap on Startup
- 2003 Impala 3.4 14k $9,000 - Good Deal Or Bad Deal???
- 2000 3.8L MAF sensor bad?
- CEL: P0455 help
- Climate control problems
- Found out what was wrong with the short in my radio,IT BURNED
- Location of coolant temp sensor?
- HVAC, and ashtray lights
- 2003 IMPALA intake and head repair cel light
- valve train?
- radio/stereo doesn't work
- Changing the Supercharger oil
- Loud surging and noises from my speakers
- 04 SS replacement tires?
- On Star antenna
- 2003 impala head gasket installation
- Please help...2003 Impala LS
- Fixing side mirror--need help
- Brakes and rotors
- A couple of "Issues"
- 2000 Impala base instrument panel cluster
- comments on 2007 Imp LT1 w/3.5
- Transmission and OBD code P0300
- 2002 Impala 3.4L Exhaust upgrade question
- 2002 3.4l speedo and transmission...
- Where is my LOW OIL warning light????
- starting to have a few symptoms.....
- How to replace insturment lights 2003 9C1
- Transmission Iussue - 3.8L
- help replacing third brake light
- knocking in steering wheel
- 05 impala wiper blades stop in vertical position
- driver side door 01 impala
- intake gaskets
- Help! Car Won't Start!!!
- 96 impala odometer
- Seat replacement......
- Front right wheel bearing
- Horn goes on by itself
- Floormats?
- Squeaking sound from glove compartment
- 2004 Impala SS upgrade suggestions?
- Catalytic Converter is clogged?
- Cold air intake or short ram intake?
- 2000 Impala 3.4 - Transmission Problem?
- aftermarket stereo install help
- 2005 Impala LS Noisy A/C Compressor!!
- GM extended warranty?
- extended warranty
- Make ac blow colder air.
- Can i install new stereo in 03' impala without interfering with service of car?
- Service department insider
- Camshaft Problems
- Rocker panel mouldings ,fr & rear bumper and door moldings
- how to remove back seat
- 2006 3.5 question
- What kind of paint for my front grill,do I need some kind of plastic primer 1st
- Resurfaced original rotors, how many times can they be cut
- How to replace Hub Assembly (bad speed sensor)
- Sent from Buick......... Over heating RoadMaster
- Any problems noted with new 3.5/3.9 engines?
- How can I cheaply stop my 05 impala from eating the GAS?
- Anyone drill holes in their impala headlamps to stop the fogging?????
- Vintage 71 Impala
- Shifting Problems in 2003 Impala 3.4L
- Stuck open thermostat
- Anyone know hoe to fix my fogging headlamps on my 05 Impala
- Best replacement rotors & pads for 05/impala
- Coolant drops under my car
- Any suggestions to improve gas mileage for the 3.4 in the impala
- 2006 impala ss gas mileage
- Best battery for Northeast?
- Best Bike rack for 2000-2005 Impala
- 2006/07 Impala
- ABS Light - any tips
- Largest Wheels On Stock?
- ACC / Lighter plug
- recirculating air
- whining sound from engine compartment
- Windshield wiper help.....PLEASE
- 2002 headlamp relay
- 03 rear defrost
- 02 impala overheating
- Fans always running
- Transmission just acted up,did not change properly
- When did GM change their intake manifold gaskets?
- 2001 Impala starting problem
- Will the A/C run in cold weather ?
- Looking for 2000-2004 Model Impala !!
- Turn signal problems
- Front seat mount??
- Daylight running lights stopped
- Excellant web site reference
- Intermitting clump and thump from left rear strut, mount maybe?
- 2003 impala LS 3.8 hards shifts
- Cruise Control Not working
- Thermostat
- 2003 impala overheating problem
- Cheap Foglight Bulb Replacement
- tick tick ticking....injectors?
- left button on mirror?
- Range when low gas light comes on
- 2001 Impala intermittent start
- A/C Odor
- 2001 impala blower motor problem
- 2006 Impala Ss
- control arm bushings???
- fragile defroster dash grille trim
- 2002 Impals LS Dome lights
- Lifter knock
- 2002 Impala Locked Factory Cd/Tape Player....Help
- Is High Mileage oil Worth it?
- How can i check my catalitic converter
- 2000 impala cd player issues
- 2002 impala under throttle engines revs up and down erraticaly
- spark plugs ??
- 03 Monte Carlo LS heating problems
- What pressure do you have in your tires?
- 2001 Impala cuts out around 20 MPH
- 2005 impala ls
- Dash Lights
- 06-07 EQ preset question?
- Side Mirror Repair
- does remote starter suck gas????
- OEM wheel vs China made
- chevy 2000 ls po410 code
- 69' Impala Heater Core
- impala ss
- 01 Impala--how do i set my clock?
- Tail lights and dashboard lights out , help please
- weird situation
- Fuel Leak, WHAT IS THIS PART?
- suspension upgrades
- low oil level light pops on--- car turned off
- 02 Impala Ls cuts off during driving
- 1970 Chevy Impala
- 2001 Impala Ls
- Updates on my POS 2004 LS
- Used BCM no good??
- New to the Impala crew....
- 01 Impala-High rpm shift/Tran slip
- apply gas or brake-slight feeling in steering wheel
- ticking sound
- popping noise
- front cigarette lighter power supply???
- heater control lights/remote programming
- 01 Impala LS pointer shows full-empty tank. What is problem?
- Battery draining
- Traction control/abs light come on
- Thoughts on a seat transplant?
- 65 with bad alternator
- 2002 Impala starting problems
- A/C Only works on High
- p0441 incorrect purge flow.
- Overhead Info Center Install
- CV Joint grease??
- TRUNK OPEN warning light?
- Which year should I get? Base or ls?
- 96 impala ss loses all power
- Fuel gauge sending unit wiring
- Impala SS 1995 Stolen
- 2000 Impala Power Window Switch
- Screaching Window
- 2002 Impala. Starts, then dies immediately
- Fog Light Bulb Replacement
- considering a 2004 impala......thoughts?
- 2003 impala stereo wiring pins
- 01 Impala B2960
- Computer Reader
- Intermittent starting problems, 2002 Impala
- I need help installing a remote starter
- Please Help Wobling Front In
- 2003 impala 3.4 oil leak
- Trunk light (re)installation
- What is a good by on an impala ss
- EGR-related performance issues
- Questions on Dexcool and leaks
- Chrome Alternator, but...
- 283 with powerglide
- rear defroster
- RADIATOR FANS not spinning correctly + CHECK ENGINE LIGHT
- Thermostat 2001 Impala ASAP
- Instrument cluster noise ?
