View Full Version : Impala | Impala SS
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15
  1. 2003 possible coolant problem - Dexcool?
  2. 2003 impala 3.4 p0128 error code
  3. Water Pump Replacement
  4. Mystery Part
  5. 1995 Impala SS - Transmission Issues
  6. To Max Wedge ( ball joints
  7. 04 Axle Seal Replacement
  8. Blower Motor Relay
  9. igntion sticking
  10. ISS sterring shaft
  11. 2005 Supercharger longevity
  12. How much oil
  13. Already a dead battery
  14. Power steering trouble please help
  15. power steering problem in the rain
  16. ABS or Transmission Issue? Help Needed!
  17. 2006 impala lt loss of steering fluid
  18. 2003 Impala - power Steering Pump
  19. blowing cold while idling
  20. 2000 Impala Heater not working
  21. 1964 chevrolet impala 409
  22. 06 impalla overheating / no heat
  23. Intake manifold leak?
  24. 2001 Impala temp gauge
  25. '02 Impala 3.4L 128k: Power Steering Fluid
  26. Exhaust Tip
  27. Heat blower motor
  28. Oil plug stuck
  29. 2005 impala 3.4 code P0507 for IAC or posible vaccum leak
  30. OnStar Backup Battery
  31. blower problem
  32. 2006 Impala Cop Rims
  33. 01 Transmission into an 03 Impala??
  34. Do they need all this s__t a__ wiring
  35. 2003 Impala Code p0404
  36. best synthetic motor oil and trans fluid
  37. need help please
  38. 2001 Impala BCM replacement adventure
  39. Engine/Trans Date Codes
  40. Finally Happened
  41. cooling fans not turning on.....
  42. Headrest removal 08 Impala
  43. Terrible Front End Noise
  44. 06 with key stuck in ignition
  45. random misfire
  46. p0741 and p0742!!!
  47. 2001 Dash lights not working
  48. Help! Please
  49. 07 Impala remote start not working
  50. Battery issue / Battery light flashing
  51. 06 - 3.5L Head Gasket - 77k
  52. 2006-2009 Power Drop
  53. 05 impala hard start when cold only
  54. Cooling System Problem - 04 Impala
  55. Blower Motor Probs
  56. trans swap help
  57. no heat on driver side, any ideas?
  58. 04 Impala not starting
  59. Pull Engine and Trans together???
  60. need 2 small hoses for coolant bypass to intake, any ideas
  61. LIM leak? swaped 4 felpro set but mist coming from back of engine?
  62. 06 Door panel
  63. 1995 Impala SS - Total Suspension Upgrade - Your Thoughts?
  64. 2005 impala has no heat after LIM gasket/themostat
  65. Help! O6 impala
  66. 2002 Impala LS Radio Light Out
  67. changing out the steering wheel
  68. 2005 impala with hole in fuel tank
  69. clunk?
  70. Leaks after LIM gasket project
  71. high Idle
  72. 2003 Impala - Driver's Side Water Leak
  73. ticking engine noise
  74. Word of caution on Splash guard
  75. 04 Impala 3.4 traction control kicks in when turning
  76. ok guys and gals i need some help.......
  77. More ?'s about 2003 trans slipping
  78. 2001 Impala - misfires under load / uphill chugging - finally FIXED!
  79. Radio/Battery?
  80. 2007 Impala A/C and Rear Defrost - Is this working right?
  81. Does bad Pcs afect reverse gear too.
  82. intermittant turn signals
  83. Before i replace my intermediate with a new one I have
  84. 3.8 water pump removal
  85. Drive Axle Replacement - Questions
  86. power door lock ?
  87. 06 Impala loses power during shift
  88. Pressure Control Solenoid or what???
  89. need help removing a window 2002 impala
  90. 2002 impala LS stalls
  91. Minimum Rotor Thickness for 2007 Impala?
  92. 2006 3.9L Head Gasket
  93. What Happened???
  94. 2006 Impala Rear Defogger
  95. Loud clicking sound
  96. Front o2 Sensor Location 2000 Impala 3.8
  97. 1995 Impala SS - Fuel Fumes
  98. AC/Blower resistor on 02 LS
  99. 2003 9c1 heated, power seat install
  100. Where is tensioner pully?
  101. Pinout for 2003 heated seat connector
  102. Loud Turning Signals
  103. GM has cut the impala ss from the lineup
  104. Tech2
  105. 2000 impala ac compressor leak
  106. Any issues with 2007 LTZ's?
  107. trying to get every think in good stats
  108. Serpentine Belt.
  109. 03 impala catalytic converter
  110. i hope someone can help me
  111. 95 impala ss wiring harness
  112. 01 Impala 3.4L Cooling and Trans. issues..Need Help!
  113. 2008 or 2009 impala
  114. P0336 Code
  115. 2006 Impala Windows Not Working
  116. 3.4 or 3.8L engine
  117. check engine light
  118. RPM range for tranny to shift
  119. New ignition cylinder, security light still on, now what??
  120. Change radiator hoses?
  121. 01 Impala air bag removal.
  122. 2000 Impala In and Out of OD constantly
  123. Location of the Camshaft Position Sensor...?
  124. Tighten gas cap????
  125. 1996 Impala SS belt squealing
  126. Unlock RDS radio -?
  127. 4T65E Trans question
  128. Loose spark plugs
  129. 06 Impala Camber Issue
  130. clock spring replacement
  131. '02 Impala 3.4: Broken Wire Under Driver's Seat
  132. AC/Heat fan not working
  133. Problems
  134. Front Tires will not rotate clockwise!
  135. Replacing blower motor resistor did not help
  136. 96 Impala SS - Odometer went blank
  137. Only starts on occasion?
  138. Tire noise? 08 SS
  139. Another Weird AC problem
  140. Denso/NGK Iridum Pugs - Your opinion and/or experience?
  141. 06 SS issue
  142. Air Conditioning will not come on
  143. Impala Tire Rod/ Coolant Leak
  144. 1995 Impala SS - Oil Issues
  145. 2000 impala dies going down the road
  146. 2005 Impala climate control malfunction
  147. New BCM, Dead Battery
  148. BCM memory
  149. serpentine belt
  150. 2005 Impala Horn Replacement
  151. hi
  152. A/C & Temp Gauge glitch for a few minutes...
  153. Windshield wiper intermittent function not working
  154. Pass key fault is on
  155. crunching in front when i put brake on
  156. CAR STARTS BUT DIES IN ABOUT 5sec.
  157. chevy impala 03 transmission slipping
  158. "service brake assist"
  159. Replacing Intake Plenum and catalytic converter
  160. Ignition switch or Key?
  161. Transmission Issue
  162. too much tranny fluid
  163. Vehicle not starting
  164. Wheel Bearing Problems 2001 LS
  165. 2003 3.4 chevy impala
  166. front axle noise?
  167. 2001 impala ABS light
  168. 1995 Impala SS A/C not working
  169. click and crack in my steering 05 impala,just started 3 days ago
  170. no start passlock
  171. 01 Impala will not shift into 2nd gear
  172. Radiator and Cooling Fan Issue
  173. 03 impala, overheating problem, mystery cracked hose
  174. Spotlight Hole Repair Help (retired cop car)
  175. 2001 impala ls a/c leak
  176. 03 Impala Blower
  177. what is the best timing degree
  178. I need A grill and headlight bezzels
  179. 2002 Impala LS Light Show (BCM)
  180. swishing & swirling noise in my 05 impala
  181. Swissing & swirling noise in my steering when turning left and right
  182. Too much plastic 06!!!!
  183. 03 impala power loss - UPDATE
  184. 03 IMPALA Transmission only can go 3mph
  185. Headlights on most of time
  186. 2000 LS Struts
  187. 1995 Impala SS - Transmission Shifting Hard
  188. Oil filter whoopsie
  189. Low Tire Pressure Light
  190. coolant leak
  191. code question.
  192. How to disconnect panic button
  193. Engine Whistle
  194. heater fan works when it wants to.
  195. Restoring Old Impala To Show Car
  196. Anyone installed Aftermarket radio in 06 up?
  197. Transmission
  198. UIM and LIM replacement...take 2
  199. 06 ac problem
  200. Synthetic oil and STP
  201. Problem starting
  202. 2003 Instrument Panel Lights
  203. 2002 Impala LS Power Problem
  204. 2008 Impala Royal Purple ATF
  205. 03 Impala power loss
  206. Turn signal intermittent problems
  207. Misfire problems
  208. Ground Wire Hookup?
  209. Nees help with gm starter wire's(color codes).
  210. running rough after intake replacement
  211. '02 3.4 120K: Front End Vibration Diagnosis
  212. tune up
  213. Accessory power disconnects when parked overnight
  214. 2007 Impala LT question
  215. power steering fluid leaked all out
  216. Help me please!!!!!!
  217. ok i give up!!!!!
  218. 02 LS intake swap problems
  219. upgraded ss cluster
  220. Warped Dashboard
  221. Evap System 03 Impala
  222. Oil pressure switch blew
  223. Service Traction System
  224. radio replacement.
  225. need a serpentine belt diagram for a 2001 impala
  226. Life expectancy question
  227. Please someone help
  228. catalytic converter Help
  229. 07 impala airbag installation question
  230. new head gasket?
  231. Welding Impala SS frame
  232. performance parts
  233. Tune-up frequency for 96 Impala SS
  234. programming new remote control for 96 Impala SS
  235. does it require premium gas???
  236. A bit of insanity struck me
  237. 2004 Impala 9C1 - Wheel Bearing
  238. Strange 2007 Impala LT Keyless problem
  239. billet grill
  240. rain guards
  241. Replace carbon fuel canister 2006 impala
  242. Check engine light on
  243. location of 02 impala vss
  244. Factory Radio Question
  245. Fuel Trim Lean
  246. Starter "Dragging"
  247. transmission leak what should i do....
  248. Fuel Guage
  249. Polar Start Car Starter
  250. 2007 Impala SS
