View Full Version : Impala | Impala SS
Pages :
1 2 [ 3]
4 5 6 7 8 9 10 11 12 13 14 15
- XM Harness
- The 15min $5.00 ISS "Clunk Repair"
- Brake Issues
- 2000 Chevy Impala Electrical problem
- Known issues and MPG with '07-'10 impala
- Jelled substance in pcv channel?
- 2004 Impala police packege horn?
- 2002 Impala - Neutral Safety Switch
- 2002 Chevy Impala
- Will pulling a 01 impala tear up trans????????
- small motor noise/ coolant issue
- Replacing a tire pressure sensor
- 01 impala 3.4 overheating problems. Advise please
- power window
- 2005 impala
- Keys stuck in the Ignition but driveable
- 3500 water pump
- 2000 Impala 3.4 Thermostat Housing torque Spec?
- 01 Impala ignition cylinder
- Wacko Horn
- Gas pedal sticks after car sits for a while
- Fuel Injector hat in the Manifold
- 2006-11 temperature sensors location
- 3.8L (3800) Head Gasket Replacement Advice
- anti freeze
- weird knocking noice
- 2005 Impala...all lights turn off!!
- Parking brakes stuck
- Rear Window Defogger
- 06 Impala Visor
- 2003 Impala 3.4 ltr code p0420a
- How does one check the heated seat elements?
- Replacing brake booster
- cat converter location
- 2002 Impala Cat Converter Problems
- Winter Tires 205/65r16 install
- ABS and Traction Control lights on?
- 2001 Impala Radiator
- 2003 ls 3800
- infamous speed selector issue
- 2008 Impala throwing P0340 code
- Headlight housing replacement
- 2003 Impala LS tranny won't go into gear.
- Clciking noise coming from engine...
- Weird coolant system problem
- Does not make sense
- power seat adjuster driver's side 2010 imp.
- 2004 3.8 LS Burning Oil
- To Max Wedge or any other's (pcs) tranny
- 2007 blower motor erratic
- 2000 impala 3.4eng code P0405
- Please help me identify a part name!
- 2000 impala 3.8 brakes hanging up...
- 2005 LS SS Super Charged
- blower fan won't ever shut off??
- starting issue
- spark plugs
- Dex Cool Change Out
- Wheels
- shaking and whistling
- Brake Line Leak
- 2002 Chev Impala - Headlamps Not Working
- 2004 Blower Motor Related Electrical Issue...
- 2004 LS Headlights dim
- Door key turns but doesn't engage/disengage lock
- 01 Impala 3.4L Idle issues
- '02 Impala 140.2k, Coolant Drip
- 04 Impala Blower Fan Motor
- 1995 Impala SS - Transmission Removal and Reinstallation
- Low Fuel Pressure
- Sensing and Diagnostic Module
- new strange problem with SECURITY
- engine swap question
- 04 Impala LS. Change engine oil light, and i just changed oil!
- door handle issues
- Odd recurring heat problem, 2007 Impala
- 3rd time replacing the Blower Motor Relay
- 2000 Impala SHUTS OFF while Driving....
- 05 Impala Oilpan removel 3800
- 2005 Impala Intermittant blower.
- stripped spark plug
- 01 impala no 3rd or drive
- whining in overdrive
- 2000 Impala 3 problems at same time.
- hey max wedge or whoever,mass flow air sensor
- Impala window off track
- homelink
- loss of power
- 07 impala tire pressure monitors
- died on me in the middle of I95
- 04 LS Passenger Mirror Heat Really Slow
- 04 LS Temp. Control(s)
- 2008 Impala LTZ developing Anti-Freeze smell
- Transmission Problem
- downsizing impala from 16 inch rims to 15 inch rims for the winter
- Question about air intake systems
- 2005 Impala No Heat
- 2000 Chevy Impala ABS and Traction OFF Light
- '07 Impala Air Condition
- nasty vinegery, "roadkill" smell from a/c.
- HELP! 03 impala won't shift
- 2004 traction control question
- 04 3.8 Where is the power steering fluid reservoir?
- 2001 starting issue
- problems removing exhaust manifold and cooling fans
- 2002 Impala LS No Start
- 2004 Chevy Impala 3.4 not starting
- 04 intermittent no start
- 2003 Impala Ignition Stuck, Please help
- shake in 05 impala
- 02 impala problems
- steering wheel shake and vibration in front floor driverside
- 03 Impala Interior Lights Out, Except front floor
- OIL LEAK CAUSED BAD Mounts? + Overheating
- exhaust
- 2004 LS Cannot put transmission in park
- 2009 Impala
- 01 Impala rear sway bar nut
- 02 Impala not starting right! Please help!
- impala has many prob. HELP!
- Changing lower intake manifold
- Removing outer door trim 03 impala
- 2008 Impala rear tire pressure monitor failures
- 2006 Impala 3.5LT Pulls left after alignment
- 2000 Impala 3.8 Misfire and turnsignal probs
- Possible paint problem 2008 Impala
- speedo light replacement bulbs?
- 2005 Impala making helicopter noise, even when off PLEASE HELP!!
- AC blower slow to come on 2000 impala
- 2004 IMPALA Trunk LEAKING! Need help!
- 2001 impala 3.8 radiator removal question?
- 2001 Impala transmission lever stuck
- a/c pressure readings question
- Radiator fan not turning on.
- 2000 Impala 3.4 - Replacing Camshaft position sensor - Help?
- '02 Impala 136.5K: Pothole = SECURITY Message
- Heavy rains and Flood
- Scan Tool
- Possessed tail lights draining battery
- Shift solenoid
- Wheel speed sensor trouble
- 2007 Impala Remote Quit Working & Tire Pressure Sensors Quit at same time
- 2008 Impala ls P0455
- ecm
- 2003 Chevy Impala overheating again!
- katzum
- Vent Motor 2005 Impala
- 2000 Impala Headlights
- 06 impala drivers side window squeal?
- 04 impala Shifts Hard when Hot, P1811,shifts hard,jerks
- 2001 impala 4t65e transmission (3400 engine)
- Front passenger window could not roll down
- 04 impala no AC
- 2000 Impala shutters on left turn only
- Multiple ABS/TCS codes, 01 Impala LS, just got it
- 04 Impala Tranny RECALL,PCS,P1811, Hard shifts
- Blower motor intermittent.
- 2001 Chevy Impala
- no high beams
- 3.9L Head Gasket
- 03 Impala Blower Switch
- Impala, low engine oil light
- Air Bag Module
- 2003 Impala turn signals
- 2005 impala not starting
- Theft Lock System
- High Beam Switch
- ac clutch
- 2004 Impala LS - Where is the Power Steering Fluid?
- Paint code location on '07 Impala
- Brake Noise
- 2001 Impala - sensors, gagues, coolant, etc
- 2001 3.8 stalling/cutting out on highway
- 03 Impala A/C Not blowing Cold, Compressor Comes on...
- multiple impala questions
- Tool for the Retaining Ring?
- evac canister
- Missing out around 1500rpms
- 02 impala turn signals and brake lights dont work
- DPFE/EGR valve pressure sensor
- ’03 Chevy Impala 3.4l 100k Gulping/Jolting.
- brake rotors
- front end shake
- conditioning the plastic trim
- Auto trans axle seal
- Tighten Gas Cap
- 3.4 is hesitateing when cold
- New 03 Impala few questions (engine, transmission, and wheels)
- To max wedge,05 impala is jumpy when cold
- 2000 impala BCM programming. Help!
- 00-05 Impala 9C1/9C3's don't have HD Transmissions
- 2005 Impala 3.4L Brake Redesign
- 2004 Impala dim odometer
- Brake Noise
- Lower Strut bolts stuck, out of ideas
- 04 Impala 3.8 cooling
- Car vibration
- 01 LS Drivetrain whub whub noise
- starting trouble 02 impala
- Need help with 00-05 Impala springs/struts
- Weird Noise
- '02 Impala: 3.4L 131.5K, No A/C
- 2001 Impala LS need fuel pressure specs.
- TPS torx size?
- '03 Impala: High-pitched humming w/brake issue
- 02 Impala LS Misfires
- Service Airbag Soon
- 2005 Impala power windows wont work
- misfire in cylinder 3
- Accel/Resume Not Functional
- Last one with dim '96 odometer
- 02 impala alternator bolt
- PHONE on radio WTF????????????????
- 2004 Impala Stereo Steering Wheel Controls Wrong Functions
- Transmission troubles 2005 Impala
- 2002 impala cooling fans
- Pinion seal replacement
- 2000 Impala LS Trunk Release Button
- No headlight blink when pressing keyfob
- 2000 impala
- 04 Impala HVAC Module
- 05' 3.8 wont start after UIM, VC gasket replaced
- 03 Impala LS 3800 V6 - Excessive Oil Consumption
- 2002 impala security light on after BCM replacement
- Impala Police car rims
- 2003 Impala Idle Misfire
- Radio**check engine light controls
- heated seat problem
- clock on 02 radio resets to 12:00 when car starts
- 2004 Impala Dash Lights
- plug/wire harness
- 2006 LT Heated Seats
- 2006 LT Remote Start
- Drive Shaft Nut Size
- 3.8L gasket replacement questions
- intake or head gasket?
- Fan switch
- coolant temp
- coolant fans
- sea foam
- intake manifold gasket help?
- trans mount
- 03 impala coolant fan not kicking on...
- 2002 Impala not starting
