View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25
  1. 93 Lumina APV 3.1 Stalling Problem
  2. How Many Miles on Your Lumina
  3. 96 Lumina Stumped Techs
  4. Hard starting and runs rough on humid days
  5. '93 Lumina APV 3.8 Cruise Control Codes
  6. Idle began fluctuating after Jump Starting???????????
  7. 98 Lumina Drum Brake Problem. PLEASE HELP!
  8. Power Locks problem in '98 Chevy Lumina
  9. lumina parts
  10. Why won't this car go when I want it to (I NEED POWER)?
  11. Heater not working, why?
  12. 3.4 Z34 coils on a 3.1 Euro?
  13. 1996 lumina coil firing order
  14. Flywheel
  15. My van dies when I touch the brakes...
  16. IAC Idle Control - where is it located/how to test it?
  17. power steering hose
  18. 1992 Dash lights won't go out
  19. Remove air silencer
  20. i am selling my '95 lumina
  21. Thier Shutting Down This Forum?
  22. Dash Lights
  23. coils?
  24. Lumina SS Brake system
  25. Buying 98 Lumina
  26. 93 Lumina Heats up when breakes applied
  27. SELLING 91 Z34 RED unless somebodys got idea to turn motor
  28. idle problems when slowing or stopping
  29. 1990 lumina cd player installation-please help
  30. '93 Lumina Problem - Rough Ride (And Not the Good Kind)
  31. New Lumina owner
  32. Lumina jerks and occasionally shuts off
  33. New member, 1998 Lumina LTZ questions RPOs
  34. Lumina APV HELP!!!!!
  35. 98 Lumina Starting Problems
  36. 1990 Lumina 3.1 problems
  37. 1992 3.4 lumina ecm codes
  38. Broke Cam Shaft
  39. '93 3.4L z34 died this morning
  40. 93' 3.1L pushrod order
  41. 92 Lumina Euro I need the wiring for the radio
  42. 93 Lumina APV transmission trouble
  43. stuck on high beams 94 apv
  44. distributor plug
  45. 93 lumina turn signal
  46. Factory alarm?
  47. Code 56?????
  48. where do I find a motor 96 lumina?
  49. I am selling my '96
  50. Rod knock or lifter? 3.1 engine 1996
  51. 1998 Lumina (car) how to interior door panel
  52. 94 Lumina APV trickle sound
  53. Oil Pressure Sensor Swtich 90 Chevy Lumina
  54. Ground wire/ car stereo/ cd player installation
  55. Blown intake gasket/Engine clean up
  56. 92' Lumnia APV Minivan Trans Troubles
  57. Looking for 93 Lumina z34 parts
  58. 1993 Lumina 3.1L coupe problems
  59. No spark 3.8 liter
  60. 92 3.1 Engine Issues
  61. 94 Chevy Lumina Euro Failed Emissions
  62. will it start
  63. feul pump located
  64. Help with a Fuel filter
  65. 1992 lumina apv engine problems
  66. 98 Lumina LTZ serpentine belt change
  67. transmission
  68. 97 Radiator fan problems
  69. ECM Trouble Code Is it Trouble?
  70. 3.1L spark plugs loonening?!
  71. 92 Euro Stalling with Speedo/RPM Problems
  72. 1995 lumina apv, wiper problem
  73. 92 Lumina euro stalls when slowing
  74. Rack and Pinion removal
  75. 1995 Lumina Brake Lights won
  76. 96 lumina trans problem-Help!!
  77. Piece of wheelwell(?) came off when driving
  78. Replaced alternator but new battery keeps going dead!
  79. Horrible Sound From Amp....plz Help!!!
  80. 92 euro 3.1L alternator
  81. 1996 3.1L Plenum (Upper Intake Manifold) vacuum hose
  82. 1990 lumina stalls
  83. '92 Lumina Power Steering Pump
  84. Turn-on lead in 93 Lumina
  85. car starts idling up and down till it just stops
  86. Swapping Lumina Engine
  87. Instrument Panel Upgrade?
  88. buy my 93 Z34
  89. '93 Z34 3.4L Serpentine belt replacement
  90. 96 lumina electrical problem
  91. 92 euro lumina has erratic/pulsating rpms
  92. 3.1L cranks, won't start when warm
  93. oes stock radio in '93 Lumina has preamp????
  94. Anyone know how to use Bondo
  95. About to put some gas and a match to my '92 Lumina Euro. Help ASAP!!
  96. where to find fuse box in 98 lumina ltz
  97. 96 Lumina 3.1 rough idle ONLY WHEN WARM
  98. 92 Z34 runs rough / stalls
  99. Security Light 97 lumina
  100. Clicking Coming From dash or Firewall W/braking
  101. Starting problems w. 98 Lumina
  102. ABS & Brake (pressure)
  103. '90 transmission stalling
  104. Lumina plug wires V6
  105. 98 lumina engine stalls while driving
  106. Spark Plug Questions
  107. Campaign code?/Heater Control Light Bulb
  108. 92 lumina wont start
  109. heater coil
  110. changing brake pads 1995 Lumina van
  111. Parking Brakes.
  112. Wheel size, changing from 14" to 16"
  113. charging problumes on 92 lumina Z-34
  114. Retracting the brakes...
  115. Perfomance Chips/Things 3.1 Gen 2 90-94
  116. CarDomain
  117. Starting Problems
  118. Weird Tranny trouble and more, please help!
  119. Problem With Driver side door after radio install
  120. ignition module
  121. Does anyone know where the cabin filter is???
  122. How to tear apart dash-replacing stock radio
  123. 92 chevy lumina runs rough and stalls when brakes are applied
  124. Timing Chain Woes.......
  125. Heating / AC control panel lighting
  126. 1993 Lumina Knocking
  127. a/c compressor
  128. 3.1 to 3800
  129. 3.1v6 fuel injectors chattering
  130. Will 20 inch wheels fit a Lumina ?
  131. Windshield washer pump
  132. engine boughs at revs and oxygen sensor removal
  133. intermitent power to ECM
  134. 3.1 engine swap
  135. Master Cylinder and ABS Motor Pack
  136. 92 3.1L Cranks great, but won't start
  137. rearend sits too low no springs what to do
  138. Driver Door Lock Issue
  139. 1998 radio take out HELP
  140. Transmission line leak - what's the most likely source?
  141. replacing ignition lock
  142. High Idle
  143. Faulty Starter or Siezed Engine?
  144. 92 Lumina Battery Dies
  145. New owner of 97 lumina with keyless entry
  146. 98 Lumina-water leaking in (outside water)
  147. Lumina vs Monte Carlo
  148. heater coil
  149. my lumina dont start
  150. Pics of my car
  151. 92 lumina apv throttle body injectors not working?
  152. 92 Z34 phantom stalling
  153. 95 Lumina Wiper Problem – Occasional
  154. The Horn won't turn off (Help Please)
  155. overheating/headgaskets/
  156. 92 Lumina Euro 3.1 FI idle & start problems
  157. removing the ignition from 1992 3.1 lumnia
  158. Anyone know where I can find a new engine?
  159. please help
  160. Adding power antenna to 95 Lumina
  161. 96 lumina transmission help!!!!!!
  162. 90 runs / stops after 10min no spark
  163. 1998 Lumina
  164. 92 lumina need help getting wiring straight
  165. 97 lumina keeps revving up on it's own
  166. '97 Lumina Engine DEAD! Now What?
  167. 1992 chevy lumina 3.1 engine
  168. my 1995 lumina ls, 3.1
  169. question bout my 93 lumina
  170. Lost my keys!!!
  171. need help with 1998 lumina
  172. 97 Lumina HELP with AIR BAG LIGHT
  173. bad tranny in 95 lumina sedan?
  174. Weird Humming sound while driving my 95 Lumina
  175. Park and Nuetral..Acting like gear engaging.
  176. Dash lights and power windows help please
  177. turning signals acting goofy
  178. '90 euro won't start, need help fast
  179. 93 lumina euro w/3.1
  180. What was towing package on '93 Lumina APV
  181. tranny and speedometer problem
  182. help again please
  183. Lumina Z34 Battery Removal
  184. Lumina SS BODYKITS, CF HOOD ..
  185. 95 lumina 3.1 cooling fan not kicking on
  186. Z34 Hood
  187. 92 Z34 Issue!
  188. Shudder, vibrations, Shakey on the highway
  189. 92 lumina 3.1 over heating problems
  190. z34 lumina
  191. 95 lumina apv seats
  192. how to remove air cleaner to remove battery
  193. 99 Lumina battery keeps dying
  194. '94 Chevy Lumina Heater Problem
  195. 90 Lumina APV 3.1 Cranks won't fire! Please help I'm losing my mind!! :)
  196. Driver's door problem!
  197. 97, 3.1 Motor Lumina Engine Problems!!!
  198. How do you remove armrests from 91 Lumina APV
  199. 93 APV climate control
  200. ECM Pin Connection Diagram
  201. does anyone have directions for replacing the intake gaskets on a 3100 (3.1)
  202. Service manual or repair manual???
  203. Selling a 92 Lumina Z34...
  204. misfire after fixing coolant leak
  205. Replacing the Starter... oxygen sensor?
  206. Electrical Heat controls running lights
  207. ECM reset on battery disconnect and vaccum line question
  208. 94 APV stalls won't start
  209. Another 93 Lumina Problem!!!!
  210. ABS Light On-STEADY Not Flashing
  211. Automatic Door Locks
  212. 92 Euro trans. conversion
  213. 1990 Lumina fuel pump replacement??? Help!!
  214. Heater Control Light up???
  215. Brake Noises
  216. ABS light
  217. Irratic RPMs.....help
  218. 1995 Lumina misses when cold
  219. 1996 Lumina dash light problem
  220. 93 Euro Tranny Being a Wierdo, and idle 2!
  221. power locks open but won't lock 96 Lumina
  222. 01 wont run
  223. Stupid stuff
  224. #1 cooling fan clicks on late!
  225. body kits 88-94 chevy lumina's
  226. 90 Lumina Sedan Problems, plz help.
  227. Please help with Tranny Model #
  228. 98 Lumina Check engine light
  229. '92 Lumina stalling when brakes applied
  230. i am cunfuzzled w/93 euro
  231. stiff gear selector 96 lumina
  232. No Dash and parking lights 96 Lumina
  233. Cooling fans
  234. Noise in 1998 Lumina
  235. 95 Lumina 3100V6 "Shuddering" at low highway acceleration
  236. Transmission
  237. 91 lumina tachometer
  238. 92 3.4 ignition problems please help
  239. Great joke!!!
  240. wanted cutlass strut tower brace
  241. hypertech chip for 3.1
  242. 3.4L to 3.1L engine swap?
  243. ABS constantly clicks
  244. 90 lumina anything
  245. any milwaukee, wi tranny experts?
  246. Lights dim...engine loud HELP!!
  247. 1992 Lumina Transmission
  248. Headers
  249. 98 lumina coolant leak and noise
  250. Service Engine Soon?
