View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25
  1. Headlight freeplay - need adjustment advice
  2. 97 Lumina 3.1L Head Gasket
  3. 94 lumina apv
  4. Adding Coolant Yo 93 Lumina Eurosport
  5. ??????
  6. problem and what fixed it
  7. cooling problems in my lumina
  8. exhaust question
  9. overheating 1995 Lumina 3.1L
  10. Rear door latch
  11. location of EGR valve on a 92 3.1L...HELP
  12. 98 Lumina Stalls won't restart continued
  13. another tune up question
  14. mods
  15. Replaced Z34's battery = no start now
  16. engine swap, 1991 3.1 engine to 1990 car
  17. 4T60E not shifting
  18. Replacing fuel pump?
  19. Help me plz!!!
  20. 98 Lumina Stalls won't restart until sits overnight
  21. '93 Lumina Euro - slow heater
  22. left rear brake pad - outboard side - HOT Wheel !!
  23. security light comes on and stays on
  24. Z34 for sale
  25. Z34, LTZ owners, a question
  26. Dash lights out 94 lumina
  27. Richtazz?
  28. Gas mileage
  29. Airbox
  30. 90 Lumina 3.1 Eurosport- Stalls when braking @ redlight/stopsign
  31. question bout a weird noise
  32. sill havin problems
  33. The annoying asker...
  34. 3.1 intake job cost
  35. manifold needed
  36. Da** FI
  37. tune up?
  38. 94 lumina trans slips out of gear
  39. General GM question
  40. frozen rear struts
  41. Stalling Again
  42. Service Engine Soon light on my 2001
  43. ???
  44. 98 Lumina 3.1 driveability problem
  45. Multiple 98 Chevy Lumina 3.1L problems, any help welcomed
  46. does any one know where the damn tcc conecter is on the 92 lumnia
  47. 96 Lumina wiper motor install
  48. Lumina windows
  49. 9o lumina flasher I cant find it help please
  50. guess on malfunctioning part
  51. 1998 Chevy. Lumina Help Please!!
  52. 93 stalling out while driving
  53. 93 euro... injector leak...?
  54. Oil Pump
  55. Possible ECM problem Need help :(
  56. Heater Problem
  57. 98 Lumina rear door issue
  58. Goin' to the boneyard.. to pick parts
  59. 1990 Chevrolet Lumina 2.5l Won't Friggin' Run.
  60. lumina turbo manifold
  61. Update on tire review I promised
  62. 92 z34 door handle problems
  63. Compressing rear caliper - Lumina
  64. Websites?
  65. climate control
  66. 92 Lumina Euro Stalling help
  67. need some help please!
  68. 92 euro - PM's and ?
  69. 92 3.1 lumina tcc solenoid help
  70. Switch Gauges
  71. 1996 APV thermostat
  72. 96 Lumina Van Noise in Transmission
  73. I Need Some help with my seats.
  74. engine assembly
  75. 92 lumina runs bad after changing alternator
  76. looking at 90' euro - need input
  77. help me with my 1992 chevy lumnia van
  78. 92 lumina APV 3.8 dies when warm always starts cold,
  79. wanted: transmission
  80. Car dies at red lights....
  81. Question for you guys......
  82. 1999 LTZ Sun Roof
  83. Tranny Slippage on 1999 LTZ
  84. Please Help Me Asap!!!!
  85. Firing order for 95 APV
  86. Wondering Z34 question.
  87. 93 lumina APV code22
  88. please help me
  89. Engine noise
  90. 98 Lumina Troubles
  91. Change oil soon light after oil change???
  92. mass air flow sensor
  93. my car stalls in drive
  94. 1991 Chevy Lumina is dying!!! Please Help
  95. Help 92 3.1 WONT START details inside!
  96. 96 Lumina radiator plug
  97. 90 lumina speedometer drops and lacks power
  98. 92 Lumina Muffler
  99. FEL-PRO 3100 Intake Gaskets?
  100. 96 Lumina wont start
  101. 1990 lumina apv van trouble
  102. Check eng light
  103. 98 3.1 using coolant and soft hoses
  104. my 92 lumnia stalls when the engine gets warmed up
  105. 97 Lumina Transmission problem
  106. still looking for the answer
  107. Blown head gasket on a Lumina, but is it really blown?
  108. WTB: Front bumper and airbags 95+
  109. New IAC, now check engine light comes on
  110. 91 lumina z34 Brake warning light
  111. 95 Lumina won't start - help
  112. 94 Lumina APV won't start
  113. a/c grinding-can i drive it w/o charge??
  114. Z34 turbo??? or blown???
  115. 1998 Chevy. Lumina Help Please!!
  116. check engine light
  117. A/C grinding
  118. Need exterior door handle 1994 2dr Euro
  119. Transmission Falls out of gear or something
  120. 2000 Lumina Problems
  121. Lumina 3.1 oil cooler
  122. Couple questons (91 Euro)
  123. 3.4 DOHC firing order
  124. '97 Lumina LS (3.1L) won't start after hail
  125. Post the sweetest lumina you have seen
  126. Running Lights Wont Come On
  127. cooling system leak
  128. interior
  129. Slave CD Unit
  130. surging confused
  131. Hand E-brake?
  132. '97 won't start
  133. Few questions
  134. 96Lumina sedan/wont shift at all...HELP
  135. turn signal switch
  136. 91 3.1 V6 Ignition problems - no start
  137. stalls.
  138. reattaching rear view mirror
  139. Poll: Lumina 96, 97 or 98?
  140. Help! So totally clueless here...
  141. 1992 chevy lumnia apv transmission
  142. Just a poll re: Ignition key lock
  143. No heat in a 1990 Lumina
  144. 3100 "M"
  145. 3.1 code p1381 p0300 lack of performance
  146. 3.1L v6 For Sale!!
  147. FS: 95 Lumina parts car
  148. 92 lumina
  149. Alternator
  150. lack of heat 99 lumina
  151. Replaced Bearing assembly - Now it creaks
  152. running out of gas...now won't start
  153. 93 Lumina SHITTY GAS MILEAGE
  154. 93 Lumina euro 3.4 High Idle
  155. 1995 Lumina stalls at low rpms
  156. I couldn't be more lost 90 lumina APV
  157. 94 Lumina 3.1 rough running
  158. 96 Lumina Pass-Key Reset Procedure
  159. 91 lumina euro 3.1 question
  160. van will shake
  161. Start on sec crank
  162. 1994 Lumina APV Brakes Problem
  163. tie rod replacement
  164. 96 lumina wont start
  165. information on programming keyless remote for 96 blazer
  166. Low Coolant / Service Eng. Soon Lights 1993 Lumina
  167. no headlights or parking lights!!
  168. no air coming from heater help!!!!
  169. 93 Lumina not starting
  170. 95 Lumina sensor location/name
  171. Cabin Air Filter
  172. 94' Z34 Lumina High Idle
  173. Gm merlin help!!!!!!!!!
  174. Front Speakers
  175. '92 lumina Z 34 Intake Manifold replacement
  176. Roll the engine, C'mon
  177. 1999 Chevy lumina converter help
  178. remote door locks
  179. GMmerlin got a ?
  180. 3.1L Hesitation
  181. Timing Belt replacement
  182. Front control arm bushing replacement...
  183. Need help, trying to grease shift cables...
  184. 1998 Lumona ABS master cylinder
  185. vibration problem
  186. Oil Pressure
  187. Exhaust
  188. '98 Chevy Lumina-Coolant reservoir won't stay filled
  189. Please HELP!!!
  190. Drive axle Hub Nut size
  191. 2000 Lumina not starting
  192. 97 lumina brake switch
  193. intermittant stall/rough idle
  194. To Be Or Not To Be; Lumina That Is
  195. Crankshaft sensor
  196. Lumina Modifications!!!
  197. Remote Start in 2001 Lumina
  198. 96 base model transmission problems
  199. 97 brake problems(loss of pedal)
  200. 95 lumina fuel filter locations
  201. 97 Lumina wont start..
  202. 99 lumina 3.8 sedan exhaust down pipe section
  203. No Heat on 90 Lumina Sedan
  204. Injectors
  205. accessories?
  206. Keyless entry question
  207. remote start/keyless/alarm
  208. 94 lumina Z34 3.4 Pwr Steering fluid leak
  209. 95 3.1 Lumina major probs starting
  210. 95 Lumina service engine soon no code
  211. 1995 Chevy Lumina LS
  212. Location of crank sensor?
  213. 99 Lumina Injector or Coil?
  214. Rough Idle after car sits for about 20 minutes
  215. looking for a Lumina
  216. No high on fan control
  217. 95 Lumina 3.4
  218. NO power under load, backfires thru carb, overheats.
  219. 96 chevy lumina wont start
  220. 3.1 to a 3.4?
  221. car will not start
  222. Seafoam in vaccum line
  223. 92 Lumina turn signal flasher/relay quit
  224. international help wanted regarding temp sending unit!
  225. 3.1 96' torque specs PLZZZ?
  226. 3.1L hesitation
  227. new fuel pump no pressure
  228. Fuel in the vacuum lines. Pls Hlp.
  229. injector cleaner
  230. ACCCKKKKK....My 98 Lumina is DEAD!
  231. Problem with electric fan
  232. 96 lumina issues
  233. chevy lumina apv electrical problems
  234. intake gaskets again
  235. '97 chev lumina check engine light
  236. 98 Lumina misfires flashing SES
  237. Prob with 92 Lumina A/C pulley
  238. Fuel gauge dropping to zero slowly
  239. 94 Z34 idle issue
  240. 97 Lumina Won't Start
  241. relay
  242. drive axle
  243. TPS trouble code
  244. Front of Oil Pan gasket leak 93' Eurosport 3.1
  245. Dash Cluster
  246. 95 Lumina 3.1 For Sale/Swap
  247. 95 Lumina APV problems, suggestions wanted
  248. 91 Lumina Starter
  249. Front wheel bearings
  250. Body Parts
