View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25
  1. coolant leaking from waterpump HELP
  2. 91 Chev Lumina Speedometer Failure
  3. Low compression prblem
  4. 96 Lumina Valve/lifter/rocker noise
  5. 95 Lumina Overheating
  6. 99' Lumina LTZ CD player
  7. 1994 Chevrolet Lumina Euro
  8. door locking problem
  9. Starting Issues
  10. engine code 1641 ??
  11. Looking for MPG figures on 97-99 Luminas
  12. '97 Lumina A/C compressor removal tip
  13. my battery dies all the time & my hood latch is broke.
  14. 1993 Lumina Stalling
  15. 92 Lumina 3.4 is overheating
  16. [Accessory] 99 Lumina 3100
  17. 94 lumina 3.1 overheating
  18. 1997 Lumina Water Pump Replacement
  19. 95 lumina fuel problem
  20. Dual exhaust on a lumina, Input please?????
  21. Service Manual Download
  22. Oxygen Sensor Readings from OBD2- Help Needed
  23. '92 Z-34 lumina major problem with idle
  24. Any help on this topic would be greatly appreciated
  25. Heat problem?
  26. Power locks
  27. 98 Lumina replacing turn signal module
  28. Need pic of TCC location
  29. WTB Lumina Euro lettering
  30. Driving without power steering question.
  31. jeffcoslacker
  32. Replacing Rotors on 96' Lumina
  33. Vandelism proofing my trunk...need help...
  34. Lumina LS, Station wagon views?
  35. Need help locating part.
  36. How I ended up in the back seat when I didn't wanna be....
  37. lumina mods
  38. Brakes holding pressure
  39. need pics of a motor to a lumina
  40. 92 lumina Euro 3.4 cooling fan
  41. 97 lumina cd player wiring
  42. '96 lumina not starting
  43. Car starting rich
  44. Brand new starter issues after alternator install (Clicking)
  45. 1996 dummy brake light is on
  46. clock stays illuminated, drains battery
  47. Mom of 5 needs advice on stalling problem.
  48. need major help
  49. leak
  50. Ltz
  51. '97 with A/C problem
  52. Ignition Troubles
  53. 1997 Lumina Leaking Coolant/antifreeze
  54. stalling
  55. Intake sucking coolant
  56. high idle when air outside is above 80 degrees.
  57. 94 Z34 starts, idles, but step on gas it dies
  58. Lumina Codes
  59. smoking steering wheel
  60. Overheating 1995 3.1L
  61. New member... 1996 Lumina Brakelights
  62. BIG Z34 Problems
  63. Anyone want to buy a cd player for their lumina?
  64. Connecting a 3.5mm connector via AUX on car stereo (96’ Lumina). Is it possible?
  65. 92 Lumina APV gets to highways speed; then stalls
  66. 97 Lumina stumbles on acceleration
  67. vent fan switch malfunction??
  68. Cylinder #4 is Dead
  69. condenser water inside but drain not plugged
  70. Help with 97 Lumina
  71. RWD Conversion
  72. over heating problem?
  73. 97 Lumina Hazzard flasher
  74. Back right wheel wont spin. why?
  75. Uneven tire wear
  76. fuel injection fuse keeps blowing
  77. MPG for 1996 Lumina APV
  78. windsheild tracks
  79. A/C drain plugged!
  80. Turn signals
  81. early lumina's drivers door handle generic problem
  82. 90 Euro bucking while accelerating
  83. sputtering lumina fixed
  84. Help 92 lumina code 23 and 35?
  85. 1997 Lumina AC Problem
  86. 97 Lumina
  87. Lumina Spoiler
  88. Z34 Parting Out
  89. TilT Steerin prblms Lumina Z34 93'
  90. 93 Euro Lumina MPG
  91. cranks but not starting. Ideas please.
  92. Multi-Vacuum Leaks
  93. A/c Blower And Turn Signal 99 Lumina Ltz
  94. how to remove the dashboard?
  95. 1991 z34 3.4 hard start/runs rough
  96. Blower motor problem
  97. I Need Help
  98. rear wheel camber
  99. Drum brakes to Disc Brakes? '97 Lumina 3.1L
  100. Just for future reference, gas tank
  101. Multifuncition lever assy 1996
  102. A dumb question I know.
  103. running rough
  104. 95 lumina
  105. Crank Shaft Sensor --- OR --- Other ignition problems?
  106. 91 Lumina Euro 3.1 power steering hose questions
  107. ways to upgrade a 98 lumina
  108. Maybe my alternator?
  109. Anyone want an alternator to rebuild?
  110. how many gas?
  111. engine replacment
  112. ? in park, rev up engine then it starts going up and down up and
  113. 91 Lumina Z34 Air Conditioning help
  114. Lumina Minivan
  115. 1991 lumina dash light prob??
  116. Torque specs
  117. idiot lights
  118. lumina engine stops suddenly
  119. Lumina Door Locks
  120. 97 lumina
  121. Problem with Car
  122. Caliper Pins
  123. CAI, interesting
  124. Engine Interchange?
  125. 92 Lumina Euro Engine cuts out
  126. Steering Problems
  127. Tailgate lock
  128. Parting out a '96 sedan
  129. air condition
  130. No electric pulse to injectors
  131. Misfire, engine runs poorly
  132. putting manual transmission in z34
  133. self paint job
  134. Lumina APV engine problems
  135. 97 Lumina fuel issues
  136. injector testing (in car)
  137. 90 Chevy Lumina rear strut replacememt
  138. Smoke coming from steering column...turn signals don't work
  139. heater hoses locations
  140. 94 Lumina Euro
  141. 97 lumina crankshaft sensor problem
  142. HELP!!!!!!!!! NO dash or tail lights
  143. Bought a '92 Lumina Z34...
  144. 97 Lumina, lots of issues...
  145. Smelling Fuel
  146. 1997 Lumina Rear wheel ABS Sensor
  147. Do I need new Alternator?
  148. Power Steering Pressure Line (Caused me Stitches)
  149. PCM location on 95 Lumina APV 3800
  150. sputtering lumina
  151. 1990 chevy lumina euro 3.1 turns over does not start
  152. radio reinstall
  153. Idle surge/rough/dies
  154. alternator diodes
  155. location of pressure switchs?
  156. transmission
  157. intake on 97 Lumina - advice needed
  158. 97 Lumina fuel pump
  159. Intake for my Lumina!
  160. injector power
  161. Please Help Me
  162. lumina sputtering
  163. 95 Lumina trans slips on take off
  164. Intake and Exhaust 3.1 Lumina
  165. 93 z34 new front brakes grinding
  166. 1995 chev lumnia van
  167. Seafoam
  168. 94 lumina van electrical problems
  169. location of ac filter for 95 Lumina Sedan
  170. 2001 Lumina idle/maintenence questions
  171. please help a girl.with a 90 lumina 3.1,starting and try pressing gas pedal then dies
  172. Front struts
  173. My Air
  174. How to Find
  175. LS7 in a 93 lumina euro sedan
  176. 3.8L engine
  177. 97 lumina Steering play
  178. 93 Lumina Euro problems
  179. 96' Lumina 3.1 power window motor?
  180. jumping / bucking / stalling
  181. Water Outlet Tube
  182. please help me fix cruise 96 Lumina
  183. could use help with coolant system - 2000 lumina
  184. Manifold / heat shield expansion (99 3.1)
  185. Bad news for my Lumina
  186. Power locks out of control
  187. vacuum leak on a '96 lumina
  188. 91 APV blowing fuses
  189. '99 With a Coolant Leak
  190. Question About Wiring
  191. Brake efficiency in 96 Lumina
  192. Need door panel, and window. Passenger side
  193. location of the temp sensor
  194. 1994 overheating wheels
  195. where is ecm?? help
  196. 1996 Lumina 3.1 idling surges
  197. Same old story--'96 Lumina Will Not Start.
  198. Fuel Sending Unit
  199. 95 lumina
  200. 97 Lumina 3.1 won't start
  201. Lumina wont start
  202. Charging System? Battery Drain?
  203. Lumina Disease
  204. JET Performance Chip for lumina
  205. How can i make my car louder?
  206. 96 gas smell when starting, can I drive it?
  207. any picts or actual mastercylinder - 92 APV
  208. 91 Lumina Apv short in dash
  209. Radiator Fans not working
  210. 97 lumina fuel smell from engine oil
  211. 95-3.1 short in radio/chime module circuit
  212. Oil In The Radiator
  213. learning the 3.1 radiator for the 93 Lumina Euro
  214. 96 Lumina 3.1 // high speed stalls
  215. Rough idles after starting car at high temps
  216. Another Braking thread
  217. 95 Lumina keeps running when turned off.
  218. Service Engine Soon Light
  219. IGNITION PROBLEM-'90 lumina APV 3.1L
  220. Designing Microcontrolled Booster...Need feedback
  221. 1992 Lumina I want the alarm system OFF
  222. Piston Head Cleaning
  223. 1990 lumina stalls only when it's hot outside
  224. Vehicle Speed Sensors
  225. Is the fuel pump going bad or is it something else?
  226. 90 Lumina 3.1 lots of problems. HELP!!!
  227. Idle Out of Control (IOC)!
  228. 96 Lumina Head Gasket Replacement
  229. Ebay Jet Chip?....any good?
  230. air cond. question
  231. Turn Signal Switch
  232. wtb: 90-94 air box and air intake hose
  233. 93 Lumina 3.1L shuts off when hot
  234. 95 drl, cruise, and air conditioner not working
  235. 1993 lumina no spark on #4 cly
  236. 91' Lumina Euro won't shift out of first gear
  237. 93 Lumina 3.1 starting problems
  238. ignition problems
  239. Power Window motor removal
  240. Electrical Problem W/ 96 Lumina
  241. 1990 Lumina 3.1 liter V6 needs help.
  242. '95 losing overdirive
  243. 90 lumina questions about brake booster and wires
  244. airbag light
  245. compressing replacing - need suggetions
  246. How to test coil pack....rough idle on 92
  247. what's the difference between a Euro and reg 92 Lumina
  248. Bought a 98 Lumina lemon! Bucks/hesitates hot on hwy. HELP!
  249. 94 Lumina APV , engine dies instantly after warm-up...please help
  250. Oil pan plug gasket 1990 lumina APV
