View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25
  1. Power sliding door stopped working
  2. 94 Lumina APV Starting problems
  3. 1999 curise control
  4. Heater air flow is stuck in Blend mode and AC doesn't not work
  5. 1991 chevy lumina won't start !!!
  6. squeaky door
  7. '99 LTZ PSP resevoir
  8. 1990 Lumina oil problem
  9. 97 Lumina $1700??
  10. replacing injector, need tips
  11. APV poor fuel consumption
  12. My 92 lumina runs great then like a piece of crap
  13. 98 lumina service engine light problem
  14. Looking for part information
  15. How to determine Bleeder Valve P/N?
  16. Lumina stalls/hesitates/lunges
  17. lumina z34 engine switch but no spark
  18. Interchange steering col.
  19. man i wish luminas had cool body kits
  20. 1992 Euro/Z34 compatible?
  21. How do u lift up the rear deck panel?
  22. Daytime Running Lights on 2001 Lumina
  23. 96 won,t start=
  24. cleaning erg valves
  25. 92 Lumina Cranks But Wont Start
  26. 92 lumina euro stalling at stops
  27. EGR valve question.
  28. No running lights or parking lights
  29. Airbag light dissapears
  30. 92 Euro power sterring
  31. 96 Lumina car daylights
  32. How to take off tail lights? (want to paint)
  33. 3.4 stumbles at 4000 RPM
  34. New filter for lumina?
  35. Air bag replacement
  36. 97 lumina 3.1 #3 missfire bad plz help
  37. EGR valve
  38. 96 Lumina Sedan NEED OIL PAN REPLACEMENT HELP
  39. Temp gauge rising
  40. Gremlins are messin with my electrical
  41. Will a TranSport computer work in APV
  42. 01 Lumina sedan keyless question...
  43. 92 3.4 5 speed high idle NEED HELP FAST
  44. Gas Mileage
  45. daytime running lights not working
  46. Heater not working...
  47. Where should i mount my amp? and my fuse block?
  48. Vapor Cylinoide 98 lumina
  49. The Following Parts Are Available:
  50. Where would I purchase a Vapor Cylinoide?
  51. high nox readings
  52. 1998 lumina just stops
  53. 96 lumina running cold
  54. Power window problem
  55. Locating a Vapor Cylinoide
  56. 007 Car Accessories
  57. Which head gasket?
  58. car does not run right
  59. ignition wiring
  60. Lifters ticking?
  61. heater blower motor where is it in 1990 lumina
  62. Trans 2000 lumina
  63. Rough Idling/Stalling, all 6 cylinders burning super rich, please advise.
  64. Routing AMp cables.... Please help
  65. warning symbals
  66. Weird Hesitation...
  67. miss at idle
  68. 1992 Lumina APV
  69. Engine Knocking!!!
  70. Runs Rough, Smell Gas, Low Gas Mileage
  71. Cold air intake on a 3.1 Lumina
  72. '94 lumina minivan 3.8 stalling speedo jump
  73. 92 Lumina APV 3.1 3t40 no forward gears
  74. 92 Euro Coolant in the motor
  75. Help Im clueless, I smell antifreeze
  76. What is the path for the large belt.. to put on.
  77. Lumina APV Jerking Hesitating
  78. Adjusting Valves on 96 3.1 Sedan
  79. 91 z34 brakes
  80. Dead Battery.1993 Lumina Z-34
  81. grind grind click grind grind click...
  82. fuel pump 95 chevy lumina
  83. Transmission 1991 125c no reverse
  84. Who thinks what...
  85. 96 Lumina APV Wiper troubles
  86. Chevy Lumina 90 Euro Help!!!
  87. Struts
  88. 93 lumina help
  89. Please help give some ideas...
  90. How I fixed my stalling at low rpm 92 lumina!!!
  91. Anyone ever broken a crankshaft?
  92. abs related(?) electrical problem?
  93. 1990 Lumina Euro Stalls/spits/coughs/won't start/run when hot
  94. The Check Engine light 5
  95. 93 3.1 lumina overheating
  96. trans
  97. She just wont start
  98. Chevy Lumina APV Minivan
  99. missing and tach jumping with the miss
  100. Parts Compatibility for a 1993 or 1991 z34.
  101. problems after intake gasket change on 3.1
  102. 1994 stall
  103. 92 Lumina Z34 for Sale
  104. Timing
  105. Power steering fluid 99 3.8
  106. car dies
  107. '92 White vs. '93 White
  108. What is this????????
  109. 91 Lumina - Engine doesn't start right up - have to hold gas down to get it to run
  110. 98 lumina 3.1 missfire
  111. well, lets throw something else in the mix...
  112. cd player
  113. Anyone have a dynomax muffler on their lumina?
  114. flex fuel
  115. issues after a trans swap...
  116. Part ID
  117. Electrical
  118. New driver
  119. New Driver
  120. bad ecm
  121. Starting issues
  122. Block heater, need help
  123. 93 lumina motor swap
  124. 99 Lumina Overheating
  125. push rods and engine ID super riddle
  126. For Sale!!!
  127. Obd1 And Obd2 Code Scan Tool Recomendations
  128. Breaking Caliper Pins
  129. O/d Light Flashing
  130. oil leak
  131. injector cleaner 3m adapter kit
  132. lumina shuddering
  133. 92 Lumina Gas Tank Pressure...
  134. Differences between Monte carlos and luminas?
  135. Need quick advice on if I should buy!!
  136. What all can be done to a lumina?
  137. Did I Get The Shaft???
  138. Idle problem and down shifting problem.
  139. Surge/Hesitation, Stalling, Flickering
  140. Air conditioner trouble
  141. 92 Lumina Z34 won't start has spark
  142. OBD2 <> Computer Interface (115200 K/Bps)
  143. 1990 3.1 No Injector Pulse - Intermittent
  144. wiered problem - coolant/temp/heater
  145. humming noise from back of car
  146. 2000 lumina ABS noise
  147. 2000 & 2001 Lumina chronic problems?
  148. 91 chevy lumina
  149. 1996 Lumina APV overheating - air pocket?
  150. i fixed it
  151. Glass Pack Muffler Exhaust system
  152. '97 3.1 now with new problem
  153. lumina/luminaz34
  154. Abs Warning Light
  155. gettin' there
  156. 98 Lumina won't turn over
  157. Lumina Dies randomly... weird problem
  158. Transmission, disengages, wont go in reverse...
  159. 97 Lumina w/157K
  160. 92 Lumina Shocks
  161. Well.... Im back
  162. 1995 Chevy Lumima central locking tranmitter module - where the h
  163. winshield wipers won't turn off.
  164. Bypass A/C compressor on 3.1 litre
  165. smoke coming out of the steering column ??
  166. Euro Tail Lights
  167. code 42
  168. IMPORTANT:----->>> $10 Oil Filter POLL!
  169. Reaching the lower Manifolds
  170. smoke coming out of the steering column ??
  171. 95 lumina power locks
  172. white smoke and water from tail pipe
  173. Gas fuel gauge needle doesnt work
  174. 99 Overheats when heater is on..
  175. fuel line clean out
  176. 1992 Lumina 3.1
  177. im gunna blow this !@#$%^& car up !
  178. 91 Lumina Oil sending Unit (With gauges)
  179. Automatic door lock
  180. 95 lumina ls flashing low coolant light
  181. Bucking Engine
  182. 93 lumina
  183. Decode a Lumina vin for 9C3 or 9C1 option?
  184. Battery Died
  185. dang 93 lumina
  186. Stupid question about OD and D
  187. Lumina overheats at high speed+a/c problem
  188. Do Not Post Until You Have Done A Search!!!!!!!!!!!!!!!
  189. Idling too high, esp in park
  190. Parting out 92 Lumina
  191. engine temp stays at 210 - 92 lumina apv
  192. button start
  193. Just changed brake pads
  194. Fatter tires for my 98
  195. $1200 CDN for 1992 LUMINA 3.1 is it ok?
  196. clicking sound
  197. 90 lumina problems
  198. Going to look at a 93 APV tomorrow
  199. Thermostat Change
  200. Just completed a Trans. Filter Change.
  201. Heater Blower for 1990 Lumina Van
  202. brake shudder
  203. 1990 lumina automatic trans. pan
  204. Replaced starter, battery, still won't start.
  205. lumina z34 parts
  206. '90 lumina won't stay running
  207. 2000 Lumina TCC stuck on
  208. 1993 lumina rear caliper
  209. Engine
  210. Condensation & Sludge
  211. 94 Lumina APV for parts
  212. Interior Work/Customization on a 1991 Lumina Euro
  213. Where do you charge the AC unit on a 1997 Chevy Lumina?
  214. I/P Electronic Battery
  215. lumina bogging down and cuting off
  216. Broken motor mounts
  217. Screeching noise
  218. 1992 Lumina tcc solenoid wire location
  219. Please Help! 1992 Lumina 3.1 Euro,cranks,won't Start!
  220. tach/rpm problem
  221. 91 Lumina 3.1 Keeps Dying
  222. 1995 Chevy Lumina LS, 3.1 car
  223. How to install a new cd player?
  224. Misfire Cyl. 1
  225. Not a fuel prob... still cant figure it out
  226. 90 Lumina 3.1-Sporadic engine miss & check engine light
  227. '97 A/C Evaporator removal question
  228. NO Headlights and Horn...sometimes it comes on
  229. Lumina Van, 3.1 engine problem?
  230. Worn bearings = loose bearings?
  231. 91 Lumina runs better with EGR valve disconnected
  232. Gasket sealer
  233. front brakes 93 lumina
  234. 1996 lumina security light
  235. 91 lumina no fire
  236. 97 lumina not as peppy
  237. 93 Lumina cuts out
  238. Lumina APV Oxygen Sensor
  239. 96 transmission OD problem?
  240. 99 has a new life...
  241. where is the RKE programming connector
  242. Click Here for Instructions on: "HOW TO IDLE-RELEARN"
  243. Door Locks
  244. resetting car computer
  245. 95 lumina problems
  246. 96 Lumina Keyless Remote Programming.. Help please!
  247. 1995 Lumina Bucket Seat Conversion
  248. flashing drl's
  249. Finally solved my hard starting when cold problem Fuel regulator......
  250. 93 Z34... What would you do?
