View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25
  1. 93' Door Handle/Latches broken ??
  2. pulling the ignition heeeeelllllpppppp!
  3. '98 LTZ Showing Code P0336, What Does This Involve?
  4. lumina 99 warm start problem
  5. Sun Visor retainer clips
  6. I cant lock the doors, from inside...
  7. Help w/'94 Lumina Euro Sport Blower Motor
  8. Need Help Badd Can"t Get Out
  9. How do I bleed the coolant system???
  10. Trade it or no?
  11. ECM 1991 Lumina wheres it at!
  12. Rear valve cover gasket 91 3.1
  13. 95 ls exausting from the radiator!
  14. 93 apv 3.1 TBI no gas coming out of injector
  15. hard start 01 lumina
  16. 92 chevy lumina trouble
  17. 97 Lumina Air Distribution box problems
  18. Fuel Display
  19. Anyone answer one of these questions?
  20. door won't open
  21. 90 lumina 3.1 Euro. Guages misbehaving.
  22. Bleeding Brakes - 93 Lumina
  23. 97 engin swap
  24. Engine swap 96 Lumina now has Bucking?
  25. 1990 Lumina 3.1L , Tried this now what?
  26. i need fuel pump help!
  27. 1993 lumina apv cranks,no start wiring problem?
  28. 91 Lumina Turn Signal problem
  29. Heating Control System
  30. Heating Control System
  31. 97 Chevy Lumina Oil Change Light
  32. 97 Lumina starts but won't shift from park
  33. 92 Lumina
  34. 98 Lumina Stalling
  35. WTF is my car stalling????
  36. clicking noises
  37. Future mod, Maybe
  38. Another easy 1.. 1997 lumina 3.1 A/C compressor
  39. Proof I'm not crazy
  40. 92 Chevy Lumina Stalling
  41. Is a Used Lumina a good buy?
  42. 95 Lumina engine swap
  43. How 'bout one of these in your Lumina?
  44. 93 Lumina Rear Disc Brakes
  45. keyless entry problem.....
  46. 91 chevrolet lumina
  47. This is strange,95 temp guage HELP!!!!
  48. 1995 Lumina APV idel speed motor
  49. trouble code 53 & 23
  50. 91 3.1 Engine Help Plz!
  51. Kickdown cable replacement
  52. Air Bags? Would it be the Best way to go on 98Lumina
  53. Leaking head gasket
  54. 93 lumina driver door
  55. Fuel Injector or Transmission Problems?
  56. 96 Lumina APV Tailgate lock
  57. 97 lumina help
  58. 1992 Chevy Lumina APV -No ignition switch or guts
  59. oil leak
  60. stuck in park --- parking pawl?
  61. 1998 3.1 with internal coolant leak
  62. LTZ Starting and Steering prob??????
  63. 90 Lumina APV 3.1 won't get fuel through injectors! HELP!!
  64. How to replace passenger side view mirror in 98 Lumina
  65. Fuel Problems
  66. 93 Cherolet Lumina backfireing help
  67. 90 Lumina Fuel Filter Trouble...
  68. Coolant
  69. Brakes
  70. '97 runaway idle, erratic upshift
  71. Drivers Window Help
  72. power steering
  73. tranny filter busted!
  74. replacing gauge face on 1998 lumina
  75. Radio removal on 98
  76. Easy Question for 97 chevy lumina 3.1
  77. Can I test a starter with a battery?
  78. Freezing and Overheating... fun!
  79. Post Your Lumina
  80. Cannot Get into my Lumina Doors won't open
  81. Power Steering & Noise
  82. 97 Lumina won't go into Gear or out of Gear
  83. Replacing Outer Door Handles-92 Euro
  84. Automatic lights have a problem
  85. MAF Sensor?
  86. Intermittent Heater
  87. EST Mystery
  88. Tailligths, dashboard lights off all the time
  89. '97 Lumina 3.1 sometimes won't stay running
  90. '93 Lumina intermitt. high revs. above 2mph
  91. 98 Lumina Over Heating
  92. Overheated"HOT",Waterpump wont spin, White cream on the oil cap, WHAT HAPPENED?
  93. OEM part numbers!!!!! AAGGHHH!
  94. Ash Tray removal on 98 lumina
  95. As If Anyone Is Interested???
  96. new lights
  97. Trans cooler lines
  98. 98 Lost low beam and driving lights
  99. Lots Of Problems With 1995 Lumina 3.1
  100. Lumina idles too low and misses.
  101. 97 Lumina Problems
  102. 91 Lumina 3.1 Euro Panel Light Issues...
  103. 96 #5 Cyl Misfire problems
  104. 93 Lumina 3.1 with ABS. Brake problem
  105. Flasher Unit for '91 Lumina APV?
  106. need help - 95 Lumina no dash light or
  107. 93 euro, odd problems
  108. 1995 lumina sedan - rack and pinion remove
  109. Need new seat
  110. Need help, mechanics and dealership dont know what it is!
  111. Lumina (sedan) wing mirrors
  112. 1990 Lumina APV --- Breaking (UK)
  113. Chevy Lumina 3.1L v6 Euro Inheritance
  114. remove caliper bracket from caliper!!
  115. Stereo Questions! PLease
  116. supsension problems
  117. Fuel Rail Assembly
  118. 96 Lumina INPUT NEEDED!!!
  119. Looking for performance mods
  120. Fuel pump relay chattering
  121. Good source for replacement parts?
  122. EST Wire
  123. tranny problems with acceleration
  124. Need Some Parts!!!
  125. Hey everyone,
  126. 96 lumina: should I?
  127. tranny leak question
  128. idle re-learn question not covered by the sticky
  129. 93 Euro problems (electric/battery)
  130. 93 lumina euro tranny
  131. 93 Lumina Euro-no Spark Or Injector Pulse-puzzled
  132. crazy stereo
  133. popcorn noise
  134. Help Locating/Removing Starter From 3.8L
  135. Coolant Issue
  136. Power Steering Whine
  137. 95 Lumina APV 3.1L - not starting - diagnosed my butt off
  138. Should I replace my timing chain?
  139. 3.8?
  140. 98 Lumina knocking and slow accel.
  141. Which plugs?
  142. 99 Lumina 3.1 Spark Plugs
  143. Windshield replacement
  144. oil leak
  145. Alternator Upgrade
  146. '95 APV tailgate lock
  147. 1992 Chevy Lumina rear spark plugs/PCV valve
  148. 1992 Chevy Lumina soft brake pedal
  149. 1992 Chevy Lumina wheel bearings
  150. 91 chevy lumina stall issue
  151. gas gauge ??
  152. battery going dead
  153. 93 Lumina Door Lock
  154. Fuel pump relay chattering
  155. speedometer to fast
  156. Anyone ever had a bad trans mount on a 3.1L Lumina?
  157. help!!! wont start
  158. My '92 Eurosport died, what to do?
  159. Replace Air Box
  160. Replacing coil packs/ICM .. Any tips or tricks?
  161. Newb Lumina guy
  162. Problem with 92 lumina 3.1 v6
  163. Parking brake light won't go out
  164. 94 Lumina APV rough start...int. hiccups...
  165. 98 Lumina Automatic Door Locks?
  166. Trans Shift Problem
  167. hating my 1995 chevy lumina
  168. Driver Side Master Window Switch?
  169. 98 Lumina Funky Fan Problem
  170. 95 Lumina 3.1 Litre Starter
  171. 1998 Chevy Lumina Engine Problems? Engine Swap to 3.8
  172. 93 Lumina
  173. 1992 z34(alternater amperage?)
  174. Oil filter leak
  175. over heats
  176. 1992 Lumina Problem(s)
  177. Lumina won't stay running
  178. Adding New Key to car?
  179. Tune-up tips
  180. Miss at heavy to Full Throttle
  181. Single Mom needs good advice
  182. 92 lumina 3.1 fuel tank problems
  183. 93 Lumina Warm Starting Issues
  184. Intake or Head Gasket
  185. Removing center console to replace carpet
  186. Change Altenator 94 Lunina
  187. z34 stalls
  188. Plug Wrenches
  189. Blinker light problem
  190. '95 Lumina, Dashboard lights out.
  191. transmission fluid#@^&#^#
  192. Clearing codes without disconnecting battery? (92 3.1L)
  193. exhaust though the engine.... hmmmmm!
  194. 92 3.1L Lumina .. random starts - BUT!?!? *pics*
  195. 96 Lumina Wont Start!
  196. Bleeder valve on top of waterpump housing
  197. Climate control not working
  198. 90 LUMINA 3.1 trans. problem
  199. T440 or 4T60?
  200. idle/acceleration issues
  201. to anyone who has replaced top strut isolators
  202. Weird thing happened
  203. Heating problem
  204. Electric Locks
  205. how hot is too hot?
  206. IAC Motor?
  207. Tranny fluid smells burnt, but still red/clear
  208. Has anyone heard from Jeffcoslacker?
  209. Gasoline smell inside car - except when cold
  210. Wet black liquid behind the butterfly valve
  211. Fuel Pressure reads 40 Psi
  212. '90 Lumina Issues
  213. 1996 lumina starting
  214. '90 lumina eurosport speedometer/rpm gage
  215. '90 lumina eurosport speedometer/rpm gage
  216. Transmission and Idle woes
  217. My Lumina doesnt suck
  218. Simple question,... 97 Lumina 3.1
  219. If you know anything about luminas, please help me
  220. looking for Keyless Remote Entry
  221. replace head gasket then bottom end goes???
  222. cooling fans
  223. belt issues help please
  224. Error Code 32
  225. *$#@&# 91 z34 code 12
  226. 91 lumina euro 3.1
  227. 1993 lumina z34
  228. wtb: kickdown cable lumina 90-93
  229. 95 Lumina LS 3.1 won't start after ign. switch replacement
  230. Barely any fuel pressure 92 lumina
  231. Timing Chain conversion???
  232. My lumnia sucks
  233. alternator
  234. Error code 43
  235. Replacing O2 sensor and spark plugs
  236. 3100 engine swap
  237. brake lights, plugs
  238. just a little bit of a FYI
  239. cs130 alternator
  240. fuel injectors
  241. timing belt
  242. Switch out drivers seat
  243. 96 lumina radiator problem
  244. 1997 Chevy Lumina Service Engine Soon light
  245. Any good Lumina repair manuals on video or paper?
  246. Fuel Pump
  247. 1995 Lumina Overheating
  248. Alternator....?
  249. Power windows
  250. Driivers Side mirror replacement
