View Full Version : Let's get Technical!
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. possible european civic engine swaps
  2. Clutch and Flywheel
  3. b16a flywheel
  4. the tranny Tranny
  5. [Need Help] Problemes after ZC Swap
  6. motor mounts b18c
  7. auto to manual conversion?
  8. DOHC ZC stock tb/intake to 74mm, fuel issues?
  9. Engine Swap
  10. underdrive lightweight pulley
  11. OBX power pulley kit
  12. Head Gasket Replaced, but still losing coolant??
  13. my freinds car will not stay running
  14. question about exhaust!!
  15. Swap F20B into Honda Civic EX
  16. b18c1
  17. exhaust header installation on 94 accord ex
  18. Guage Install...Help Needed
  19. diffrence betwen the D16y Vtec and the D16z Vtec
  20. exhaust decibels
  21. Engine & Trans. Swap
  22. how much boost?
  23. Stock Civic EX to JDM-B18c5 swap questions....
  24. Injectors aren't getting fuel?
  25. ls vtec ? about ecu
  26. 11 sec eg hb
  27. ZC Head question!!!!
  28. higher than usual RPM
  29. Smoke at 5500 wide open
  30. hondata ecu
  31. best header for b16a
  32. OBX Throttlebody Spacer
  33. engine swap
  34. A little advide on what to choose
  35. whats better mod to buy out of these!!!
  36. should i change the exhaust piping?
  37. exhaust buzz
  38. drift
  39. Is It Possible
  40. h23 4 door Teggy
  41. b16 or b18 into 96-98..
  42. 2000 si head work?
  43. S2000 engine in 95 Integra
  44. type r for 91 civic 4dr
  45. Weapon R dual spring coilovers, any good?
  46. Timing Belt loose...Help!
  47. Incorrectly installed intake
  48. d16z6 to either H22 or GSR?
  49. how many h22s are there?
  50. 98 civic headlight instillation
  51. Intake manifold
  52. How to identify the different VTEC heads
  53. H22a swap questions
  54. difference between engines
  55. Suggestions on what to do
  56. I want to Swap engines...... please reply
  57. ls vtec turbo or gsr turbo
  58. NA b20? Worth it
  59. "How to build Honda horsepower"
  60. what do ya think
  61. Civic Idle Problem
  62. b18c4 inlet manifold
  63. I love torque!
  64. What motor should I swap in my 92 civic hatchback?
  65. CRX bad timing..?
  66. 1995 civic si B16A2 swap HELP?!?!?!
  67. Important>HONDA COOLANT
  68. b18b vs b16a
  69. Squeak sound while coming down off high rpms
  70. side marker lights
  71. Identify Head? b16a
  72. Car makes weird sounds
  73. awd understeer?
  74. engine swap WISCONSIN
  75. DC Sports JDM 4-1 HEADER for sale
  76. B16B Compression
  77. Where to get engine swap?? Florida
  78. !!!Big transmission problem!!!
  79. can i use a 93 cx intake manifold on a d15b2 head?
  80. zc into my std
  81. H22 Swap Problems <Newbie>
  82. need HELP!!! on auto to standard
  83. 99 accord v-6 timing belt and sprokets?
  84. Cat-Back Conversion
  85. h22a idle problem please help
  86. can i use a two pin connector for knock sensor
  87. Help Me Out My Car Is Throwing Codes!
  88. type of spark plugs
  89. Exedy Clutches Any Good?
  90. Lowering Springs How-to...
  91. civic tranny
  92. 1995 Honda Civic DX Coupe
  93. 1990 integra ls at........check engine light
  94. mugen spec ecu
  95. Engine Swap Questions
  96. with my hx, could i get ex headers, exhaust etc.
  97. LS crank in a B17 block
  98. Best ECU upgrade
  99. Info on frankenstein engine swap in a accord
  100. LS V-tedc
  101. VTEC Issues
  102. 91 Civic DX Upgrade
  103. J1 Tranny b16?
  104. lsvtec in the car, and here comes the question..
  105. honda accord rev limiter?
  106. h22 accord
  107. 90-93 integra axles fit L3 tranny??????
  108. F20B Engine Swap
  109. 5th gen vic DIY's
  110. Toda Bs on a B16A??
  111. 1991 civic headlights
  112. Sh AWD?
  113. JDM motor governor?
  114. installed shift light with rpm activated switch now no tach reading help!!!
  115. how much is too much?
  116. Civic Radiator
  117. can a ex intake manifold fit on a crx dx head?
  118. how to install a cam gear?
  119. shift light wont work please help!!!
  120. h22 + boost = good or bad?
  121. GSR Motor for sale
  122. 91 crx si tranny...whats best fluid?
  123. GSR Motor for sale
  124. Civic-97 clutch problem?
  125. b18c1 swap in 98 civic hatch
  126. My First Engine Swap
  127. Dart Blocks and T sleeves for boosting
  128. What would u do to a H22 BEFORE you installed it?
  129. these 2 b16's.. different?
  130. cooling fan
  131. 1990 integra tailights
  132. Aftermarket Intake Manifold, PCV Question...(turbo application)
  133. spoon sports engine repair kit question
  134. gsr ecu
  135. Ligit LS/Vtec Question
  136. Help: Upholstry for '03 Accord
  137. Get the information of the car
  138. Recieve Information of the Engine
  139. GSR preparation for Turbo
  140. Clutch Pedal Noise
  141. Blown Fuse
  142. L3 tranny
  143. b16 in an Insight?
  144. Earliest B16B
  145. H22 or H23 Tranny? Is their a difference?
  146. tranny yr of birth
  147. honda del sol s b16a1 swap
  148. wire/spark plug questions
  149. big exhaust for a while.... how much would it hurt?
  150. 98 B18C1 into 94 Civic DX
  151. exhaust and ecu questions
  152. What do i need for h23 install?
  153. Prelude loss of power ??
  154. h22 wiring.
  155. 90 Accord Radiator Support Installation
  156. Type R front Lip or Mugen front lip?
  157. b16a2 and b18c1
  158. Spoon rims
  159. motor swap out of a 2000 EX
  160. Which injectors?
  161. How Often.....
  162. question about all viper alarms?
  163. d16a1 swap?
  164. H22A in my 93 LUDE
  165. b18a to 91 civic lx
  166. where to find the engine series
  167. Tune up?
  168. obd1 motor in to an obd2 question
  169. Apexi Exhaust
  170. Cylinder compression ratio
  171. Experienced H22 swap mechanics in Florida??
  172. crank for 96 ex
  173. opinions on this motor set up for FI.
  174. b18b1 crx swap HEPL!!!!
  175. brake lights on!
  176. will H22a exhaust mani fit on f23a?
  177. gsr ecu
  178. 90 Prelude Crank pully
  179. h22 in a 4th gen
  180. V-Tec and DOHC
  181. Difference b/w Gas Octane
  182. VTEC (not really), and DOHC
  183. Will h22a exhaust mani fit A f22a?
  184. how many o2 sensor on first gen b16a
  185. 6 speed integra
  186. CEL is on in 4th gen prelude
  187. a new start
  188. spec list on the three black honda civics in the fast and the furious
  189. AC problems 96 ex
  190. 1996 Civic Reverse Indiglos HelpMe
  191. d15 tranny & parts wanted & h22a 4 sale
  192. b18b1 engine mod
  193. GSR or Ls
  194. Thanks to scallywag
  195. 95 Civic EX Catalytic Convertor
  196. Honda S2000 Flow Bench Head
  197. header for 87 Integra, worthwhile or not?
  198. 91 Accord Transmission Computer?
  199. Premium fuel needed for GSR?
  200. CRX ls intake question?
  201. Diff between Cat-Axel Back Exhaust
  202. Just wondering
  203. B16A2 Hydro with more mods, or B18c Gsr with less mods?
  204. very laggy prelude in hot weather :(
  205. Troublecodes
  206. Camshaft??
  207. Operating specs B16A3?
  208. Dual Clutch
  209. Msd
  210. b16a vs b16a6
  211. vtech and transmission swap
  212. DSM Powered Civic
  213. Vtec
  214. what is dual vtec engagement?
  215. what is dual vtec engagement?
  216. VTEC swap
  217. exhaust mods
  218. f22B2 engin with piston change
  219. can it handle 75 wet shot?
  220. b16a help
  221. Anyone in NY want a ZC Motor?
  222. 99-00 b16a2 or a 99-01 b18c1
  223. transmission stuff
  224. *Injectors* High-Low Imp...Wet-Saturated...HELP
  225. b18b crower cams info
  226. H22, closed or open deck?
  227. Comptech Integra ECU???
  228. ls/vtec parts needed
  229. Questions re "VTEC INDICATOR LIGHT"
  230. Why is VTECH so good?
  231. making cold air fit with b18 swap
  232. custom strut bar...
  233. turbo timer
  234. PBR brake system
  235. ecu wiring diagram
  236. D15B2 head replacement
  237. LS VTEC after effect
  238. 92 Civic Code 43 !!!!!!!!!!
  239. gsr cams in a b16a
  240. B17 Hybrid Motor ( not for the Unexperienced)
  241. What should my spark plug gap be?
  242. catalytic converter?
  243. valve reliefs on ls/vtec...help
  244. my 00' ex swap
  245. Hot or cold plugs for a na gsr?
  246. Horrible Gas Mileage...
  247. s2000/INtegra Type R DC5 pedals fit?
  248. b16a and b18c difference?
  249. Need Wiring Diagram For '92 Accord
  250. b16a into 5th gen civic
