View Full Version : Regal
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. Sticky finish on instrument bezel I console
  2. 1985 Regal won't start. Possible wiring problem?
  3. 99 Regal GS - Couple minor questions
  4. 93 Regal wireless remote programming
  5. 2000 regal -odometer light
  6. Buick Regal 1998 stalls when turn signal on and stopping.
  7. cat converter want code 420 gone
  8. 94 Buick Regal
  9. Blinker bulbs melting near contacts?
  10. car burnt up aless than 150 miles trans rebuilt PLEASE HELP
  11. 91 Regal hood won't release
  12. Speedometer
  13. How To Fix Heated 02 Sensor Regal
  14. Need some real quick help please!
  15. 2002 Buick Regal LS question
  16. MiSsInG 3.8 GS
  17. To attempt or not to attempt.
  18. Hey can anyone help me please... '92 buick regal gs 3.8
  19. power steering reservoir fluid level
  20. 1990 Buick Regal Custom 3.1L shuts off after 5 min. warmup (won't restart until cold)
  21. L27 performance/modding
  22. IP Cluster 00 Regal LS
  23. Intermittent stall & no start- Fuel pump relay makes fast ticking sound?
  24. Radio Wiring Harness
  25. 3100 series upgrades
  26. 98 Buick Regal Tensioner replacement / No start
  27. 90 buick regal PLEASE HELP!!!
  28. Remote leyless entry, Very weird problem.
  29. 94 Regal GS 3.8, multiple starting issues
  30. 3.1 1993 Regal runs until it warms up then won't restart until it cools
  31. 1997 Regal GS - Starting problem
  32. '83 3.8L knocking after oil change??
  33. Need some help! 1996 Regal stalls while driving and then won't restart
  34. Battery dead in my 1994 Buick Regal Custom!!! Can I change it on my own?
  35. 98 Regal rear windows
  36. Installed another tranny, now...
  37. 1991 Buick Regal Custom- Lateral Stab Bar R&R
  38. 93 regal tensioner came off!
  39. 89 Regal Tail light issues need help please
  40. 94 Regal Custom electrical lights dim
  41. Basic Cold Air Intake
  42. installing new stereo in a 1992 buick regal gs
  43. 93 Buick Regal Lmt
  44. Battery Gauge
  45. Is there a section for standard repairs?
  46. 1991 Regal Custom - High Idle
  47. 1990 buick regal radiator
  48. 95 Regal won't start after sitting
  49. 2001 Regal, rough start, power steering rumble
  50. 92 regal 3.8
  51. 98 regal no start/code 1610,1626
  52. Strut Recommendations
  53. help me with 92' buick regal?
  54. '88 Buick Regal sputtering badly. Only has 34K miles on it! Please help
  55. 93 Regal 3800 door locks
  56. buick regal 94 custom stalling problem
  57. Installing Rack and Pinion in 2002 Buick Regal LS
  58. 99 Buick Regal blower motor problem
  59. 84 T-type "sneezing" out turbo
  60. 93 regal GS electric problem
  61. 92 Regal code 17
  62. Loud squeeling sound-97 Regal LS
  63. Headlignts and highbeams
  64. fuel pump or sensor??
  65. 92 Buick Regal
  66. water leak
  67. 1991 Buick Regal Won't Start!!!!!!!!!!!!!!!!!
  68. 93 engine swap?
  69. 92 Buick Regal
  70. GS vs GSX
  71. 1999 regal
  72. heater and a/c dont work
  73. 1999 regal gs
  74. Brake system gone haywire
  75. 84 t-type vacuum diagrams and firing order for coil pack?
  76. 94 GS - Zero Compression
  77. Auto lights turn off when blower motor turned on
  78. Power steering stiff when cold
  79. Shift Control Cable
  80. 01 regal seat warmer
  81. '98' Buick Regal
  82. trouble code dtc u1153
  83. Fog lights for older body style? - 1995
  84. 2000 regal GS ecm ?
  85. 93 regal ABS/BRAKE warning light + alternator "gauges" light
  86. 83 regal t-type compression limits
  87. Light electrical problem
  88. 94 Regal 3.8 Engine - How To Change TCC Solenoid
  89. battery change
  90. 94 Regal 3.8 Engine - Codes P0705 & 1406
  91. 96 buick regal 3800 type 2
  92. 90 buick regal transmission problems
  93. 97 regal gs radio
  94. 97 regal gs
  95. Broken Fuel Line
  96. 1993 regal gs power steering line
  97. Water Leak keeps coming back
  98. 98 Regal ls/P0507
  99. Check Engine Light doesn't work
  100. 1994 regal 3.8 problems starting and stalling
  101. Tensioner Pulley Remove/Install
  102. 94 Regal Shuts Off
  103. 97 regal low beams not working and drl
  104. 83 Buick Regal for $300.00, good deal??
  105. 1999 regal
  106. Basic Engine upgrades to get a little more
  107. wipers stop in upright position
  108. Climate Control Lights
  109. 4T60 no forward or reverse after sitting overnight
  110. supercharger
  111. 94 regal custom hard starting
  112. 1996 regal wont start
  113. '92 Regal won't start
  114. Supercharged 3800 maintainence
  115. 2001 Regal Backup/Reverse lights not working
  116. 92 Regal Turn Signals?
  117. 1988 Buick Regal Stalls and Won't Start
  118. Digital Dash broken, odometer?
  119. computer woes
  120. exhaust
  121. 99 Buick Regal GS Heater problems
  122. new or used struts
  123. how to get to a 1991 regal starter
  124. rims...
  125. 98 regal gs 3800 supercharged
  126. 1999 odometer light
  127. 1993 Regal windshield wiper switch
  128. '91 3.1 won't run with gas cap on...?
  129. Please Help
  130. 2001 Buick Regal LS shifting & digital gear display
  131. What oil to Use?
  132. 01 Buick Regal LS
  133. 94' Regal GS charging issues
  134. 2000 regal front headlight doesnt work
  135. A/C Compressor Noise
  136. 97 regal LS jumpy speedometer needle
  137. 1999 Regal LS Headlight Aiming Problem
  138. 98 Buick Regal only start w/lights on
  139. 92 Regal no start, no power, no headlights, possible bad ECM?
  140. 1990 battery cover issue
  141. '93 Regal Custom problem with a fuse
  142. Where is the window ground landed?
  143. 91 regal problems starting
  144. 99 regal GS not charging
  145. 91 regal stalling/wavering idle
  146. water leaks
  147. ignition cylinder won't come out
  148. 1999 buick regal
  149. 88 Buick Regal won't stay running
  150. 1986 carb tuning help???
  151. 2000 Regal GS supercharger whine
  152. I need a compatible models for a driver side bucket seat. (94 Buick Regal Custom)
  153. AC / Heater blower Motor always on
  154. 1991 buick regal 3800 died out wont start
  155. 2004 Regal Brakes and ABS Light
  156. Will Not Start
  157. electrical gremlins
  158. buick regal window regulator or motor?
  159. Climate Control and Cruise Control Problem
  160. 1999 regal gs
  161. 1993 Buick Regal Keyless Entry Receiver Module Location
  162. 99 Regal LS hesitation up hill?
  163. 1990 stalls when brakes are applied
  164. Whinning sound. Transmission going???
  165. 1996 Belt Tensioner
  166. Tire Pressure?
  167. Window regulator question...?
  168. rear struts
  169. hesitation/jerk 2001 Regal LS 10-15 mph
  170. What number tranny?
  171. whinning noise
  172. transmission problem?
  173. '95 Regal GS Intermitting problem - need help badly!
  174. sway in rear end?
  175. 1999 regal gs
  176. 2000 Regal - Backup and license plate lights not working
  177. Regal low shift points
  178. abs sensor for 2000 regal LS
  179. 01 Regal 3.8 intake manifold???
  180. right window will not work(need to take off panel)
  181. Regal '91 - brakes control solenoid
  182. anti-lock brake light
  183. overheated buick regal
  184. 1999 Regal Stereo Speaker Removal
  185. 96 Regal continual brake issues
  186. Sun Visors
  187. 1990 buick regal radiator drain plug
  188. 91 Regal GS 3.8 no spark
  189. Power Moonroof Switch
  190. 98 buick regal wont start
  191. Buick regal 2000 HVAC
  192. low coolant light
  193. Horns goes off when ever it feels like it!!!
  194. 99 Regal LS 3.8
  195. Ignition problem - 2001 Regal
  196. 93' Buick Regal "Low Oil" Light On.....
  197. 99 Regal Supercharge...starts but dies immediately
  198. new Regal Moderator
  199. 1993 regal idles rough
  200. 96 Regal ABS light on
  201. 2000 Buick Regal GSE Fuse Block problem
  202. '99 vent doors noise?
  203. please help me 97 buick regal!
  204. 93 Buick Regal shutsdown
  205. 2002 regal 3.8 loses power on hills
  206. 92 Regal blowing fuse pump fuse
  207. 2000 GS Stalling
  208. 80 buick regal oil in the air cleaner
  209. 1980 buick regal
  210. broken power window switch 97 Regal
  211. 98 Buick Regal GS list of problems all at once
  212. 1993 regal 3.8l starting problem
  213. Bleeding Brakes ABS '92 Regal
  214. How to disable just the auto door lock feature?
  215. low blower speeds
  216. 90 regal 3.1 autocross car
  217. 98 Buick Regal won't start
  218. Window Stuck 98 Regal GS
  219. glove box broken
  220. 98 regal a/c problems
  221. Hi, Problem starting after battery drained
  222. 99 regal ls dash HVAC door control
  223. Turn signal problem
  224. paint code
  225. 1993 Buick Regal Limited 3.8L
  226. 1996 buick regal 3.8L AT, intermmitant stalling & hesitation
  227. replacement door
  228. 02' Buick Regal
  229. Emergency flashers not working
  230. 2002 Regal Light Problems
  231. blown fuel/ECM 20 amp fuse
  232. CPS Code Problem
  233. "Service engine soon" "Trac on" "ABS" lights
  234. 93' Buick Regal Random Ringing Sound
  235. 1992 Buick Regal: Air-Conditioning Problem
  236. GM Dealerships
  237. Dtc P1406 Egr
  238. 02 Regal Shutting Off
  239. 1993 Buick Regal 3.1 Repair
  240. 94 remote problems
  241. 1996 Buick Regal Custom 3.1L, Will it spin'em?
  242. 2001 Regal stalls at idle when cold.
  243. Door Panel Removal ('94 Regal)
  244. Window Regulator Help
  245. 1997 gs
  246. 1992 buick regal gran sport oil locator
  247. DTC code P0102 1999 Buick Regal GS
  248. 91 regal 3.1 engine problems
  249. 96 Regal Custom: After Brake Job Rear Break Knock when Foot Pedal is Pushed
  250. 2001 Buck Regal Climate Control A/C blower
