Cutting out at idle.
jdman79
10-14-2004, 11:13 AM
My GR tip has started to cut out when im idle.
It only happens sometimes and if I rev it to about 2000 revs when im standing still and keep it there for a few minutes it will be ok.
Sometimes its fine and sometimes I start the engine without reving it and it just dies on me.
When it is fine it just sits there at about 1000 revs and stays there.
This can be a problem when I get to a junction and have to stand still. Ive been using my left foot for the break and reving with my right foot just to keep the engine going.
Apart from that, its fine!
Anyone got any ideas on what this could be? Alternator? Fuel pump?
Thanks in advance.
Thanks in advance.
KENFTO
11-01-2004, 02:04 AM
No man it's not the pump, and not the alternator probably. I'm 99% sure it's your stepper motor....VERY common problem! But easy.
Go to www.ftooc.org (http://www.ftooc.org) and visit the forum....make a search for stepper motor, or idle speed control, and you'll get an infinity of info and links on how to test, clean, or replace the stepper motor. Very easy job and just takes a couple of minutes ;-)
Should you have to replace it visit http://www.camskill.co.uk/products.php?plid=m3b0s9p362
These are FTO specialists and their contact is a must for any FTO owner...btw my user name on the ftooc site is KEN.
jdman79
11-04-2004, 07:30 AM
Thanks Ken.
TRD2000
11-09-2004, 01:16 PM
haha thats the exact problem i came here for! my g/f's is doing it.
hey Ken, you said just a couple of minutes, but what i found says take out the throttle body and test the connections with a multimeter. Is there a quick easy way i didn't find?
KENFTO
11-10-2004, 02:37 AM
:grinno: Whoever said you need to take out the throttle body is wrong. You only have to pull of the intake pipe FROM the throttle body simply to get this pipe out of the way to gain access to the stepper underneath it.
Then you will see the stepper motor there. If you just need to test the connections it can be done leaving the stepper installed: just unplug the loom and test the connections with a multimeter as described in http://homepage.ntlworld.com/jaycom/fto/engine/stepper.htm
Should you need to remove the stepper to do it outside or be a bit comfortable, it's just a question of 2 screws...as I said a couple of minutes jobbie :grinyes:
TRD2000
11-10-2004, 12:46 PM
cool thanx ken.... will give it a try
TRD2000
01-10-2005, 01:10 PM
just for the record, that's exactly what it was and it took the mechanic an hour to fix under warranty.
KENFTO
01-11-2005, 02:36 AM
Glad to see it got sorted mate, but your mechanic took a bit long at it IMO but at least it was under warranty. Did you have to replace it or just a good clean? The cleaning might have taken a bit more time then
TRD2000
01-11-2005, 02:00 PM
got replaced, they may have been able to clean/recoil it but they went for a new one, prob something to do witht he warranty, there was a $100 excess, but the part was like 300, plus a bit at the mechanic. could have taken all day if he wanted, we weren't paying for once haha.
mracornish
04-25-2005, 04:52 AM
can anyone help me ...
I have slight problem my , I have a 1995 2.0 V6 MIVEC FTO GPX.
I had the Stepper Motor replaced due to idle messing around ..this seems to have fixed the problem I was having at then time
but I have another problem now ...when the car is wet it stalls.. it will drive and start fine .... but when I come to a stop it will stall ...but only when it is wet.
KENFTO
04-25-2005, 07:12 AM
,,Hi mate,
What I find strange in your case is that it is only stalling when wet! :screwy:
I just can't see a connection between the stalling because the car is wet. There are other potential reasons for stalling like the throttle position sensor, apart from other obvious things like clogged fuel/air supply, but again I just can't figure why it only happens when wet :eek7:
Sorry :disappoin
,,Hi mate,
Sorry :disappoin
TRD2000
04-25-2005, 03:37 PM
water getting in ignition components perhaps. i realise that with the bonnet and all this is unlikely... but it might cause the problem.
KENFTO
04-26-2005, 02:15 AM
water getting in ignition components perhaps. i realise that with the bonnet and all this is unlikely... but it might cause the problem.In theory yes but on the FTO these components are well hidden away safely...also there isn't 1 ignition coil but 3 of them tucked in over the plugs of the front bank under the mivec cover. Each coil feeds 2 cylinders.
Dunno but the fact of it being wet might just be a coincidence perhaps and the problem is something else, for example clogged fuel (filter, lines, pump, injector, etc.) or air (filter, incorrect fitment of variable inlet manifold motor. Before changing the stepper has anybody fiddled with the idle screw? Perhaps the idling is too low and in the wet you might have lights, wipers, and perhaps demisters on so the load on the engine might be too much then for an incorrect idle speed and it stalls. Also are you sure the stepper is plugged in correctly, do you hear it functio when you switch on/off the engine?
Texasviking
01-15-2008, 11:06 PM
I have 2001 Celica GT, Auto, Injen intake, TRD exhaust...
I have the same problem of the car stuttering and losing power but only when it's raining or very wet outside. Did the poster who has the same problem ever figure this out? I've brought the car in to the mechanic and I get the same response that they can't duplicate the problem and there's nothing they can do. I've thought of buying a waterproof cover for the air filter but I'm not convinced that that's the problem and I don't want to go throwing money away at every possible suspect.
Also, the engine blew last year during a thunderstorm (my fiance was driving so I'm not certain what it was doing before it went kablooey) and when the mechanics did the post-mortem on the engine they didn't find anywater in the engine and they blamed it on valve-float.
superok
08-31-2009, 09:19 AM
hi bud cud u tell me were about the stepper motor is so i can take it out any help wud be great tanx r my email addy is superstallion2008@hotmail.com plzzz help as ive a large pain with me car cuttin out and its a automatic if dat helps tanx again
paul112004
09-07-2009, 03:56 PM
hello wonder if anyone can help me i bought a fto mivec 95 plate and when i drove it first of all it was fine but few days after i had it the battery went flat so i replaced it ever since then i have had idle problems in the morning i have tried the volts test the ohms test cleaned the stepper motor replaced it 3 times but i did get all 3 from the breakers for a tenner but i cant see all 3 broke each time i check the ohms there perfectly fine and there is no carbon on them or inside and they move fine i have replaced the throttle body the throttle control valve and set it up to the instructions i got of the internet and the manual i have changed the isf sensor i just cant figure out why it will not idle when cold i can even smell petrol when i start up in the morning could it be the o2 sensor doing this to the car it uses so much petrol now and i am getting slightly annoyed i dnt want to go buy a brand new stepper motor to find its not that any hints please i have the car for sale now as its getting on my nerves that much but hopefully if i can sort it soon il keep it
