1999 Crown Vic Police Service Wiring Question
mtnchar
06-07-2004, 09:34 PM
I've got a 1999 Crown Vic P71 and wanted to take advantage of the police wiring package to power an stereo amp and a CB radio. There is supposed to be a 50 amp continuous service and 30 amp switched service available which would be excellent for powering stuff, but after standing on my head looking at the wiring harnesses coming into the passenger compartment I cannot find the wires that should be there (A large black wire with an orange stripe for the 50 amp connection and a large black wire with a light green stripe for the 30 amp).
So either the color coding on the ford wiring diagrams is wrong or these wires come in somewhere else or don't come in at all. The battery junction box has the correctly colored wires coming out of it but they never seem to make it to the right hand side of the instrument panel where Ford says they should end. There appears to be a police power relay in the #4 relay position, since I don't know why else there would be a relay here unless you have air suspension which my car doesn't have. Also fuse 16 is there for the 50 amp connection and fuse 4 is there in the box for the 30 amp connection. I can see the large black/orange wire coming out from the junction box but after that I don't know where it goes.
Ford's diagrams show connectors c247 and c246 being just to the left of the glove box but I can not find them. These are the two connectors that suppose to allow the connection of the police equipment, one is the 50 amp service and the other is the 30 amp service. Might these connectors be behind the radio? Is it worth taking out the radio to see?
Was the police wiring optional on 1999 P71s? My car was a pretty stealthy P71, from the looks of it they had only one antenna on the trunk and a bunch of stuff installed under the hood and trunk from the looks of the holes left behind. When they took off the police equipment they didn't leave any electrical connectors behind under the hood or the trunk that I could find. I wouldn't think they would have cut out all the power connections when they removed the police equipment.
If anyone wants the Ford wiring diagrams for the 99 Crown Vics, let me know, I'm happy to email them to you.
Thanks for the help,
Charlie
Charlie
ModMech
06-08-2004, 12:19 PM
The Police Package wiring was standard. You will typically find the wires on the passenger side near the top of the carpet in the footwell, although they are sometimes routed under the carpet to a spot between the front seats.
mtnchar
06-08-2004, 12:52 PM
Hey Thanks so much for the tip. The police wiring was buried under the carpet/sound insulation just where you said it might be, found both the red and the blue connectors. I shouldn't have listened to Ford tech manual.
I was really thrown off by the Ford diagrams whiched showed these connectors (C246/C247) being up high under the dash just to the left of the airbag behind the instrument panel. I dug around up there till I was crazy and unwrapped the tape from part of the various wiring harnesses looking for those elusive wires. Glad I can tape it all back up now.
Thanks again for the info, I'm was almost considering splicing into the regular accessory wires in the wiring harness but I really hated that idea, this is so much nicer and cleaner to used the existing police circuits plus its nice to have all this stuff on its own heavy duty circuit and not have to worry about capacity.
Charlie
Charlie
ModMech
06-08-2004, 01:57 PM
Glad to have been of help to you.
tkhilliard
06-09-2004, 09:22 PM
is this the same for a 93 p71? which wire is which if it is?
InPrimer
06-29-2004, 11:19 AM
Charlie
Hey Charlie, I also have a '99 P71 that I just bought and would be interested in that wiring diagram. You can send it to me at shawner75 at juno dot com. Thanks!!
Charlie
Izy
07-27-2004, 03:05 AM
Me too! I would love a copy of the diagram...i cant find very much info on these p71. Of course im an amature and have only been an owner (2nd one) for 3 4 years now...Thax Iz
officerbill
07-28-2004, 02:32 AM
I'll take a copy of that diagram also... Have a 1999 Vic P71
Please email ro officerbill@earthlink.net
Thanks a bunch
Thanks a bunch
jpitts
08-18-2004, 11:12 PM
I am in desperate need of one.
And I'm too broke to go and buy a good one!
PLEASE e-mail me a copy at jsp254@msn.com
Warren'74
08-23-2004, 02:23 PM
The wiring is on the passenger side, it usually comes out about the center, or right center of the passenger underside dash.
You will have a red, and a blue connector, each with 3 round holes in the connector end. The red is powered all the time, the blue is ignition switched power. One hole=one power outlet. Hence 3 red outlets, and 3 blue outlets.
HangFire
09-09-2004, 11:29 PM
Charlie
Hey Charlie,
I'd like a copy of that wiring diagram, I just bought a '99 Crown Vic P71 too!
Thanks,
HF
Charlie
Hey Charlie,
Thanks,
HF
Samw
09-11-2004, 04:13 PM
Love those Crown Vics! Reminds me of when I used to drive a gasoline tanker.
HangFire
09-12-2004, 07:09 AM
LOL!
Do you know anything about an aftermarket plate that goes between the diff and tank?
LOL!
lujedunit
02-10-2005, 02:18 PM
Charliei would be interested in the blueprints if you are still willing to e- mail them. thanks
backyard_mech420
02-11-2005, 01:34 AM
You've obviously never driven a Crown Vic if you think it would drive as slow or clunky as a tanker.
magnumforc
04-17-2005, 10:02 PM
Best connectors are bullet connectors (overside available from electronics wholesalers) that allow fast and easy connection to either battery or ignition source. All P71's have the same connectors in the same place, although the 2004 and 2005's now have an available power distributionl block or box in the glove box for power distribution as well as an additional power distribution box available in the trunk, IF you have one that was purchased with the Police Prep setup. There are several levels of wiring available from Ford Fleet, including the base setup and two levels of police prep that includes various stages of wiring for lights, siren and wig wags, radio rack, etc. The complete package now includes LED lights and flashers, strobes already in the taillights and corner lights etc, a strobe power supply, a fan for the trunk, wiring tunnel down the center of the floor, a part console for gear etc. Quite a package all ready to go!
slammedcavi254
06-26-2005, 08:52 PM
cani get a copy of that diagram?? thanx slammedcavi254@hotmail.com
magnumforc
06-26-2005, 09:12 PM
LOL!
The plate is part of the Police Upgrade package and is nothing more than a small lip protector for the diff edge.
hexham
08-30-2005, 10:04 PM
Hey Charlie,
If possible I would really like the wiring diagrams my email is mcgrah@email.com. I have the '00 P71 should be pretty much the same (sigh of hope). I would like to reconnect the aux. power in the trunk, when they decommisioned the car they just cut the lead but left the outlet. I have a feeling that the car was rewired coz I can't find the matching wire and I've taken all the tape off all the wiring in the trunk.
goody54
01-28-2006, 07:08 PM
Charliehey charlie ill take a copy of the diagram if you happen to still have it.. my email is raceresq54@yahoo.com
therepoman
02-18-2006, 02:35 PM
i got a 1999 crown vic police intercepter i have no head lights or tail lights, in need of circuit breaker or fuse panel info for headlights i do not have a owners manual. thanks dt
batrachian
02-24-2006, 09:50 PM
cani get a copy of that diagram?? thanks pin2000_01@yahoo.com
williamain
07-09-2008, 11:43 PM
Charlie
may i please get a copy of the 99 crown vic wiring diagram sent to willimain@msn.com thanks in advane
Charlie
sdaugherty80
11-25-2008, 03:08 PM
What kind of connector do you use to connect into the 3hole connectors?
Davescort97
11-26-2008, 11:52 PM
Welcome to AF. This thread is over 2 1/2 years old. It is unlikely they will reply to your request. If a thread is over 3 months old, start a new thread rather than resurrecting an old one.
kakarot75a
03-06-2009, 07:30 PM
hello, i just recently picked up a 99 P71, and i am curious about some of the connectors and such left in the vehicle, one in particuler is a box mounted in the trunk on the driverside behind the carpet board, it's aprox 4x2x3 inches and has what looks like a red button on the top of it. any idea what it might be? if no one knows i can go take a pic to post to show it. and i'd very much like to have the 99 P71 wiring diagram sent to me if it is still available for distrabution.
magpi1
12-12-2010, 12:54 PM
may I have the wiring diagram for the 99 cvp71 too.
point6000@aol.com thanks and merry christmas.
avwolf
10-26-2011, 07:53 AM
Hey I have a 1999 Crown Vic P71 trying to install a Viper Auto start and having trouble locating the Tach wire. From the wiring info I was able to find out it's supposed to be a White / pink wire at the PCM located under the hood on the driver side of the brake master cylinder. There are several connectors of there does any one know what the PCM looks like? I find one connector on the fire wall (with a cover and a screw holding it on) but I didn't mess with that. I found another connector right under the brake master cyl that had like 45 wire's on it and found one wire Pin 32 (looked like a dirty white with pink wire), when I probed it with Meter set to A/C display showed .5v on meter. From what I read it's supposed to have 3-5V.
Can anyone help?
Can anyone help?
Saruanyrube
12-26-2011, 08:59 PM
hey gentlemen i was curious to know if anyone of you guys can help me i have a 2001 crown vic p71 interceptor and i was wondering if you can help me reconnect the strobe lights (white) that are in the front headlights and also if you can help with a solution for a horn of somesort
bill45colt
04-18-2012, 11:53 PM
Im another who would like a wiring diagram please!! Thanks bill45colt@yahoo.com ford PI 1999
Mello1
12-05-2012, 11:30 AM
I would like a wiring diagram please. Thank you very much! I need all the help I can get! :biggrin:
bill45colt
12-05-2012, 08:39 PM
Im trying to wire 250 watt aircraft landing lights behind grill. Im going to run them on relays of course. Need the correct wire for high beam headlight. Im trying to run relays from high beam so they all come on with high beam--thanks bill 45 colt at yahoo.com
AlmightyOatmeal
12-24-2014, 08:24 PM
I'm in dire need of the wiring diagrams for a 99 crown Vic. I'm on the verge of starting a Kickstarter project to collect money to start my crown Vic on fire and roll it down a hill. Feel free to email me: jamie.ivanov@gmsil.com
Thank you!
Thank you!
