93 Grand Cherokee transfer case destroyed
madrieger
04-28-2014, 02:21 PM
My daughters 93 Jeep grand cherokee with 4.0 and 42RE, transfer case was destroyed when she felt a vibration going down the highway and heard a big thump.
Drive shaft going to the front axle appears to have come out of the front axle and tore apart the transfer case.
I was wondering if someone can ID the transfer case from the attached pictures since the part with the ID tag is gone. Thanks for the help.
madrieger
04-29-2014, 11:33 PM
Here is a piture of the shifter inside the jeep.
Johnobub
02-04-2015, 10:19 PM
The NP242 has an aluminum case and it should have a tag on the back saying New Process Gear, Model 242. New versions of the NP242 are refered to as NVG242 or NV242 which stands for New Venture Gear. The tag on the back of the transfer case will reflect the name change. Only the name is different.
The chain driven NP242 is a full time transfer case with a 48/52 torque split front and rear. It is possible to lock it into four low so it behaves like a part-time transfer case. When it is locked in, power will be split regardless of traction. The output for the front axle is on the drivers side. Low range is 2.72 and high is 1.00.
Usage
The NP242 is used in Grand Cherokees (ZJ) and Cherokees (XJ).
Usage
