Urgent - SRT8 cut out problems
dad635
05-26-2012, 07:23 AM
My 2007 SRT8 has started cutting out without warning - bit scary on the highway - and usually when I back off the throttle. After a while I could restart it and go, but lately it is getting worse, cutting out and varying from turn-over but no start, to start but cut out exactly 2 minutes later.
I have been hunting desperately for a Service Manual, or at least the wiring diagram, but no success. Error codes give no clue and local dealer here not able to spot the fault. It is too risky to drive right now so hoping for some help to either locate the manual, the wiring diagram or better still the fault.
Thoughts around faulty fuel pump, fuel pump connections, crank angle sensor, camshaft sensor, engine RPM sensor.
Any other thoughts appreciated as it is an expensive yard ornament.
:confused::banghead:
