Fuse block
invisiongrafix
08-30-2011, 05:52 PM
Anyone know where I can find a diagram, including fuse identification, for the fuse block in the engine compartment in a 94 Grand Cherokee?
jeep123456
02-23-2013, 08:39 PM
ok 1 is under hood on passenger side the other open passenger door and its right there but 1st what is your issue if you know this then look up jeep and find what you have like grand or limited or whatever then it will tell you what amp fuse to look for like a 10 amp is blue and it tells location as well so turn on car pull 1 at a time if your system stops thats the one or alot of times you can look and see there blown so hope this helps
