Low speed Aux fan not working
Tampa 735il
10-15-2010, 06:45 AM
88 735il
No fan operation at what point on the gauge does the hi spped fan cut on?
No fan operation with compresor on.
I have checked the fan works bypassed: Replaced the fan sensor and temp-2 sensor, coolent sensor works.
I have checked both relays hi and low both have voltage and fuses are good. It seems like the resistor maybe the issue I will check that today.
I never let the car heat up over 1/2 way which maybe why the hi speed fan does not come on unless bypassed.
Does anyone know what value resistor is?
Tampa 735il
10-15-2010, 05:10 PM
Resistor is bad it's open!
lincolnmaster80
10-17-2010, 01:59 AM
I was just going to say, sounds like a resistor failure...but you've already figured that out. :)
