View Full Version : Sportage
- Kia 2001 Sportage 5-door 4x4 - Fuel leakage
- Modifying a Kia Sportage
- Sportage highway comfort
- 01 sportage window problems
- Intermittent starting
- Brake problems
- Gone
- Mystery noise
- 2005 Kia Sportage problems
- Kia Sportage problems
- Greykia
- 2009 Sportage AC issues
- 2001 Kia Sportage, Rear axle seal
- 2008 combination/related problem
- 2001 kia sportage heating issues
- obd 2 trouble codes for kia sportage 1998 - 02, 15 & 17
- No accelerator response
- Rough Idle while stopped
- Rattling/Grinding Sound When Going Uphill 2001 Kia Sportage
- 2000 Kia Sportage will not run
- 99 Sportage 4x4 auto not shifting
- 2007 Sportage smells hot and has started idling down at stop
- rear differential '95 sportage
- 2001 Kia Sportage
- Door lock/unlock issues
- kia sportage 2000
- 2008 Sportage V-6 spark plug replacement
- Starting problem with '99 Kia Sportage
- 2002 kia sportage
- Need some help
- 97 kia sportage wont shift
- alternator not charging at idle
- 01 Sportage intermittent power loss w/no pattern
- KIA SPORTAGE Car DVD Player with GPS Navigation
- Transmission Shift Issues?
- fuel pump?
- Stalls when braking (solved!)
- KIA Sportage simple decoration:)
- Gear Oils
- 2001 Kia Sportage Vibration
- kia sportage 2002
- 00 Sportage Won't start?????
- Kia Transmission Clunking/Vibration.
- Stuck Transmission?
- timing belt questions
- 02 Sportage 4wd
- 2009 Kia Sportage low tire pressure light stays on...
- 2001 kia sportage hubs
- Kia sportage no power on climbing hills
- 1994 kia spotage
- Kia sportage burning No 4 coil
- Fouling spark plug and missfire
- front hubs
- 2000 Sportage Electrical issues?
- Holding won't disengage!!
- 2000 Kia Sportage Starting Problems
- Overheating issues
- 2000 Kia Sportage rough idle
- Check Engine Light
- Transmission? 1642??
- Check engine codes
- 98 Sportage Overheating in Heater
- 2000 Sportage Fuel Gauge Not Working...HELP!!
- 01 Kia Sportage 4x4 DEAD No start No power Needs jumpstart everytime
- Sportage 2007 Loss of engine torque.
- 2k sportage
- 99 kia sportage trouble need help from someone that knows kia"s
- do fuel from the tank
- How to get the best deal when buying a new Kia?
- No diesel out from diesel pump.
- Flashing hold and Check Engine Light...
- New Kia Incentives and Rebates – Dealer Negotiation Tricks Email
- Help where is the o2 sensor located
- 2001 kia fueling problem
- 2000 Kia Sportage starting problem
- Gas Milage
- Check Engine Light Codes
- 2010 kia sportage spyshots
- 01 sporty only idles
- sportage drive cycle
- 2000 Sportage head bolt torque
- 2002 Sportage P0171 Code
- 1998 sportage front brakes
- 2001 Kia Sportage driveshaft problems
- 2007 Kia Sportage
- CEL on, then off, then on, then off....P0304&P0343
- please help! my 96 sportage died on the hwy and now it wont start...
- 2000 sportage
- 98 kia vibration
- Thumping in front end, tire feels loose
- 2001 kia power serge
- Alternator mounting bolt
- 2000 Kia Sportage died on fwy. Will Turn over but not start...HELP
- ecm
- No power when gas pedal pushed
- egr valve
- 00 KiA Sportage 4wd Locking Up on Turns
- Overheating 2001 sportage
- Where is the fuel filter on '99 KIA Sportage? PLEASE HELP!!
- Where is high pressure fuel filter '99?
- codes
- no power 97 sportage
- *URGENT* Need right rear backer plate for 95 Sportage!
- Washington and Jefferson Nat. Forest
- KIA Sportage OBD2 Problem
- Sneaky gas smell
- blower motor
- Ragtop -suitable replacement?
- 2000 Sportage Installing Glow Gauges
- 2000 kiad sportage no power
- 2000 kia sportage help no power
- 4wd dont work, only 2wd...
- 01 sportage busted timing belt
- question about alternators
- had spark plugs changed ...now wont start
- 2001 Sportage died on highway and wont start...timing belt??? And How to replace it
- 1999 Kia Sportage won't start
- 97 Sportage 4wd and #2 misfire problems
- 2002 Sportage - in drive mode
- 98 Sportage Vibration
- engine light code reading help
- 2001 sportage weird vibration
- help with timing/head gasket
- 4 wheel drive making noise ONLY! HELP
- Kia 98
- kia sportage 2000 blows fuel inj fuse
- 2000 Kia Sportage WILL NOT start when it is cold outside..HELP!!!
- 2001 kia sportage cel code p0171
- 97 Sportage making loud noise!
- replaced water pump and t.b. won't start
- Best solution for 2001 Sportage 4x4 hub issues?
- where is the crankshaft position sensor
- extreme starting problems
- Dash Lites... no engine turnover
- fuel filter
- Brake issue, soft pedal - 01 Sportage
- Crankshaft for sale
- need engine for 2000 Sportage
- fuel pressure
- Hard to start when cold
- Help with O2 sensor
- help
- ABS sensor - replacement
- 07 Sportage-Can't find touch-up paint
- 98 sportage rear hatch help--
- car alarm 97 kia sportage
- trying to fix rear drifeshaft and carrier bearing
- Help PLS!
- gas cap
- Sportage remote failure , engine not start :|
- Intermittent starting problem KIA
- 2000 kia sportage engine wont start when hot
- engine don't start
- Hold button and 4th gear Help Please.
- Need maint manual for 01 Sportage
- Power loss after transmission replacement
- Changing fuel filter on 2000 Sportage
- 98 Sportage Fuel Tank
- 98 sportage speedometer not working
- 2000 sportage-difficulty starting when engine is hot
- 1998 Sporatge Knocks when braking
- Support Bracket Intake Manifold
- check engine light flashing
- kia the power to suprise
- 2001 Kia Sportage trouble starting
- HELP!!!! My 2001 Sportage wont start
- "Help" Sportage will not start!!!!
- Srs Light
- 2000 Kia Sportage - Timing Belt Problem?
- 97 sportage 2.0l ignition coils and spark plug wiring
- 2007 sportage water inside
- Squeeky belts when it rains-solved
- need help after changing sportage motor
- 2001 kia sportage 4x4 problem
- Transmission Problem
- 2001 Sportage with no power
- Vibration on Acceleration and Coasting in High Gear
- 2001 Sportage power lock problem
- P1795 code - 00 Kia Sportage
- 2000 sportage fuel gauge problem
- 96 manual transmission prolem
- help!!!
- No Start and OBD connector location?
- coils melted,still has miss
- 1998 Kia Sportage "NO POWER"
- Hub nut socket
- Fuel injectors
- kia sportage running fast
- Water Pump Question???
- Need advise on 2000 Sportage
- Repair Manual
- 1997 kia sportage timing belt
- Looking at buying a 97 Kia Sportage
- CEL light when it rains
- 2001 Kia Sportage Brake Warning Light
- 1999 kia sportage will not start
- timing belt
- 2000 Sportage: Won't shift out of park! HELP!
- need confirmation of marks?????
- 1999 SPortage warranty problems
- two questions in 94 sportage
- Transfer case shifts hard
- 2001 Kia Sportage starting problem.
- 2000 Sportage Starting Problems
- is this possible??? need a fix
- 98 kia sportage won't start?
- 2000 Kia Sportage Door Locks
- sportage airbag
- 99 sportage sloppy 5 speed shifter
- 2000 Sportage 2wd rear main leak
- 2000 sportage has me boggle read
- Blower motor
- 2000 Sportage Will Not Start ????
- 2000 Kia Sportage keeps blowing Meter Fuse
- 99 sportage 4x4 all or parts for sale
- fan bracket
- Cold weather starting problems
- non interference engine
- 1995 speedometer quit
- t-belt ?
- Cant change gears
- 2002 Sportange No 4WD Troubleshooting
- cranks but no start or intermittentstart
- 2002 Sportage no heat inside? Heater Coil?
- Fuel tank maintenance
- 1999 sportage overheating
- 2000 kia power loss just put new battery in whats up?
- Clutch replacing
- 99 Kia Sportage, AC, Windows, & Wipers quit
- 2001 Kia Sportage running rough after overheating
- 99 Sportage Tranny
- 1998 Kia Sportage OBD code P0264
- What Now??
- KIA Sportage – sputtering - misfire - no power - check engine – smoke - PO303
- HELP - 2001 Kia sportage 4x4 Power Steering problem
- removing rotor on 4wd
- heater core replacement
- 98 Sportage Won't Start After Fuel Filter Change
- New video brochure for Sportage shoppers
- need 5 speed for 01 sportage 2wd
- Kia Sportage Wheels
- Fuel Pump Issues
- 2001 kia sportage fuel injectors
- starting issue 2001 sportage
- 98 Sportage-clutch slipping
- Fuel tank differences 2dr/4 dr
- O2 sensor draining battery?
- 95 Sportage AC not working
- 2001 Kia Sportage oil filter leaking
